In my Falcon 120 I had to make up extension leads on the battery side, about 30cm long and I added 3 680uf caps to the esc end of the leads, but as the esc battery wires have not been touched there's probably close to 15cm of plugs and wire between the caps and the esc. The Turnigy Sentilon 100HV have worked perfectly so far.
Joined Feb 2010
re the question about lumped capacitance(caps all in one location) vs distributed(spaced along the wire), the only reason I can think of is that Jeti seemed to have a transmission line concept in mind when answering you email. Knowing the rise/fall time product of the cap and inherent line resistance together with wave travel time you can adjusting the spacing to impact the way reflections occur on the wires. Not sure if that is what they were concerned about.
I'll add that my dad is also an EE type and my discussions with him mirror the above. I asked him about adding caps in the middle of a long wire and he was under the impression that it would create more variables than take away but the Jeti guys have an interesting perspective and certainly have many thousand hours of high level thought on model applications. For those looking for a cheap and easy place to buy caps, I buy mine from a variety of places. http://www.thecapking.com/35zl220.html (this is for 4s, for example) http://electronics.mcmelectronics.co...ow+esr&x=0&y=0 (random search, these caps are a little big but a refined search can be done) Rubycon low ESR caps are among the best IMHO. Type in "low ESR" into the search port and then find your mUf value. I also use about 1.5 times my planned voltage for my capacitor voltage. I don't typically add caps just to add them but I do if my battery wires are longer than 8" and in a few models, this is a fact of the size or application layout. When I do add caps I tend to add one cap of at least 220muf capacity per 4 inches of extra wire. As said above by others, one large cap is not as good as two or three paralleled caps for longer wires. I always buy radial capacitors, they are easy to solder up. Protect the wire with paint on insulation that you can get at an electronics store, don't leave any bare wire. Also, wear and tear on the caps is seen with swelling on the top of the cap - over time heat and rapid voltage charging will wear out tje caps but I bet they will last longer than most the airframes will! But if you saw one looking a little dodgy or see one go off they are easy enough to replace. The other thing to consider. When we add caps, we are gonna get even more spark when hooking up. So make up your resister lead and plug that one in first to charge your caps slowly and not spark up your connectors. The batteries, connectors and caps will thank us
Latest blog entry: The Gas Turbine Engine (with images)
Joined Nov 2005
I've found with stiffing caps my packs come down cooler, they help with burst energy...
Why aren't the ESC makers just putting larger caps at the esc if voltage variance is such an issue. The bigger the stiffing cap (resistance etc taking into consideration) the lower the chances of ripples. |
Joined Nov 2005
I think putting bigger stiffing caps at the ESC is the answer for longer leads here. |
I have been flying caps in my Hawk now for the past two + years and no problems. I use caps in anything 10s and above. I fly the Hawk on 10s but have used 12s. As I have stated before I almost burned my F-86 because of ripple current and since that time I have used caps in line. Everything runs cool in my planes now.
Concerning longer wiring...........I have posted this thread before(many times)and there is good info in it concerneing wiring and caps. http://www.rcgroups.com/forums/showt...3#post10926525 |
| Thread Tools | |
| Discussion HK ESC + Turnigy Motor Timing Issue | lipoflyer | Power Systems | 6 | Mar 20, 2012 10:19 AM |
| Discussion Miracle of the Avus, or the one time it's good to have your seatbelt fail.. | CashRC | Life, The Universe, and Politics | 1 | Feb 23, 2012 01:27 PM |
| Discussion WWF ad just in time for 9-11 | E-MO | Life, The Universe, and Politics | 68 | Sep 03, 2009 06:28 PM |
| Question Nikon coolpix 3700 ad on ebay...is this a good deal/good beginner camera? | Picoflyer | Aerial Photography | 15 | Jul 26, 2004 01:13 PM |
