Old Apr 06, 2012, 06:25 PM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Question
Spoilerons and Pylon Racing
I notice that some racers set their planes up so that on the straights the trailing edge is lifted a few mm to improve speed and then on the turns the trailing edge is dropped to normal position to improve lift and thereby tighten the radius of the turn.
My question is: How is this done? By a TX mix where the spoileron setting is mixed with the elevator I presume? Or is there some other way?
Thanks in advance!
Peter
Peter M is offline Find More Posts by Peter M
Old Apr 06, 2012, 08:18 PM
Alien_Tech is offline
Find More Posts by Alien_Tech
Pile-it
Alien_Tech's Avatar
United States, CA, Palmdale
Joined Nov 2007
I mix elevators to the spoilers, so when you pull they come down.
Red
Alien_Tech is offline Find More Posts by Alien_Tech
Old Apr 06, 2012, 09:57 PM
DHG is offline
DHG
Find More Posts by DHG
DHG
United States, CO, Arvada
Joined Jul 2010
Thanks in advance!
Peter
Peter,
This only works on some airfoils, usually not enough gain to make it worth the effort. But those who do it use a separate servo for each wing panel (naturally) and an electronic mix function in the transmitter. On the JR transmitter, it's called the "flaperon" function.
One place where flaperons are helpful is on landing. I prefer to have the ailerons kick up slightly (actually a spoiler effect) as Red suggests. This dirties up the airplane and raises the nose for a slower glide.
Hope this info is helpful.
Cheers,
Duane
DHG is offline Find More Posts by DHG
Old Apr 07, 2012, 04:38 AM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Thanks in advance!
Peter
Never actually raced with it man, but snap flap is good fun. You do definetly get a boost in turn speed. A few models Ive set up a mix where 100% throttle reflexes the TE of the wing, and up elevator drops the TE (snap flap). As DHG says, it depends on the model as to how well it works.
Set up a few mixes and give it ago
jackosmeister is offline Find More Posts by jackosmeister
Old Apr 07, 2012, 04:05 PM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
Originally Posted by jackosmeister View Post
....Set up a few mixes and give it ago
Thanks guys, I might just have to give it a go!
(I use spoilerons on a switch for my gliders and hotliners but never mixed with elevator and/or throttle before and just needed a push....)
Discussion Pylon Racing 2012 MattinAZ Arizona Model Aviators 235 Aug 17, 2012 07:10 PM
Wanted Fast pylon race type - mohillbilly Aircraft - Electric - Airplanes (FS/W) 9 Oct 05, 2011 09:08 PM
Fly-In Neprcc open fun fly and pylon racing Alrus1 Electric Flight Events 1 Sep 20, 2011 12:31 PM
Yippee! 2012 FPV AIR RACE NATIONALS - UPDATE 13/SEPT/11 - Pylons and Course Walk Through wac FPV Talk 18 Sep 17, 2011 10:23 PM
