Old Oct 25, 2012, 09:09 AM
The Recursion is offline
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
That looks right now, except obviously the eLogger connects to the OSD
I have a picture/description I think in my log of the filter. basically you wrap the wire in a ferret ring followed by a 1000uF capacitor to get rid of EM interference and power spikes (especially from the ESCs). After that I power my camera/vTX. Seems to work well (no interference that's noticeable).
The Recursion is offline Find More Posts by The Recursion
Old Oct 25, 2012, 09:42 AM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Or if you're lazy you can buy this:
http://www.dpcav.com/xcart/Power-Sup...-L-C-Type.html
Cervanchez is offline Find More Posts by Cervanchez
Old Oct 25, 2012, 09:52 AM
Joined May 2012
Based on the effort he put into making his diagram, he doesn't look like the lazy type
That would work though.
Old Oct 25, 2012, 10:09 AM
Cervanchez's Avatar
Joined Dec 2011
True, I usually like building it myself whenever possible. More rewarding that way
Old Oct 25, 2012, 10:37 PM
Kosmos is offline
Find More Posts by Kosmos
Just Starting..
Joined Oct 2012
I with you on taking the time - the journey is more than half the fun - and I am
all about do-it-yourself - but for 12bux for a swanky cleaner might fit the bill just fine.
My ESC and "stuff" are here but are held hostage by the USPS so I'll do my best to have the pile o goodies before the weekend - who knows I might fly by Sunday....
Thanks again everybody for the suggestions and help.
Kosmos is offline Find More Posts by Kosmos
Old Oct 28, 2012, 08:11 AM
jpsabo is offline
Find More Posts by jpsabo
jpsabo's Avatar
Joined Feb 2011
jpsabo is offline Find More Posts by jpsabo
Old Oct 28, 2012, 03:34 PM
yoadrian is offline
Find More Posts by yoadrian
32 ft/sec^2 sucks
yoadrian's Avatar
United States, GA, Jasper
Joined Nov 2006
Ok so today I tried adding an extra feature to my NAZA controller since I added the GPS. The GPS was wondering a bit but holding it more steady than ATT mode by it self. Then for giggles I flipped the switch to the new Feature, Intelligent Orientation "Home Lock". It starts heading straight to the ground not responding to radio controls. Unfortunately I was kind of low to the ground and so impact came faster than I had time to respond. So now I need 4 new Graupner props and a new arm for my FPV1, and I have no idea what happened. The landing gear saved another arm from getting broken off. The motors seem to be ok. Nice!
yoadrian is offline Find More Posts by yoadrian
Old Oct 28, 2012, 03:37 PM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
scrape is offline Find More Posts by scrape
Old Oct 28, 2012, 04:20 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Yikes...auto crash mode. I don't think I'll enable that one.
Back when I owned an XAircraft controller (before the days of Naza) I toyed with the different heading modes (via the mag sensor). I didn't like them. All they did was confuse the heck out of me so I just left them deactivated. I could see the benefit of, whatever the mode is, pulling the stick back brings the copter back home...no matter the orientation. That would at least get you back to orientation range where you can turn off the function and return to LOS control...but I have RTH or that so maybe I'll never use the mag sensor functions.
Vantasstic is offline Find More Posts by Vantasstic
Old Oct 28, 2012, 04:24 PM
Cervanchez's Avatar
Joined Dec 2011
Were you within 10m of your home point? The manual basically says not to use home lock within that radius.
Old Oct 28, 2012, 11:32 PM
yoadrian is offline
32 ft/sec^2 sucks
yoadrian's Avatar
Joined Nov 2006
Yeah I probably was inside of 10 meters. Need to keep that in mind next time.
Old Oct 29, 2012, 04:44 PM
OICU812 is offline
Find More Posts by OICU812
Joined May 2005
Originally Posted by Kosmos View Post
This is my first quad - very new to ALL this, but I am very excited to get this in the air - still waiting on ESCs, and other things.....
My plan is a HTFPV frame with:
-Eagletree OSD and logger and GPS,
-ImmersionRC 5.8 vTX
-GoPro flight record
-readymaderc - RMRC-540N video for FPV
-Turnigy plush 30A ESC
-3300mah 3S main lipo
-500mah 3S vTX lipo
-28-26A motors (had to cut the shafts)
-DJI NAZA with GPS
-Eagle tree ground station (readymaderc tracking station)
-Fat Shark goggles
Some suggests most welcome on my wiring diagram I know it is not right - little confusing to a newbie. I also got power distribution plate from HT would like ask for some guidance as how best to solder that up? Would I be better off
with a 750mah for video system? Question on GS - how best to wire up the lipo there would like a dual 5000mah setup - is it best to use a regulator there?
I'll be powering the tracking station and servos, 5.8 video receiver, fat sharks, and perhaps a small LCD of some sort - still working on that idea....
One last thing - how best to power the FPV camera?
Draft Wire Diagram
Ground Station under construction:
Cut down the 28-26A motor shafts:
Shaft almost flush with the motor - but there is room with the motor mounts anyway:
Arms are done and Body shafts installed - I CA'd the motor mounts - hope I don't regret that...
In the mean time I am abusing an MQX quad - to brush up on my flight skills and
get myself comfy with the Specktrum DX8.
TIA
Ground station looks awesome my friend!!
OICU812 is offline Find More Posts by OICU812
Old Oct 30, 2012, 06:55 PM
mast3rwurm is offline
Find More Posts by mast3rwurm
Joined Dec 2010
More ppl have problems with the 'yaw'?
Mine flys like s/*hit. I tried al lot of different PID settings but all seems not to work.
Anyway i fly with Arducopter.
mast3rwurm is offline Find More Posts by mast3rwurm
Old Oct 30, 2012, 07:39 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I flew mine with a CC board and a Naza controller. I can't say I had any yaw problems with either. It did like to weather vane in the wind though...but that's probably standard for any flying thing.
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4545 Today 06:50 AM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
