I built my first paddled flybar for my V911s and tried it out. I only hovered and did some really slow tight circuits and figure 8s but so far so good!!! I'll be trying it out some more tonight...
Latest blog entry: Fitting a Bravo SX fuselage to a GW 9958...
A few batteries on the MiniCP, outside and inside.
Latest blog entry: Vintage Kyosho Buggies, why I love 'em...
Put my V911 paddled flybar through its first real test last night and it really performed well! Flew my stock V911 right before it as a baseline. So far I'm quite pleased and will be making another paddled flybar for the stocker.
![]() Rebuilt my original S107G coaxial heli last night as well (replaced the RX board). I put on some snazy black Helizone Firebird parts (canopy, blades, and tail decorations) in celebration. Also added a stronger tail rotor to give it more zip. Fantastic maiden flight. Finally, I broke out my MCX S300 for another flight (been about a month) and marveled at the grace and stability of that little coaxial heli. Quiet, too. |
A few packs on the 270 as well.
Put in 4 flights on my pair of MSRXs to unwind after work. It's been two weeks since I flew them indoors and boy, was I out of practice maneuvering in tight spaces! I'll need to fly these guys a bit more regularly.
It was a little breezy today so I took my V911s and 9958s out for a spin. I had 110mm paddled flybars on the V911s and experimented with them. They're a bit more squirrely with the flybars and I might need to make those flybars shorter because I still got canopy strikes, but they fly well and definitely need more airtime.
The 9958s performed very well as usual (also with paddled flybars).Got in 9 flights total before the wind picked up and I had to pack it in. |
2 and 1/2 battery on the Mini CP, first battery was nice, controlled circuits, figure 8s, a little side in hover training. Second battery was more erratic, let the heli get away and lost orientation. I did see I was making it tilt nose and tail in some crazy angles as I operated elevator to regain orientation, but managed to get it under control again. A slight breeze came up, and during one circuit downwind, the heli went into a shallow dive, from which I could not make it recover. Close to the ground I slammed the throttle down (still not used to throttle hold) and "planted it down" on the concrete. Good thing it was jut a few cm above the ground when I slammed the stick down, so no damage. Flew a third battery after that, to verify then heli was still ok, but found no problems.
Pretty windy today so I tested out my custom paddled 100mm V911 flybars. Overall, the helis performed okay but the wind was definitely in control. I think the shortened (lighter) flybars work well for rapid changing directions but for long pushes in one direction they might not be as good as the longer weighted flybar. Flew 4 batteries between the two.
| Thread Tools | |
| Discussion What did you do to your plane today? | 809Flyer | Beginner Training Area (Aircraft-Electric) | 389 | Oct 18, 2012 10:53 AM |
| Discussion What did you steal from the field today? | Jim Varley | Arizona Model Aviators | 9 | Nov 09, 2011 10:14 AM |
| Discussion What did you fly today? | xrx1113 | Electric Plane Talk | 4 | Oct 25, 2011 09:37 PM |
| Discussion What did you fly before you flew the PZ extra 300? | skarface | Parkflyers | 5 | Oct 24, 2011 05:47 AM |
