If you're moving the goal posts I can beat you all with one of these.
I got the idea from Derks &Dayheads posts in the walk along gliders thread on the free flight forum.They have been good value with the kids over the hols.Just enough weight to balance,twist the wing and a touch down on the centre.Just a slight push and they go into an almost flat glide.This is one of the least successful,not enough wing area,but still floats across the room.
Jens,you should make some of these!They demonstrate how these things fly.Leave them flat and they just side slip away.Put some twist in and they go straight as an arrow.It's surprising how much effect bending just the bat tail makes.I've been using 2mm depron and kitchen film.This ones a bit too small,I was trying to get a bit of durability!I'll leave you to rc one,bet you've got the bits somewhere
![]() Regards Stuart |
Moving the goal posts
Since there are so many linear twist flying wings in the vintage section, thought I'd try a high aspect ratio version. This free flight model is for testing CG. It has a thicken MH45 at the root with 10 degrees of linear twist out to a SD8020 at the tip. Cut from foam with a 1/64" plywood spar caps. The tip chord matches the lawn chair slats in width.
Kent
Nice wing Kent.Now we know why all the tissue testing!
Did you have any issues with the foam bending after the hot wire?I must admit a slight concern about this when I come to cut the sections that you sent me for Verns wing. Looks like you had some still air,where did the cog end up? Stuart |
| Thread Tools | |
| For Sale Supra Competition Carbon Light $950 shipped SOLD | Wetcoast | Aircraft - Sailplanes (FS/W) | 8 | Apr 23, 2012 10:17 PM |
| For Sale Supra Pro Competition Carbon Lite, team plane | Wetcoast | Aircraft - Sailplanes (FS/W) | 4 | Mar 20, 2012 03:27 PM |
| For Sale Supra Competition Carbon Light | Wetcoast | Aircraft - Sailplanes (FS/W) | 0 | Mar 14, 2012 01:49 AM |
| Discussion Why do DLG competitions let you switch planes? | isoarthenland | Hand Launch | 34 | Dec 21, 2011 08:47 AM |
| Discussion What's a good competition ALES plane to get? | Big Browns | Electric Sailplanes | 12 | Dec 20, 2011 07:43 AM |
