Old Nov 04, 2001, 11:37 PM
King Kong is offline
Find More Posts by King Kong
King Kong's Avatar
los alamitos ca
Joined Jun 2001
Shear Web?
I'm building an Explorer 2M. On the plans for the wingsThe Spar stops and the SHear Web starts. It dosn't say how big to cut the strips. It says how thick, and how long, but not how wide. This is stopping me. Please help!
King Kong is offline Find More Posts by King Kong
Old Nov 05, 2001, 12:31 AM
Lenny970 is offline
Find More Posts by Lenny970
Lenny970's Avatar
Greeley, Colorado, USA
Joined Feb 2000
I can't address the Explorer specifically, but in general, shear webs fit tightly between the top and bottom spars and provide a great deal of strength to the wing. They should be a good fit with no gaps and glued securely. It's usually best to cut them slightly oversize and sand them to fit exactly between the spars. Note that the balsa grain should be vertical. Thickness of the webs near the wing root are often equal to the width of the spars, with the webs getting progressively thinner toward the wing tip.
Good luck,
Lenny
Lenny970 is offline Find More Posts by Lenny970
Old Nov 05, 2001, 08:27 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Although between the top and bottom spar strips is best, many kits have you glue the shear webs to the sides of these stips - you can cut them a little tall, and then sand them flush (making sure not to sand the ribs)..
..a
Old Nov 05, 2001, 08:42 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
What Andy said, glueing the webs to the front or rear face of the spars is a lot less work and very nearly as good. That's what I've always done with my own designs, never had a wing fail in flight yet!
But Lenny's description is certainly the 'proper' way to do it!
Bill Glover is offline Find More Posts by Bill Glover
Carbon or balsa shear web for I-beams SkyPyro Composites Fabrication 13 Mar 04, 2009 05:37 PM
depron shear web mr_wood Hand Launch 1 Aug 12, 2005 09:08 PM
What is a shear web? Yardbird The Builders Workshop 42 Feb 22, 2005 11:55 PM
Shear web theory ? FlyByMike Modeling Science 8 Jul 05, 2003 09:08 PM
Shear web question dwood99 The Builders Workshop 15 Apr 23, 2003 07:34 PM
