This thread is privately moderated by Ribble, who may elect to delete unwanted replies.
Old Apr 04, 2012, 08:11 PM
Ribble is offline
Find More Posts by Ribble
Crash and learn
United States, PA
Joined Dec 2011
Data
DH9104 NOTES - Motor FETs and Motor Amps
fly4fun6719 pulled a part number off one of the DH9104 motor switching FETs.
Part number is: CEP73A3G
N-Channel Enhancement Mode Field Effect Transistor
CEP73A3G/CEB73A3G
30V, 62A,
RDS(ON) = 9mW @VGS = 10V
RDS(ON) = 16mW @VGS = 4.5V.
Super high dense cell design for extremely low RDS(ON).
http://web2.cetsemi.com/PDF/TO-220-263-N/P73A3G.PDF
fly4fun6719
"Purchased a IRF1405 mosfet from the local electronics store and fitted it..I tried it with the receiver out of the helicopter and it appears to work ok.The only problem I had was removing the original mosfet. I haven't done this sought of work for some years and I am a bit rusty."
IRF1405 should work as a replacement for any Syma or Double Horse receiver board.
Note: Input control Voltage Gate to Source is 5.0v for 20 amps motor current, though it does start switching ON between 2.0 and 4.0 Volts.
VDSS = 55V
RDS(on) = 5.3mΩ
ID = 169A
http://www.redrok.com/MOSFET_IRF1405...4.0_TO-220.pdf
IRFZ44N IRFZ44 Power MOSFET N-Channel International Rectifier - Banggood
http://www.banggood.com/Wholesale-Ir...t-p-44871.html
DH9104 tail motor was 2.99 amps full speed off 7.4v 1300mah Li-Ion stock battery.
Main motor 5.72 amps full speed off 7.4v 1300mah Li-Ion stock battery.
Non-motor load = 23ma = receiver and forward white floodlight LED (Transmitter turned off)
Receiver without LED and motors = 16.1ma (Transmitter turned off)
Receiver without LED and motors = 17.6ma (Transmitter turned on)
Receiver without LED and motors, Servo disconnected = 9.6ma (Transmitter turned off)
Receiver without LED and motors, Servo disconnected = 11.2ma (Transmitter turned on)
7.4v 1300mah Li-Ion stock battery = 7.67 volts no load after running tests (needs recharging).
I had expected main motor around 10 amps. It may not have been running full speed due to the test leads, but the main blades were bending upwards, so 5.72 amps is at least close.
Motor ampere measurements were by shorting motor switching FETs to ground through ammeter. Kids, don't do this at home!
DH9104/9100 TX schematic drawing
http://www.rcgroups.com/forums/showthread.php?t=1571121
Ribble is offline Find More Posts by Ribble
Discussion going flybarless on a dh9104 305coco Electric Heli Talk 7 Aug 04, 2011 10:35 PM
Discussion Experience and opinions of DH9104, 9100 please nvidia101 Coaxial Helicopters 5 Jul 09, 2011 06:35 PM
Question I need two or three 20 to 30 amp Fet's. Help. himeros DIY Electronics 5 Dec 14, 2006 01:49 PM
Question FET & Max. Amp for BL speed controller Dhammapol DIY Electronics 7 Sep 06, 2005 11:30 PM
