Old Sep 25, 2012, 01:37 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Originally Posted by Exploding Fist View Post
You need a low pass filter with 1.3Ghz. I made the same mistake.
I have a lpf, but do get beeps at closer than the expected range. i ordered some longer antennas for the Frsky rx so I can get the receiving end placed where i want them. Also hoping a booster on the Frsky Tx will help
Cervanchez is offline Find More Posts by Cervanchez
Old Sep 25, 2012, 01:58 PM
The Recursion is offline
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
Yeah I still need to properly test my range as well with my new lpf installed. I was getting beeps fairly early but I attributed that to bad antenna positioning on the RX.
The Recursion is offline Find More Posts by The Recursion
Old Sep 25, 2012, 02:04 PM
Titus Gordon is offline
Find More Posts by Titus Gordon
FPV it is!
Canada, SK
Joined Aug 2012
Are there any special PID tuning options to consider with the HT-FPV frame since it's non-symetrical?
I'm using MPNG
Titus Gordon is offline Find More Posts by Titus Gordon
Old Sep 25, 2012, 04:34 PM
Cervanchez's Avatar
Joined Dec 2011
I asked that a while back, here was Tom's response:
http://www.rcgroups.com/forums/showp...&postcount=799
Old Sep 25, 2012, 04:40 PM
FPV it is!
Canada, SK
Joined Aug 2012
ok good, thanks for that
Old Sep 25, 2012, 06:51 PM
FPV it is!
Canada, SK
Joined Aug 2012
Got another question for anyone using NTM 28-26A motors.
I notice the shaft sticks out the bottom, will that interfere with the aluminum spacer below the motor? Will that spacer have to be removed?
Old Sep 25, 2012, 07:49 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
1ea Dremel
1ea Cutoff wheel
4ea shorter motor shafts
=No more interference
Vantasstic is offline Find More Posts by Vantasstic
Old Sep 25, 2012, 08:30 PM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
I had that problem too.
scrape is offline Find More Posts by scrape
Old Sep 25, 2012, 09:33 PM
FPV it is!
Canada, SK
Joined Aug 2012
I'm not sure what to do now LOL
I have a set of these motors coming to me
Oh well, I'll figure it out.
Old Sep 26, 2012, 08:24 AM
tamron is offline
Find More Posts by tamron
Canada, ON, Barrie
Joined Jan 2009
I just left that spacer out and I've been flying it for months with no issue.
tamron is offline Find More Posts by tamron
Old Sep 26, 2012, 08:31 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
I would just take the spacer out. You could always redrill it slightly offset as well if you want to keep it and move it slightly.
You might also be able to turn the motor mount plate end for end and see if that gives a better clearance as I don't "think" it is centered but I may be wrong, don't have it in front of me to check.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Sep 26, 2012, 08:33 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I'll say it again....
1 Dremel + 1 Cutoff wheel=1 shorter prop shaft (not being used) and no more interference. You don't have to cut off the whole shaft...just ~1/8"+/- to get the clearance. No problems...
Old Sep 27, 2012, 02:39 PM
Diamondback68 is offline
Find More Posts by Diamondback68
Joined Apr 2012
I now have several dozen flights on my HT-FPV and have some comments and modifications I have found helpful. I did a side-by-side with my Witespy 450 and at the risk of heresy, I came to some unusual conclusions.
Hoverthings HT-FPV vs, Witespy 450 Quad Copters - A side-by-side Comparison (8 min 13 sec)
I will cut to the chase on my opinions -- I like the Witespy 450 a lot better. I hardly ever crash mine...any more. For what I do, which is nature photography and I work in a flight restrained vertical environment and within 1000 feet and sometimes over water, the 450 just works better. Sometimes I put an expensive camera aboard the pod and I want it back if something happens so I do not fly them very far. I seldom have a problem with the 450 and it has proved very reliable.
For me - The HT-FPV is a blast to fly and it is very fast, especially if you fly it without a camera. I love to fly FPV with this frame and have many hours on it. Crows fear me! I have a high-end 600 line CCD flight cam and can fly on all but the darkest nights. However I find the frame to be very twitchy in flight and it does not like downwind hard rudder turns which turn them into Lawn Darts. I cannot make it take good video at slow hovering speeds. It does not handle (or I cannot make it handle) slow, smooth changes in direction as well as the 450. It is harder for me to fly in tight places.
I think the best analogy is that my Witespy 450 is like a Ford F-150 pickup truck; does everything, never breaks, cheap to fix, easy to repair, does the job. My Hoverthings HT-FPV is like having a race car in the garage that is fast, complicated, requires frequent repairs, is twitchy to drive hard, and prompts me to try things I have no business doing, usually producing a high speed video ending with a session of lawn darts and fade to black. They are worth every hour of the repair!
Diamondback68 is offline Find More Posts by Diamondback68
Old Sep 27, 2012, 02:44 PM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
The Whitespy 450 and HT-FPV frames were made for different purposes which I think is what you have found. It is really finding the best platform for your needs.
And you do realize the Whitespy and HT-FPV frames are made by the same person right?
So it isn't really heresy :-)
Site Sponsor
Old Sep 29, 2012, 12:05 AM
shdwkeeper is offline
Find More Posts by shdwkeeper
United States, CA, Anaheim
Joined Dec 2011
Same here
shdwkeeper is offline Find More Posts by shdwkeeper
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4517 Jul 12, 2016 01:32 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
