Old Apr 03, 2012, 11:22 AM
Diz is offline
Diz
Find More Posts by Diz
Diz
Brushless for ThunderTiger/Ace Seamaster
I have a seamaster currently running an OS 46.
I have running gear from a wrecked heli that I'd like to move over:
6s1p Lipo, 6000 mah
CC Phoenix Ice 100 ESC
And a Century 600+ motor (which I assume is not going to work for this).
Seamaster is in the 7lb range. It is I believe limited to an 11" prop. It doesn't need to go fast, but does need good low speed power to get off of the water. I think if there was a reason to go with a larger diameter prop I'd have to raise the pod, which I'd rather not do.
Any motor recommendations? I don't have a brand preference, and am fine spending $100 or more if necessary to get the right fit. Any input appreciated!
Thanks.
Diz is offline Find More Posts by Diz
Old Apr 14, 2012, 01:39 PM
Diz is offline
Diz
Diz
In case anyone else wants to do this, there's a million opinions out there, but little data. Here's what I ended up with:
E-Flite Power 52 Brushless Outrunner Motor, 590Kv
Stuck w/ the original 11x7 prop I had on my .46 nitro engine
Static full power:
10,500 RPM
37 amps
That's w/ the 6s1p 25c lipo, 6000 mah, and CC Phoenix Ice 100.
Feels like it has plenty of power, but haven't tried flying it yet. Still need to mount the battery.
Old Apr 14, 2012, 08:16 PM
bob93447 is offline
Find More Posts by bob93447
United States, CA, South Lake Tahoe
Joined Sep 2006
You might consider going to a 3-blade prop. Lots more thrust for a minimal loss of efficiency.
bob93447 is offline Find More Posts by bob93447
Old Apr 16, 2012, 10:19 AM
Diz is offline
Diz
Diz
I'll give that a shot, thanks!
Question Ace Nautical Commander radio question for the Ace guru's Kmot Dock Talk 56 May 26, 2014 05:04 PM
Discussion 80% Seamaster peso Waterplanes 10 Jun 15, 2012 10:40 AM
Sold Thundertiger ah-1w wishmaster420 Aircraft - Electric - Helis (FS/W) 0 Feb 29, 2012 12:14 AM
Discussion Neptune II (Seamaster) Crash, repair, new look. lupy Waterplanes 7 Dec 29, 2011 08:10 PM
Discussion seamaster modification advise please flybyjohn Waterplanes 8 Nov 03, 2011 11:20 PM
