Old Sep 29, 2012, 12:20 PM
Bhuwan is offline
Find More Posts by Bhuwan
United States, MA, Boston
Joined May 2012
I'm using the NTM 1200 kV motors with the multiwii FC and I have a few questions. I tried to fly the HT-FPV today and I noticed that once I give the quad enough throttle to hover, it seems to be all over the place:
a) it was tilting to the right; I countered with left trim on the roll axis, and it seems to work a little bit
b) the quad wants to spin in circles (CCW); i added some right trim on the yaw access, and it works a little bit
c) the pitch access seems fine.
I'm having a hard time flying this time because I'm having to trim all the time - am I doing something wrong? my expectation is (was) that the quad would not be all over the place.
Bhuwan is offline Find More Posts by Bhuwan
Old Sep 29, 2012, 12:42 PM
nike25 is offline
Find More Posts by nike25
United States, IN, Schererville
Joined Jan 2004
Witespy 775k vs. Sunnysky 800k?
I`ve been flying my HT-FPV with the Witespy purchased 1050k motors. It flies great but the motors get a little too warm for my liking! I`ve tried just about every prop combo you can imagine but still not what I`m looking for. I`m thinking of going to either the Witespy 775 or the Sunnysky 800`s with 4 cells. Any advise for me? Is there a noticeable difference between these two motors?
Thanks in advance!
nike25 is offline Find More Posts by nike25
Old Oct 02, 2012, 05:28 PM
Bhuwan is offline
Joined May 2012
Surely someone must have advice?
Old Oct 02, 2012, 06:14 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
I suggest providing more info.
ESC's, battery, gains, etc. Have you tried adjusting gains? What flight mode are you flying when this problem occurs? You may also want to try posting on the multiwii thread.
Cervanchez is offline Find More Posts by Cervanchez
Old Oct 02, 2012, 06:22 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Sounds like it's a little loose. You may need to bump up your Roll and Pitch P until it starts to oscillate and then back it down ~10%.
Vantasstic is offline Find More Posts by Vantasstic
Old Oct 02, 2012, 07:24 PM
Bhuwan is offline
Joined May 2012
Thanks for taking the time Here is some additional information:
- 30A HK SimonK flashed ESC's (Thanks timecop)
- 2200 mAh 3S on 8" props (I could try 9" as well)
- Flying in gyro only mode until i gain some skill
I haven't yet adjusted any of the gains - at the moment, I'm trying to understand whether the problem I am seeing is a frame problem (motor, esc, battery, or the frame itself) or whether it's related to the multwii settings.
Hey thanks for your reply. How are you doing? I think I missed it - what sounds loose? the Flight controller? I haven't yet changed any of the gain settings on the FC as I wasn't sure if this was related to the FC or if the hardware needed to be tweaked in some maner.
Old Oct 02, 2012, 07:55 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
By loose I mean it likes to drift around vs trying to correct back to level. Every frame, motor, battery, weight, combination is different. If we had the exact same setups we'd probably end up with different Multiwii settings.
You mentioned you were flying in Gyro mode only until you got more experience. I think you've got this backwards. Accel mode provides more self leveling reaction. Gyro mode doesn't try to correct back to level flight very much...thus is good for fast forward flights and 'stunts'. Accel mode is what you want to be in while learning to fly.
If you're in Accel mode and drifting around you probably want to bump up the 'Level' P gain. Don't do to much at a time though. Maybe only 1.0 up or down until it feels stable without wobbling back and forth.
Pitch, Roll, Yaw P's are adjusted about the same. If the P is to high it'll quickly oscillate back and forth. Increase your P's (one at a time) until you see this oscillation starting to set in, then back it down a little.
All this takes a little time. The default settings should provide you a flying frame, then it's up to you to adjust it in until it feels right to you.
Old Oct 02, 2012, 08:40 PM
Bhuwan is offline
Joined May 2012
Hey! makes total sense! Makes sense what you said about the mode I should be in.
Before I try to get auto level working, do you offer any tips for the yaw drift? Anything that I should look at, hardware wise? The one thing I've noticed is that on power up the frame drifts on the roll, but once I have a little height (> 5 ft), it doesn't go crazy on the roll axis. However, the yaw is another story that is going nuts >
Old Oct 02, 2012, 09:24 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
First question...did you calibrate your ESCs first? This can cause issues with the motors running at different RPMs. For the Multiwii boards I just connect each ESC to the Rx throttle port, turn on the Tx, go full throttle, power up the ESC, wait for the calibration beeps, pull throttle to off, wait for the confirmation beep, disconnect power, and repeat the process with the other motors.
After that then PID adjustments are probably going to be required....one axis at a time. The higher the P the more it will try to 'correct'. To high a P and it'll start to oscillate. The lower the P the less it'll try to correct. To low a P and it'll drift around to much and become difficult to control. You have to find the happy medium for your personal liking. Also, calibrate the ACCELs in the GUI. Do this on a level surface. This will help greatly with level flight when in Level mode.
Old Oct 02, 2012, 11:28 PM
Cervanchez's Avatar
Joined Dec 2011
Usually when my yaw drifts, I increase the I gain. But first calibrate your ESC's and adjust the P term to just below the point of oscillation like Vantassic said.
Old Oct 03, 2012, 09:11 PM
Bhuwan is offline
Joined May 2012
I have calibrated the ESC's - but I decided to do that again. I re-did the trims via the GUI and rechecked all the settings.
I also tightened down the motors a bit more, and tightened the arms down as well It seems to fly better.
I'm going to try and post a video to get feedback as to whether everything looks fine.
Tjhanks for your help!
Old Oct 05, 2012, 03:57 PM
mike76 is offline
Find More Posts by mike76
mike76
TAHITI
Joined May 2008
hi
here is my video fpv with a quad
FPV QUADCOPTER GOPRO HD 2 (3 min 51 sec)
thank you
mike76 is offline Find More Posts by mike76
Old Oct 05, 2012, 05:14 PM
nike25 is offline
Joined Jan 2004
Originally Posted by mike76 View Post
hi
http://www.youtube.com/watch?v=evZfatc6cdc
thank you
Beautiful Video! Great job!
Old Oct 05, 2012, 05:48 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Nicely done. Very enjoyable. Loved the canoe scenes....and that water....BEAUTIFUL!!! Can I come fly with you???
Old Oct 05, 2012, 05:55 PM
The Recursion is offline
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
hi
thank you
Great video. All you need to find now is a good location.
The Recursion is offline Find More Posts by The Recursion
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4517 Jul 12, 2016 01:32 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
