Old Oct 05, 2012, 07:54 PM
HansAuf is offline
Find More Posts by HansAuf
Pass me some zip-ties!
HansAuf's Avatar
United States, FL, Gainesville
Joined Nov 2006
Originally Posted by mike76 View Post
hi
here is my video fpv with a quad
thank you
Good gosh I am so jealous. Where I live it's flat and full o' gators. Fantastic video Mike. Very watchable.
HansAuf is offline Find More Posts by HansAuf
Old Oct 05, 2012, 09:59 PM
Titus Gordon is offline
Find More Posts by Titus Gordon
FPV it is!
Canada, SK
Joined Aug 2012
Some new pictures showing some recent additions,
HT-FPV frame
Crius AIO Pro 1.0 flashed with Megapirate NG 2.7 R4
Crius CN-06 GPS unit
Skywalker Quattro 20Ax4
FrSky D8R-II+
FrSky Telemetry Hub
FrSky FLVS Lipo Voltage Sensor
new 4x NTM Propdrive 28-26 1200 kv motors with 9" gemfans
new 3DR Telemetry Radio
3S batteries
FPV Gear:
ImmersionRC 600 mw 5.8 Ghz Tx w/ Bluebeam Whip antennas
600TVL SONY SUPER HAD CCD D-WDR
Stock Turnigy 9x Radio with FrSky DJT Telemetry module & FrSky FLD-02 Telemetry Screen.
Laptop running APM Planner with 3DR Radio
Titus Gordon is offline Find More Posts by Titus Gordon
Old Oct 05, 2012, 10:15 PM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
HT-FPV frame
FrSky D8R-II+
FrSky Telemetry Hub
FPV Gear:
Nice Titus...you have managed to stuff a ton of electronics onto that frame dude...looking forward to seeing some fluffy vids soon
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Old Oct 05, 2012, 10:17 PM
FPV it is!
Canada, SK
Joined Aug 2012
Thanks! The only problem I have now is that I cannot afford a GoPro... (for awhile)
I'm ready to try some FPV though! I'm a little nervous LOL
Old Oct 05, 2012, 10:38 PM
Joined Apr 2011
Baby steps...
Old Oct 05, 2012, 10:52 PM
FPV it is!
Canada, SK
Joined Aug 2012
Originally Posted by SDSURFnGLIDE View Post
Baby steps...
I still gotta get it dialed in, my yaw tends to drift and it takes some stick to correct it so I don't think I can FPV with it yet.
Old Oct 05, 2012, 10:58 PM
Joined Apr 2011
Yea...the ht-fpv frame does handed some yaw issues...bit I'm sure you will those worked out...you are are flying a different FC than me so i can't help you there
Old Oct 06, 2012, 05:58 AM
RC911 is online now
Find More Posts by RC911
8 bit is more fun
RC911's Avatar
Norway, Troms, Tromsų
Joined Aug 2012
Be aware that those prop spinners may produce bad vibrations. I recommend replacing them with 5mm lock nuts.
RC911 is online now Find More Posts by RC911
Old Oct 06, 2012, 09:22 AM
vic20owner is offline
Find More Posts by vic20owner
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
HT-FPV frame
FrSky D8R-II+
FrSky Telemetry Hub
FPV Gear:
Looks like you are gaining a lot of weight on the tail there with gear, be sure your CG is within the correct range. Slapping a gopro on the front would probably do it
vic20owner is offline Find More Posts by vic20owner
Old Oct 06, 2012, 09:23 AM
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
If you are using the multiwii type controller, it does tend to drift in yaw quite a bit... it needs constant trimming. The Naza though for example has no yaw drift. Each flight controller is different.
One thing to check though, make sure you have no twist in your arms.. if you see one twisted just give it a good firm twist the other way and tighten everything up again.
The only issue you should ever find with yaw which is frame related is that it is slower than a smaller frame, or similar sized frame with larger props. The total weight effects this also. But for video we really want is smooth yaw, not fast yaw. Fast yaw is possible though with the right combination of props and settings. Setup is everything.
HT-FPV OpenPilot CC tuning, LOS flight (2 min 38 sec)
Old Oct 06, 2012, 03:21 PM
FPV it is!
Canada, SK
Joined Aug 2012
Thanks I'll keep an eye on that
Old Oct 06, 2012, 03:23 PM
FPV it is!
Canada, SK
Joined Aug 2012
I'm narrowing down the yaw drift on my HT-FPV, which is alot easier thanks to the 3DR radio... hover for a sec, see what's happening... land, adjust value on laptop and write, hover, test, repeat
Old Oct 06, 2012, 04:27 PM
FPV it is!
Canada, SK
Joined Aug 2012
Ok finally got around to timing the 3300 3S batteries and I get about 8 minutes of hover time. It hovers at half stick.
It's crazy windy outside today, so i'm doing all these hover tests in my living room
Old Oct 06, 2012, 05:19 PM
yoadrian is offline
Find More Posts by yoadrian
32 ft/sec^2 sucks
yoadrian's Avatar
United States, GA, Jasper
Joined Nov 2006
My first real FPV Experience. I think I like it. Not sure yet. Need more practice and also need my bird to be a little more stable I think. Let me know what you think.
Hover Things FPV1 (4 min 57 sec)
yoadrian is offline Find More Posts by yoadrian
Old Oct 06, 2012, 05:34 PM
FPV it is!
Canada, SK
Joined Aug 2012
@ yoadrian, wow that was close with those powerlines!
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4489 May 01, 2016 02:53 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
