Old May 06, 2012, 08:28 PM
fmkit is offline
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Originally Posted by BCSaltchucker View Post
Wow, kind of disappointing to see the failures with this cam.
Would be great to use the AV-out for FPV on smaller planes, but if this thing crashed going from dark to light....
AV-out never crashed on me, just some recordings get damaged while others look decent.
here is original video recorded onboard small flying wing, lots of shake and low light
if you wonder how the video stops exactly when I catch the plane -- I just pushed button on my nunchuck controller stopping recording remotely.
http://www.fpv2.com/img/PTDC0016.AVI
fmkit is offline Find More Posts by fmkit
Old May 07, 2012, 10:07 AM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
that good to know, so the crashed only effect the recorded files?
i have downloaded your files it true then you cant simply edit it using windows movie maker but it play fine though
skellator is offline Find More Posts by skellator
Old May 07, 2012, 12:47 PM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
today I flew the cam and all files were bad, went home, fixed pan and flew again now panning away from clear sky or something that camera can't focus and got usable files, was able to edit with TMPGE
http://www.youtube.com/watch?v=fr7QSHzxTMc
Old May 08, 2012, 04:31 AM
Dionysos is offline
Find More Posts by Dionysos
Singapore, Singapore
Joined Apr 2012
I got 2 of these and am **unhappy**.
I have the corruption bug as well. I couldn't provoke it by chaning in illumination, but it occurs after ~4min. Every single time.
To me it seems rather some sort of buffer overflow problem rather than illumination.
Nice toy, but with this bug a NO_ GO. Get the #16.
Dio
Dionysos is offline Find More Posts by Dionysos
Old May 08, 2012, 07:02 AM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
Dio
What is the Make, Size & Speed class of your SD card(s) ?
empeabee is offline Find More Posts by empeabee
Old May 08, 2012, 07:49 AM
Dionysos is offline
Joined Apr 2012
transcend class4, 16Gb...
corruption looks identical to the one posted at exposure room. Top of the picture still clear, bottom gone, pitching/high-pitched noise.
Old May 08, 2012, 07:52 AM
Dionysos is offline
Joined Apr 2012
@frank:
could you do me a favor and try to take a video for more than 5mins with this config
#18 with hardware revision
I just received a new test camera that, according to my Ebay vendor contact with the developer, has had some kind of hardware modification to it (I think to fix the file corruption that occurs when panning the camera from the ground to the sky). Here's one of several brief tests I did with it... all with similar results:
Brief test of Revised #18 HD keychain camera (0 min 26 sec)
Old May 08, 2012, 08:20 AM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
I have exact same problem with 16gb cards, yesterday the DVR corruted file system on 16gb card so it appeared as 8gb with many strange file on it, formatted using laptop and it still appeared 8gb, then formatted with another car dvr and it was 16gb again but I decided only use 8gb with #18
Old May 08, 2012, 08:56 AM
Dionysos is offline
Joined Apr 2012
I won't tolerate this. If I have to make a drawback in terms of video quality compared to a GoPro, or any other similar cam, I'm totally ok.
But I cannot rely on a device that is faulty. Sorry guys, to me that's the definition of faulty. Just because something has 4 wheels, it's not a car. Would you mind the engine stalling after every 20km just because the car was cheap? Of course you would.
Same here with the cam.
a corruption file fix tools alias a perpetually rented towing service doesn't make sense. I'm too German for these games.
Dio
Old May 08, 2012, 12:18 PM
Tom Frank is online now
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
@frank:
I have shot much longer videos. The corruption does not occur at any given time interval, but occurs virtually EVERY time I pan the camera from pointing at the ground to up to nothing but sky with about a 1 sec. time span. I can also trigger the corruption with a bright LED flashlight byt putting the camera in a darker environment and suddenly shining the flash light into the lens from about 1 CM in front of it. It definitely has something to due to the light level change, but scene complexity also seems to come into play. If I keep just a portion of the ground in the scene, corruption does not occur, even when the majority of the scene is nothing but sky. But when the sky suddenly occupies about 90-95% of the frame, the corruption occurs.
Tom Frank is online now Find More Posts by Tom Frank
Old May 08, 2012, 12:20 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
I had an 8GB CL4 Sandisk card become permanently write protected while using the camera! The card has three files on it that cannot be deleted, and the card cannot be reformatted!
Old May 08, 2012, 12:43 PM
9W2DLR
Joined Nov 2011
that not good the camera getting bad as we speak, I order 1 now feeling maybe i make a mistake but the AV-out is hard to resist for fpv camera
Old May 08, 2012, 01:38 PM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Originally Posted by skellator View Post
........... but the AV-out is hard to resist for fpv camera
yes, even if it wasn't recording the camera w/AV-out is lightest I ever had
today flew some more:
#18 808 keychain camera onboard small flying wing, test 2 (1 min 23 sec)
Old May 08, 2012, 02:18 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
There could very likely be some serious competition for this camera in the market place VERY soon!
Old May 08, 2012, 02:53 PM
tete is offline
Find More Posts by tete
Joined Sep 2008
"There could very likely be some serious competition for this camera in the market place VERY soon! "
could you be a bit more specific Tom?
Cheers
tete is offline Find More Posts by tete
Discussion The ORIGINAL #16 HD keycam thread (read posts #1-#5 BEFORE posting questions) Tom Frank Aerial Photography 19381 Today 10:21 PM
Discussion HD Keychain Cam with A/V out frank48 FPV Talk 4 Mar 19, 2012 05:45 PM
Discussion New HD video camera for onboard recording with Live AV out ! oded mazor FPV Talk 6 Nov 09, 2011 12:49 PM
For Sale Aiptek HD Camera with AV INPUT $69...Target.com crd FPV Equipment (FS/W) 8 Dec 17, 2010 08:58 PM
For Sale Micro Keychain camera---OUT see new post for list p51p51 Aircraft - General - Miscellaneous (FS/W) 20 Apr 02, 2010 10:04 AM
