Old Apr 04, 2012, 08:45 PM
Jessestr is offline
Find More Posts by Jessestr
BelgiŽ, Vlaams Gewest, Evergem
Joined Nov 2011
New Product
zeroGravity - An STM32 Flightcontroller based on PIPO32 hardware
First of all hi!
Dialfonzo (Eric) and I are working on a flightcontroller based the current PIPO32 (Link to website) hardware. It uses an STM32 chip.
Our goal is yet to make another flightcontroller with some new features. We have more room for programming code and storage and lots of speed to use.
All of the sensors will be onboard so no more stupid cables to solder, no more vibrations causes by cables.
Feel free to join the development. Contact me in PM.
Goals (listed)
- Creating the most minimal system necessary in code as in hardware
- Creating a plug-in system for Sensors, GPS, whatever
- As less as wires as possible.. All sensors will be onboard
- Easy changeable code
- Clean code
Achievements
  • Ordering the PIPO32 board
  • Port AfroFlight32 / PIPO as a test
  • Build our own flightcontroller
Microcontroller
We will use this platform as prototyper: (Thanks Erazz - It's the PIPO board )
Feel free to ask, help and share things..
Jessestr is offline Find More Posts by Jessestr
Old Apr 04, 2012, 10:04 PM
Jessestr is offline
Joined Nov 2011
-- More information --
Old Apr 05, 2012, 09:19 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Ok
We are waiting for some feedback from programmer to lock on that hardware.
Anyone ?
Dialfonzo is offline Find More Posts by Dialfonzo
Old Apr 05, 2012, 09:54 AM
robert b is offline
Find More Posts by robert b
Switzerland, Aargau
Joined Mar 2011
really needed
The STM32 processor is a really good a powerful processor for multicopters it can handle much and at a fast speed.
It works on 72MHz with 20KB SRAM and 128KB Flash that gives us enough storage room and power - even if we want to keep it as minimal as possible -
Another advantage is that it runs on a arduino based platform but for 32 bit processors. So still the known form of arduino but in a new jacket.
the base platform is sh**.
there is no advantage using arduino.
mainly because arduino will be using another core.
i would need more memory... and a faster chip.
plus sd card interface
plus secondary spi flash chip.
any experience on mems devices?
or just re-using what others use?
am i bad ?
this is just fresh copy of existing ideas.
nothing new and the processor is from the past.
robert b is offline Find More Posts by robert b
Old Apr 05, 2012, 10:16 AM
erazz is offline
Find More Posts by erazz
erazz's Avatar
United States, NJ
Joined Jun 2004
robert b, I think you got it wrong
Though they use the arduino environment the CPU is pretty good. The problem is the lack of on-board sensors.
The chip has a lot of memory and is very fast. Why would you need another spi chip?
Fair disclosure: I'm also building a 32bit board. I know that the easiest thing is to actually build the board. The biggest issue is software, I know this from experience. You can have the greatest board in the world, if you don't have software its not going to be any good.
erazz is offline Find More Posts by erazz
Old Apr 05, 2012, 10:23 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Thanks erazz i apreciate your feedback
The board is mostly a Prototype board.. To make sure it work.
Plan is to make our own PCB soon if everything is ok.
Want to merge with Pipo ??
Old Apr 05, 2012, 10:28 AM
Jessestr is offline
Joined Nov 2011
@Robert
We sure will innovate this project and make it different than just another flightcontroller.
@Erazz
Thanks for your opinion. I'm a developer too.. maybe we can something out with PIPO like Dialfonzo said?
Start with fresh and clean innovating ideas for a 32bit capable platform
Old Apr 05, 2012, 10:56 AM
robert b is offline
Switzerland, Aargau
Joined Mar 2011
i don't think so.
- loiter - add a filter for gps estimates.
- use google 3d data to verify the current height abouve ground
and - i re-used an older kalman filter on an st32 chip.
to be precise timecop's hw.
i ended up at a 400 hz mainloop and a few things are not yet done.
and yes i did use an mpu-6050 which means quite fast reads to obtain mems data.
hmm - need more ram - more cpu cycles ... not in a row pls. - per timeslice
Old Apr 05, 2012, 11:33 AM
robert b is offline
Switzerland, Aargau
Joined Mar 2011
hw developper?
to start with, there is a need:
- 32 bit platform - easy of development
- jtag interface
- any mems device will do it - on a desk i don't care about vibrations.
so i take:
- lpcxpresso with 120 mhz cortex m3
- freeimu
- gps device
when i looked at the maple stuff stuff i made u-turn in record time.
and i am set.
Old Apr 05, 2012, 11:38 AM
erazz is offline
erazz's Avatar
United States, NJ
Joined Jun 2004
Well thanks for the offer guys,
The PIPO32 HW board is done and on it's way to me. I should have completed boards within a week. I'll open a new thread so I don't hijack this one.
Old Apr 05, 2012, 11:50 AM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
sounds like uavx-arm revisited. (which need a hardware as well) why start fresh when there are good code base to start from.
askman is offline Find More Posts by askman
Old Apr 05, 2012, 12:00 PM
robert b is offline
Switzerland, Aargau
Joined Mar 2011
that base needs to be setup in a cleaner way.
i assume it is a testbed for various sensor fusion algrithms.
has anyone used it as a base?
Old Apr 05, 2012, 12:17 PM
Jessestr is offline
Joined Nov 2011
As I can see on your google code PIPO32 is just AfroFlight - MultiWii port..
Old Apr 05, 2012, 01:31 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Well... is there any way we could have boards to developp?
Old Apr 05, 2012, 02:36 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by robert b View Post
hw developper?
- jtag interface
so i take:
- freeimu
- gps device
and i am set.
You know any board that we could use to developp ?
Wanted NEED USBASP AVR Programmer mamba max1 Aircraft - Electric - Multirotor (FS/W) 0 Mar 30, 2012 11:36 AM
Sold New Microchip PICkit 2 Starter Kit programmer 34Ford Non R/C Items (FS/W) 2 Mar 03, 2012 06:05 PM
Discussion Another confused noob needs help please. Anarchy1 Multirotor Talk 25 Mar 01, 2012 05:09 AM
Sold Hitec servo programmer new! jakeg1999 Aircraft - General - Radio Equipment (FS/W) 3 Feb 29, 2012 09:45 PM
Sold NEW BALANCED EDF WITH MOTOR + ESC + programm card pajlotmato Aircraft - Electric - Jets (FS/W) 0 Nov 22, 2010 06:12 PM
