Old Apr 27, 2012, 09:13 AM
cyberdog is offline
Find More Posts by cyberdog
Sweden, Norrbotten County
Joined Jun 2007
Use the motormounts that came with the motors and put them between motor and motorplate. Belive they are about 3mm thick and perfect for it. Thats how i did
cyberdog is offline Find More Posts by cyberdog
Old Apr 27, 2012, 12:16 PM
unrealistic is offline
Find More Posts by unrealistic
unrealistic's Avatar
The Netherlands, UT, Utrecht
Joined Mar 2012
Thx for the tip, Peter!
I found out the bolts are 'normal' M3's and I bought some longer ones.
With the X-mount adapters everything lines up nice:
unrealistic is offline Find More Posts by unrealistic
Last edited by unrealistic; Apr 27, 2012 at 05:07 PM. Reason: changed the motor orientation. Prop must point up! ;-)
Old Apr 27, 2012, 04:04 PM
cyberdog is offline
Joined Jun 2007
Thats how i did it Now i use G10 spacers. I belive its only you and me that has the same frame.. Well the only 2 posting pics
I Belive you mounted motor upside down
Old Apr 27, 2012, 05:05 PM
Joined Mar 2012
And all the secret builds of this frame!
I just cut the booms to 37.5 cm.
Tomorrow I can attach the arms with motors.
Where do you have the esc's?
Thx for the tip.
I changed them. Propellor must point up?
Old Apr 28, 2012, 05:14 AM
Joined Mar 2012
This is the frame with cut booms.
Motor to motor is about 80cm / 31 inch.
The wire just reach the center:
Old Apr 28, 2012, 06:48 AM
cyberdog is offline
Joined Jun 2007
Looking good. Mine is 94cm MtM
Need to clean up some wires because it looks bad.
Old Apr 28, 2012, 11:14 AM
Joined Mar 2012
I measured mine at 83.5 cm.
You didn't cut the booms back?
I needed to or I had to lengthen my motor leads.
These iPower 2814Q motors have long leads, so hopefully I can connect them like this.
Where did you put the esc's?
I'd like to keep all screws free, so I can remove / adjust the arms without removing the esc's.
I was planning on making the arms removable, but with the landing gear rotated between the arms, it is quit compact already.
The flexacopter mounts only need the outer screws loosened, I believe.
I would have to loosen all 24 screws, which is hard with the FC and battery cage on.
Old Apr 28, 2012, 12:39 PM
cyberdog is offline
Joined Jun 2007
Think i cut my booms around 30cm each. My ESCīs are mounted under the bottom plate. Will get a pic of it tonight.
Old Apr 28, 2012, 01:08 PM
cyberdog is offline
Joined Jun 2007
My motorcables are still too long So i guess the Tiger Motor wires are longer than yours
Old May 01, 2012, 02:26 PM
Joined Mar 2012
I am still waiting on parts but I came across a nice gimbal for a good price.
It fits really nicely.
For now I won't be using the pan axis.
Old May 05, 2012, 03:34 AM
Joined Mar 2012
I flashed the ESC's:
and I started in the power board.
The board I got from Ebay was too small (diameter) so I cut my own:
Wish me lucking connecting the motors ;-)
Old May 21, 2012, 04:27 AM
Joined Mar 2012
I have dropped the idea of the power board.
It was getting too heavy.
Coming week I will solder a power spider instead.
This is how it looks now:
Old May 26, 2012, 08:58 AM
cyberdog is offline
Joined Jun 2007
Looking good so faar. Any updates lately ?
Old May 28, 2012, 03:36 AM
Joined Mar 2012
no updates.
I am waiting on my batteries and I am working on the power distribution.
The board was too heavy, so I am going for a wired spider to supply power to the esc's, bec and leds.
The leds are awesome! :-)
They are 6 x 1 Watt leds on the motor mount.
I have tested them on 200ma and they are really bright.
When the power distribution is on, I will post more pics.
<edit>
Leds working on the FC:
Led test for hexacopter (0 min 8 sec)
This is on just 60-70% brightness ;-)
Old Jul 25, 2012, 02:26 AM
Joined Mar 2012
first test flight:
first flight of unrealistic's hexa. (0 min 46 sec)
This was with the Black Vortex but I didn't like it.
I had the Naza on my F450 so I wanted to try that.
This worked really nice!
Naza on Hexorcism 600 (1 min 33 sec)
I think I am going to sell my Black Vortex board.
The PID tuning is difficult without good flight experience and I don't want to crash the hexa beacuse of this.
Discussion AP - Great ..Big City festival.. guyg Aerial Photography 1 Feb 25, 2012 09:52 AM
Discussion Quad or Hexa for AP fiego007 Aerial Photography 5 Jan 14, 2012 09:12 AM
Discussion AP Hexa or Octo? What gives you the best stabilisation? Voguna Multirotor Talk 7 Feb 09, 2011 06:35 AM
Discussion Folding frame for AP - tri, quad, Hexa, Okto danielpetrescu Multirotor Talk 9 May 10, 2010 12:25 AM
Build Log lets build a BIG ap/av plane. cars4fun2001 Aerial Photography 130 Oct 02, 2007 11:56 AM
