This thread is privately moderated by SkyCadet, who may elect to delete unwanted replies.
Old Apr 05, 2012, 10:00 PM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
Wing wires installed!!!
I used a Sullivan Wing wire kit and an extra spool of 30' wire (needed about 3 feet more than I had in the kit - figures...).
My approach was different than many - I wanted a clean look to the wires, without all the turn buckles and such. So, I used the grommet mounts on the wing struts, and two eyelets on the cabane rear struts, and two on the gear struts.
This way, I use one set of wires on each side and level to snug up! Two bottom strut wires go to the upper rear cabane strut through an eyelet, and the other side same. The top strut wires on both sides go to/through the eyelets on their respective sides at the gear. This allows a shared load between wires, and a cleaner setup (but trickier to install!). The loops are affixed with crimps and CA, any excess is removed via a Dremmel and diamond wheel (carefully!).
See pictures of this below. I adjusted the tension using the nuts on the eyelets to be able to increase tension on two wires at once. They are taught, but not too tight, and I have enough room to adjust them further if need be...
Now, the aileron linkages, and prop/canopy and balance! Whew!
Skycadet
SkyCadet is offline Find More Posts by SkyCadet
Question Broken servo wire in composite wing planepainter Thermal 6 Mar 23, 2012 09:18 PM
Discussion One man foam wing cutting wire position calculator chiloschista The Builders Workshop 7 Mar 08, 2012 03:35 PM
Question Which wire to cut on esc for twin install Ken Smith Electric Plane Talk 15 Dec 14, 2011 03:18 AM
