Old Apr 05, 2012, 07:36 PM
Multicopter Addict =)
copteryx's Avatar
Mexico, JAL, Puerto Vallarta
Joined Apr 2009
The yaw not work in my HFP
Hello,
I have a HFP green board and I was happy with the perfomance but sice 1 month ago the yaw stop working, I do all the test in the hoverfly setup software and everything its ok but when I try to fly it, the quad spins in CW direcction, I mount the board in a Y6 with robbe motors, turnigy push esc, 10x45" and 12x45" props, I try in my hexa DJI f550 flat with the same motors with 10x45" and the last try in a xaircraft X650V 4X with avroto motors an 1147 props, I upgrade an downgrade the firmware, all the setups same problem no yaw response, I use the same Tx (Ftaba 8fg super) with my WK-M and my KKblack board with out any issue, Im very dissapointed, any idea whats wrong?
Thank you
Pepe
copteryx is offline Find More Posts by copteryx
Old Apr 05, 2012, 09:11 PM
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
It is usually either....you need to re-calibrate the throttle on the ESCs, mechanical misalignment (motors have to be straight up and down), Props not rotating in correct direction, Gyro failure (use the Setup Client to test this), motors not connected correctly to the PRO. Check this last one since there may be a difference in setup on the other controllers.
photronix is offline Find More Posts by photronix
Old Apr 06, 2012, 02:53 PM
copteryx's Avatar
Joined Apr 2009
Ok I will recheck
Question Weird problem with New Y-6... Throttle works, but not Pitch Roll or Yaw Adidas4275 Hoverfly Technologies 4 Apr 02, 2012 11:21 AM
Discussion my new traxxas slash not working Patriot2373 Off-road Cars 12 Mar 14, 2012 12:10 PM
Help! Y6 Yaw stops working in the air kuutee Hoverfly Technologies 34 Jan 12, 2012 12:00 PM
Help! Y6 perfectly stable - and not responding in mid air! (HFP) ed.ge Multirotor Talk 0 Dec 22, 2011 01:27 PM
Help! Yaw does not work eaton Coaxial Helicopters 0 Jun 02, 2009 11:34 AM
