Old Apr 03, 2012, 02:46 PM
videorov is offline
Find More Posts by videorov
USA, FL, Bradenton
Joined Oct 2007
Using CNC router table to cut out half of fuselage and wings
I wonder how the factory cuts the inside out in the fuselage in the nose.
I wonder if they use the CNC to cut that out too. I guess you could make
a mold for the half to sit down into to hold it still tape it down to that mold.
My CNC would have a vacuum table where I could drill holes through the
mold and then it could it too. Just tape it would be easy way to hold it in the
reverse mold.
Just wonder how the factory does it with these styrofoam planes
like the BlitzRCWorks Sky Surfer . How they build these.
Anyone been to a factory that makes planes like these.
I can see in this model there is a seam down the middle of the fuselage and looks like
it was made in two halfs and then glued together.
videorov is offline Find More Posts by videorov
Old Apr 03, 2012, 03:09 PM
Rocketman1092 is offline
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
It's my impression that most ARF foamies like the Sky Surfer are made in large metal molds that get filled with molten foam. That way, hollow cavities like inside fuselages aren't a problem; there's just a male insert in the mold. Here's a picture I found with a quick Google search for "foam airplane mold".
Rocketman1092 is offline Find More Posts by Rocketman1092
Old Apr 03, 2012, 03:57 PM
Whiskers is offline
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
This will give you an idea of how they do it.
http://www.madehow.com/Volume-1/Expa...oam-EPF.html#b
Actually that article is a bit of a mess. Just scroll down to Molding. The drawing near that shows a schematic layout.
Whiskers is offline Find More Posts by Whiskers
Old Apr 03, 2012, 05:40 PM
vtdiy is offline
Find More Posts by vtdiy
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Yes, besides limited undercut facility, CNC milling takes a long time by comparison, and produces a lot of waste. Only one part can be worked on per mill at a time. With a plane composed of 2 fuselage halves, 2 H stab halves, a wing, and a hatch, a set of molds can be filled all at once compared to each part being cut out on a mill. And several identical molds can be used depending on the production rate needed. Depending on how they are made, molds can be cheaper than multiple CNC mills.
vtdiy is offline Find More Posts by vtdiy
Old Apr 03, 2012, 07:46 PM
videorov is offline
USA, FL, Bradenton
Joined Oct 2007
Interesting process and thanks for the link Whiskers
I wonder if they make the molds with a CNC machine. I wonder if they are
aluminum which would be easy to cut with CNC.
I thinking of setting up a shop to build planes with this process here in America
for a change. Ive been looking at large CNC tables with auto tool changers etc.
Even 3D 5 axis CNC if needed.
I bet there is not a factory in America anymore doing RC products like this
anymore. I sure would be surprised if there are.
It would be my own company no other people to deal with. I would do it my way
I just want to do something diffrent here in America.
Old Apr 04, 2012, 11:27 AM
videorov is offline
USA, FL, Bradenton
Joined Oct 2007
metal molds
I wonder if they are using CNC machines to make the molds or maybe even
stamp the molds out.
If you find anymore information about this process please post or send it to me.
Old Apr 04, 2012, 12:39 PM
vtdiy is offline
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Here's a tool that might help.
Incredible Resource
Old Apr 04, 2012, 05:32 PM
RogueTitan is offline
Find More Posts by RogueTitan
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
Nevermind
RogueTitan is offline Find More Posts by RogueTitan
Old Apr 04, 2012, 05:38 PM
Foam Av8r
RogueTitan's Avatar
Joined Sep 2008
UM, how do you stamp out a mold without machining the stamp first?
heres your sign
Old Apr 04, 2012, 07:18 PM
videorov is offline
USA, FL, Bradenton
Joined Oct 2007
heres your sign
Yea your right. Im sure they must CNC the mold but that mold might be
for the styrofoam beads to go into and if they wanted more molds then
they would have make a mold that could be used in a stamping machine.
Which Im guessing they would just make another mold the CNC way.
They are made with more precision then stamping them out.
Build Log CNC Router Table - Carolina build Merk CAD/CAM 140 Sep 11, 2012 01:32 PM
Discussion Can a router be used to cut out and lighten model parts without a CNC machine? Graeme Marion The Builders Workshop 42 Feb 27, 2012 12:07 PM
Discussion CNC Router? I need help to cut this pieces i made Zombee Multirotor Talk 3 Dec 24, 2011 10:37 AM
Discussion Has anyone done a DIY CNC machine to cut out foam? NeveSSL Foamies (Scratchbuilt) 6 Nov 15, 2011 10:14 PM
Yippee! CNC router fully op. need G-Code to cut some balsa... jlagran Heli The Builders Workshop 8 Dec 12, 2004 11:02 PM
