Adjustable Retract and Door sequencer w/Display -- End point Adjustment?
Against my better judgment I got one of these:
http://europemodels.eu/p_3968_Servo+...ion=%22../%22/ Servo delay for Flaps or Landing gear. The main function of this controller is to slow-down the movement of the servo. It can be used for landing gear or flap of aircraft model, or other applications. Starting position and movement speed can be adjusted. Dimensions: 35 x 12 mm Working voltage: 5 V Time adjust: 1 - 14 s Weight: 3 g It’s of absolutely no value to me! If there was a zero point on speed adjustment it might have worked since in can adjust one end point. But it does not work around the center position – it drives a servo to either end ONLY. And, is of no value with a retract servo for mechanical retracts (i.e. my Mustang) or w/“servoless” retracts (my B-17). I still haven’t found what I really like to have ; does anybody have the instructions for one of these?Adjustable Retract and Door sequencer w/Display: http://www.hobbyking.com/hobbyking/s...w_Display.html This Retract/Under-carriage door control unit offers adjustable delay sequencing between your retracts and servo powered gear doors for both the up and down positions and also end point adjustment for up to 3 servos. Simply plug into the gear channel of your RX, plug your retracts and doors into the unit and set up via 4 buttons on the reverse of the sequencer which also features a large, easy to read LED display. Weight: 11g Input: 1 servo Channel. Output: 3 Channels (retracts and 2 x doors) Dimensions: 57x25x10 Includes Instructions What I really want to do is have something that will allow me to adjust end points of a servo when used with a dumb TX? |
Looks like this might be the ticket: http://www.servocity.com/html/180o_servo_stretcher.html .
| Thread Tools | |
| Discussion End point adjustment for throttle | hone1er | Beginner Training Area (Aircraft-Electric) | 4 | Mar 31, 2012 10:21 AM |
| Discussion Throttle End point adjustment? | hone1er | Radios | 2 | Mar 30, 2012 05:06 PM |
| Discussion dx8 end point adjust | DenverJayhawk | Radios | 12 | Oct 06, 2011 08:54 PM |
| Question End-Point-Adjust vs Dual-Rate | LSF226 | Radios | 6 | Nov 29, 2009 11:17 AM |
| Can one end-point adjust the throttle on a Futaba 8UAF? | temacc | Electric Plane Talk | 6 | Jun 13, 2001 09:21 AM |
