Old Oct 06, 2012, 05:44 PM
yoadrian is offline
Find More Posts by yoadrian
32 ft/sec^2 sucks
yoadrian's Avatar
United States, GA, Jasper
Joined Nov 2006
I know, not my best performance.
yoadrian is offline Find More Posts by yoadrian
Old Oct 06, 2012, 05:58 PM
Titus Gordon is offline
Find More Posts by Titus Gordon
FPV it is!
Canada, SK
Joined Aug 2012
@ yoadrian, show us some pics! and are you using a seperate camera for fpv? what camera for the high def footage?
I don't have a high def camera to put on mine yet
Titus Gordon is offline Find More Posts by Titus Gordon
Old Oct 06, 2012, 06:37 PM
FPV it is!
Canada, SK
Joined Aug 2012
Did some tests and tuning in my living room today since it's really windy outside, this is my first full test of the fpv gear while hovering. (also my first youtube video!)
watch in 480P for the full effect :P
FPV gear test on HT-FPV frame while hovering (0 min 52 sec)
Old Oct 06, 2012, 06:38 PM
yoadrian is offline
32 ft/sec^2 sucks
yoadrian's Avatar
Joined Nov 2006
Here are a few pics. Just running a gopro to an immersion 600mw TX. Running a 5000mAh pack. Still want to add a GPS to the Naza, and an OSD. Perhaps an EZUHF down the road.
Old Oct 06, 2012, 06:48 PM
FPV it is!
Canada, SK
Joined Aug 2012
Nice and clean!
Old Oct 06, 2012, 10:34 PM
compuatic is offline
Find More Posts by compuatic
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Titus have you had a chance to try the new motors?
compuatic is offline Find More Posts by compuatic
Old Oct 06, 2012, 10:42 PM
FPV it is!
Canada, SK
Joined Aug 2012
yeah I like them alot better than my old ones. Getting 8 minutes with 3300 3S lipos. Hovering at half stick
I balanced my props to the best of my abilities and when holding the frame in one hand while I give throttle it seems pretty smooth with no obvious bad vibrations that I can feel.
That video I posted above is with those motors
Old Oct 07, 2012, 07:37 AM
znbang is offline
Find More Posts by znbang
Joined Dec 2011
This is my first multicopter. It looks simple but took me 3 days LOL.
SunnySky V2216 900KV motors
HobbyWing FlyFun 30A ESC
Skylark Tiny OSD III
DragonLink
LawMate 1.2G 1000mW with case
Align's PU Adhesive Gel
Lots of 3.5mm bullet connectors
znbang is offline Find More Posts by znbang
Old Oct 07, 2012, 08:51 AM
glmccready is offline
Find More Posts by glmccready
Gary
glmccready's Avatar
United States, MD, Salisbury
Joined Mar 2011
znbang: Looks great and top rate! Might want to solder those battery to ESC connectors for reliability, esp. after you work out all the kinks. That was one of the recommendations direct from Tom the "HT man". I've even soldered my ESC to motor connections, on two of my Quads, after a few flights, and I know the motors are rotating the correct way. Makes for more work in a repair, but more reliable flight.
This is not meant, in anyway as a criticisms, but I've had problems with my 3.5mm connectors sometimes and they are hard to pin down.
glmccready is offline Find More Posts by glmccready
Old Oct 08, 2012, 09:37 PM
HansAuf is offline
Find More Posts by HansAuf
Pass me some zip-ties!
HansAuf's Avatar
United States, FL, Gainesville
Joined Nov 2006
znbang, Just to back up what glmccready said above... Those bullet connectors will come loose. Not may, but will, lol. Sound like this may have happened before? Get the quad up and running, motors turning the correct direction, etc. Then see the following (also on a thread on my RCG blog page).
Heat Shrink - Buy a bunch of it and use it. Example: When configuring a multirotor and you get the motors spinning the right direction, take the bullet connectors loose one at a time and slip another piece of heat shrink over them. Reconnect the bullet and then shrink the heat tube down to hold those connectors in place. They wont come apart, but are still easy to get apart if you need to using an xacto or side cutters.
HansAuf is offline Find More Posts by HansAuf
Old Oct 10, 2012, 01:07 PM
theSouthGA is offline
Find More Posts by theSouthGA
KK4LIK
theSouthGA's Avatar
United States, GA, Ocilla
Joined May 2012
Doing some LOS video with the HTFPV
Hey fellas,
I've been doing some LOS GoPro shots for my brother. He had to asked me to take some aerial photos to document his pool being built. I took the liberty to fly around a bit so he also got some video too! The ole' HTFPV has done well. I'm waiting on my 5.8g Predators to come in to do some more FPV. Here are a couple videos!
OH- I was using some turnigy 1050's and the DJI 920's but I recently switched to the T-Motor 900kv (still using 3s), balanced my 10" props, and with the fpv manuals GoPro Pad I'm getting little to no JELLO!
Blue Skys!
This Video was done after replacing the motors and balancing the props
Almost Finished EDIT2 (2 min 12 sec)
This Video was done before motor and prop replacement.
Greg's Pool Day 7 (3 min 11 sec)
theSouthGA is offline Find More Posts by theSouthGA
Old Oct 13, 2012, 02:25 AM
EarthOrbiter is online now
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
Fast build.
[QUOTE=znbang;22934927]This is my first multicopter. It looks simple but took me 3 days LOL.
DragonLink
Hi I noticed also the 1.2 Ghz at 1 watt is close to the GPS. If you have difficulty locking on the GPS it will be because of separation of the VTX antenna to the GPS rcvr. Shutting off the VTX will verify if it occurs.
I've had a great time this week with my first Quad FPV flight. Note that flying into the wind (based on the flags) makes more vibration.
FPVQuadTesting (9 min 27 sec)
EarthOrbiter is online now Find More Posts by EarthOrbiter
Old Oct 13, 2012, 09:26 AM
The Recursion is offline
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
DragonLink
FYI when I had my GPS there it had a horrible time getting/keeping a lock do to the interference from the GoPro/Electronics. You might have better luck, but just be aware of it.
The Recursion is offline Find More Posts by The Recursion
Old Oct 13, 2012, 10:59 AM
Bhuwan is offline
Find More Posts by Bhuwan
United States, MA, Boston
Joined May 2012
Hi everyone. I'd like to tell you a little story. I recently crashed my HT frame and broke two landing gears and one of the motor mounts. I emailed the HT folks and asked for suggestions on different landing gears for beginners and decided the pool noodle would be the best option
I then went ahead and ordered a new front arm (just in case) and a set of 4 motor mounts.
I received the package yesterday and, to my surprise, there was a set of new landing gears. Attached to the package with the Landing gear was a piece of paper and hand drawn smiley
Thanks guys!!
Tom and his wife are great and I am a customer for life. Thanks for reading
Bhuwan is offline Find More Posts by Bhuwan
Old Oct 13, 2012, 11:08 AM
FPV it is!
Canada, SK
Joined Aug 2012
Been having a blast with my first FPV experiences with my HT-FPV frame!
FPV Flight #2 (4 min 24 sec)
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4559 Today 07:00 AM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
