Old Oct 20, 2012, 08:53 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
One question on your diagram. Why do you have the M1-4 outputs going through the ET OSD to the ESC's? I was not aware of any multirotor control available on the ET yet.
Oh and to answer your questions:
The GS battery: You could do the math and add up all the current being drawn by your components and calculate the capacity needed. Or you could wait till you try it and see how much you are consuming, then select accordingly. Or you could just go with the 2 5000mAh, since weight or size are not so much of an issue on the ground. I would think that would be plenty.
Camera: Since you are using a separate battery for the Tx, you can power it straight from that 12V 3S, no filtering should be needed.
Cervanchez is offline Find More Posts by Cervanchez
Old Oct 21, 2012, 03:03 PM
p0st4L is offline
Find More Posts by p0st4L
BUILD.FLY.CRASH.REPEAT.
p0st4L's Avatar
United States, CA, Santa Cruz
Joined Mar 2012
Great thread. Your energy reminds me of when I started in on FPV/Multirotors
For the ground station, when I had a 5.8ghz setup, to power my rX and Fatsharks, I'd run at 1300mah 2s that worked well for all the batteries that I'd have to fly with (2x 2200, 2x 3000, 1x5000) about an hr of total time 'ON')
But, if you're going w/ a monitor, dvr, and other stuff.... the dual 5000 might be a lil more understandable.
Lookin' forward to seeing your beast in the air
p0st4L is offline Find More Posts by p0st4L
Old Oct 22, 2012, 02:56 AM
EarthOrbiter is offline
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
Good build
[QUOTE=Kosmos;23055419]This is my first quad - very new to ALL this, but I am very excited to get this in the air - still waiting on ESCs, and other things.....
My plan is a HTFPV frame with:
-Eagletree OSD and logger and GPS,
-ImmersionRC 5.8 vTX
-GoPro flight record
-readymaderc - RMRC-540N video for FPV
-Turnigy plush 30A ESC
-3300mah 3S main lipo
-500mah 3S vTX lipo
-28-26A motors (had to cut the shafts)
-DJI NAZA with GPS
-Eagle tree ground station (readymaderc tracking station)
-Fat Shark goggles
Cut down the 28-26A motor shafts:
Shaft almost flush with the motor - but there is room with the motor mounts anyway:
Arms are done and Body shafts installed - I CA'd the motor mounts - hope I don't regret that...
Your build looks good.
I also Ca'd the motor mount. Slack there can cause vibration.
I've had some discovery regarding prop adapters.
I just wish all of them were machined accurately.
Many of us balance motors, props, and make a stable frame only to find out
a subtle wiggling prop adapter connection that can make a camera see jello.
EarthOrbiter is offline Find More Posts by EarthOrbiter
Old Oct 22, 2012, 01:45 PM
glmccready is offline
Find More Posts by glmccready
Gary
glmccready's Avatar
United States, MD, Salisbury
Joined Mar 2011
earthorbitor: For future reference you might want to wrap your motors in a plastic bag with only the shaft sticking out. When you cut the shaft the filings are attracted by magnets. Ask me how I know? lol
I now remove the shafts to cut them, but I had an RC timer motor faiI and I took it apart. Metals filings all over the magnets. I "fixed" the others by blowing them out with a stream of air from a compressor.
glmccready is offline Find More Posts by glmccready
Old Oct 22, 2012, 09:55 PM
The Recursion is offline
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
-500mah 3S vTX lipo
-DJI NAZA with GPS
-Fat Shark goggles
Some suggests most welcome on my wiring diagram I know it is not right - little confusing to a newbie. I also got power distribution plate from HT would like ask for some guidance as how best to solder that up? Would I be better off
with a 750mah for video system? Question on GS - how best to wire up the lipo there would like a dual 5000mah setup - is it best to use a regulator there?
I'll be powering the tracking station and servos, 5.8 video receiver, fat sharks, and perhaps a small LCD of some sort - still working on that idea....
One last thing - how best to power the FPV camera?
Draft Wire Diagram
Ground Station under construction:
In the mean time I am abusing an MQX quad - to brush up on my flight skills and
get myself comfy with the Specktrum DX8.
TIA
I don't think you can hook the Naza into the eagle tree like that.
The Recursion is offline Find More Posts by The Recursion
Old Oct 22, 2012, 11:47 PM
Kosmos is offline
Find More Posts by Kosmos
Just Starting..
Joined Oct 2012
Thanks for the tips and updates - keep them coming - I am researching hooking the Naza to the ET. Also was worried about the magnets and metal shavings... bag was a great idea. I have been blowing them out with compressed air - hate to have
one fail on me.
Kosmos is offline Find More Posts by Kosmos
Old Oct 23, 2012, 03:36 PM
robstach is offline
Find More Posts by robstach
United States, PA, Bethlehem
Joined May 2012
one fail on me.
If you get the ET GPS / Naza GPS issue sorted out you'll be a hero. Would love to see a shared GPS stream eliminating the need for two GPS units.
robstach is offline Find More Posts by robstach
Old Oct 23, 2012, 03:41 PM
robstach is offline
Joined May 2012
Oh wait - I didn't notice your M1-M4 connection. If you are using Naza why would you want ET to take over to begin with? Just curious...
I personally treat OSD as a separate component to simplify things - plus, Naza does a pretty good job on all accounts. But - I'm probably missing something
Old Oct 23, 2012, 05:00 PM
Joined May 2012
Your not missing anything. What he is trying to do won't work. I am curious what would happen if you tried though.
Old Oct 23, 2012, 08:23 PM
robstach is offline
Joined May 2012
Well I'm not volunteering.
Hey- did that foam cutting wore ever show up? I sent it forever ago ... I'm windering if an envelope with a wire in it raised any eyebrows.
Old Oct 23, 2012, 09:17 PM
Joined May 2012
Oh $#!+ yeah! It did arrive and I'm planning on using it. The foam that came with my case ended up being pluck foam after all, but in the spring I'll buy some regular foam and carve it out. At least now I have time to figure out how I want to organize things.
Thanks again!
Old Oct 23, 2012, 09:49 PM
robstach is offline
Joined May 2012
Haha! Okay good. I'm glAd it finally made it and I'm not on some watch list !
Hope it works out for you!
Old Oct 25, 2012, 12:05 AM
Kosmos is offline
Just Starting..
Joined Oct 2012
Okay working some more on the diagram - here is what I think is a
correct diagram - at least this will get me in air?
This is my first build and I am having a blast, just can't wait to
get it in the air... updates and suggestions please?
(bummer I have to have 2 GPS.. I hear that!!!)
I also don't think the ET OSD will do 12v for the camera I got so I'll put a Y plug
on the video battery.... What do you all think about hooking the TM1000 battery
monitor to the vTX sub-system to look after the battery levels - or perhaps that doesn't work that way?
Old Oct 25, 2012, 12:24 AM
Joined May 2012
Bzzz
With the Naza as your flight controller the only thing you're using the OSD for is telemetry. You don't need to, nor should you hook anything into the OSD from the receiver (unless you have a spare channel for the menus). That is only if you are using the OSD as your flight controller, which you aren't.
A 3S battery is 12v, so you can use that to power your camera. You should filter the power though.
Take a look at this thread I made: http://www.rcgroups.com/forums/showthread.php?t=1692974
I have a similar setup as you (including the naza/eagle tree). It may help bridge the gap a bit.
Old Oct 25, 2012, 10:00 AM
Kosmos is offline
Just Starting..
Joined Oct 2012
Do I hear a ding ding ding? I think I am on the right page now.
Indeed the ET OSD has NO support for multi-rotor (yet)
Here is rev 3 of the diagram - comments most welcome.
I expect to have the ESC any day. If I was going to use
the main battery for the camera what best to use for a filter?
PS thanks Exploding Fist, and nice write up.
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4463 Feb 12, 2016 03:30 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 01:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 09:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 11:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 12, 2009 12:05 AM
