Old Apr 03, 2012, 04:03 PM
Tucker33 is offline
Find More Posts by Tucker33
Joined Jan 2012
First Qudcopter - Hobby King Order - Check List Help
I need some help before I place my order on Hobby King, am I ordering the corret items or is something wrong for my first Quadcopter?
Motor = hexTronik DT700 Brushless Outrunner 700kv (13amp)
ESC = TURNIGY Plush 18amp Speed Controller
Battery = ZIPPY Flightmax 3000mAh 3S1P 20C
Battery Charger = Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories
Voltage Detector = On Board Lipoly Low Voltage Alarm (2s~4s)
Quadcopter Board = HobbyKing Multi-Rotor Control Board V2.1 (Atmega168PA)
Propellers = 10X6 Propellers (Standard and Counter Rotating) (6pc)
Tucker33 is offline Find More Posts by Tucker33
Old Apr 03, 2012, 05:20 PM
peoples is offline
Find More Posts by peoples
United States, CT, Norwalk
Joined Nov 2009
peoples is offline Find More Posts by peoples
Site Sponsor
Old Apr 03, 2012, 05:43 PM
Tucker33 is offline
Joined Jan 2012
OK, I was told that this motor + Propeller combo was a good mix
Old Apr 04, 2012, 03:32 AM
Tucker33 is offline
Joined Jan 2012
On Hobby King the reckon the DT700 will produce 900g of thrust using upto a 11" prop. Does anyone have any experience with this motor or have any suggestions what I should use?
Also what about the other items I'm looking to purchase do these seem correct?
Old Apr 04, 2012, 04:08 AM
tosjduenfs is offline
Find More Posts by tosjduenfs
Joined Jul 2006
I use the dt750 motors with 10x4.7 props. I have 8 and they all work fine. great power and efficiency. Your list looks fine. you might want to add some wire and some connectors for your batteries. you should use 20 gauge from esc to motor and 14 from battery to escs. You'll also need a prop balancer. Those 10x6 props do not come well balanced you should get 10x4.7 props I use apc. I don't think hk has 10x4.7s. If you look through my other posts you'll see some of builds with the dt750s and some videos of fpv flights.
tosjduenfs is offline Find More Posts by tosjduenfs
Old Apr 04, 2012, 04:22 AM
Tucker33 is offline
Joined Jan 2012
Hmmm, you now have me thinking about going for the DT750 now as the price is the same, what do you think what size battery do you use with these?
Old Apr 04, 2012, 06:37 AM
peoples is offline
Joined Nov 2009
try use these http://quadframe.myshopify.com/colle...s/ipower-2212q
Site Sponsor
Old Apr 04, 2012, 01:24 PM
Tucker33 is offline
Joined Jan 2012
So I think I'm going to get te DT750's now do you think this Lipo will still be powerful enough?
http://www.hobbyking.com/hobbyking/s...idProduct=8851
From my calculations I should get 7 mins of flight from it but I will need to upgrade the current ESC I'm looking at to 20amp
Old Apr 04, 2012, 05:56 PM
Joined Jul 2006
I get about 9 minutes from a 2200mah in hover, I also use that same 3000 ocassionaly and get about 11 min hover and 8 min fpv flight. The 18 amp esc is fine. I actually use the plush 12 amp. The dt750 wont pull more than 13 amps at full throttle with a 10x4.7 and the plush 12 can handle 15amp burst, and I never use full throttle.
Old Apr 06, 2012, 04:40 AM
Tucker33 is offline
Joined Jan 2012
Perfect, than I will stick with that battery and ESC combination, does anyone know which ESC extension cables I should use?
Rant Another Hobby King order gone awry JurassicJet HobbyKing 26 Apr 04, 2012 07:26 AM
Discussion Order processing at Hobby king goldsworthy Chit Chat 1 Apr 01, 2012 08:28 PM
Discussion Hobby King USA order high shipping charges gquiring HobbyKing 10 Mar 29, 2012 02:36 PM
