Can't get much better than Phil Barnes Vacuum Bagging Made Easy.
http://www.rcgroups.com/forums/showthread.php?t=1625321
I am having a third anniversary sale on the instructional DVD's I have produced. Please read the reviews on my website that George Voss did for RCGroups. Curtis |
United States, MA, Waltham
Joined Dec 2001
I think if I was going to bag a wing I'd get a big, repeating shotgun. But it's easier to buy or build them, and then you don't need to remove all those pesky pellets. ;-p
----------- More seriously, I don't know what materials are recommended in the videos, but cheap substitutes are often acceptable. I generally don't do wet layup bagging, but since I have the stuff I use vacuum bagging for a lot of things. Today I just bagged a sneaker that I was gluing back together! Recently, I bagged a work bench using a tarp for a vacuum bag. Obviously only a new tarp will do, and I suppose there is a little bit of leakage, but it worked. 5 mil polyethylene from a building supply place works too. For sealing the bags, I use 3M strip caulk that I buy at an auto body shop place. I don't know if it's cheaper than the official stuff, but it works well and it's local. I use paper towels to soak up excess glop in the bag. I've used polyethylene sheet instead of mylars. Doesn't need waxing as it releases pretty well by itself, but it needs to be thicker as the material is not as stiff. Depending on how much vacuum you need, there are alternative, inexpensive vacuum pumps. When I need a lot of vacuum (like, say, 20 inches of mercury), or a large volume of air to keep up with leaks, I use a commercially available pump, though I want a better one. However, I also have a moderately large aquarium air pump which I put inside a large can. The exhaust hose comes out of the can, and the hole is sealed so air can't get in past it. Another hose goes into the can, and that provides the vacuum. If budget is an issue, check out surplus places. They often have pumps that are cheaper. Try to have a filter right on the inlet so crud doesn't get inside and mess up your pump. ----------- Suggest for practice you bag cheap materials onto lousy cores or scraps of foam. Maybe cardboard or epoxy soaked kraft paper.(The latter, I think, might make an acceptable wing.) Once you've got these kinks worked out, you can then start working with wet layups. |
Latest blog entry: pics from Winthrop, MA indoor flying...
United States, WI, Appleton
Joined Jul 2010
Phil, I'd like to order your DVDs, but none of the links below seem to work:
"Convinced? Good! Vacuum Bagging Made Easy is available from Bill Haymaker at: http://www.paonline.com/hayman/video.htm Forms of payment include checks, Money Orders and Paypal http://www.polecataero.com http://www.nesail.com" |
US and Costa Rica
Joined Dec 2004
Hi,
please forgive me for jumping into your thread but I'd like to start doing this too and I will order a set of Phil's DVD's next month while I'll be in the US but at this time I have a good chance to buy the pump here since it's a bit heavy to bring it down but I'm not sure if this would work or if it is a good choice. http://www.harborfreight.com/25-cfm-...ump-98076.html I know I can use a fridge motor but those are not free here. All this is probably discussed on the DVD's but as I said I won't be able to see them until next month and there is a sale here where I can get this pump cheaper (for the first time in human history) than in the US. Thanks for any input and apologies again for hijacking. Fernando |
| Thread Tools | |
| For Sale Wing/plane Bag Open Class Bag Lady Bag | quietman | Aircraft - Sailplanes (FS/W) | 1 | Aug 10, 2007 07:33 PM |
