Old Sep 23, 2012, 09:46 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Hey guys
So I was finally just getting my HT-FPV dialed when a bad factory motor solder took me out. Here's a quick video of me messing around before it went down. unfortunately I didn't catch the crash on film.
Frame: HT-FPV
Flight Controller: Naza+gps
Power Distribution: homemade
Batteries: 3300, 4000 mah 3S and 4S
ESC: DJI 30A optos
Motors: DJI 2212
Props: 8-9" various
Rx: Frsky D8RX
Lights: n/a
Camera: sony 540 tvl
Video Tx: 400mW 1300MHz
OSD: Eagle tree
AUW: ~1600g
Playin at the Playground (3 min 37 sec)
Cervanchez is offline Find More Posts by Cervanchez
Old Sep 23, 2012, 09:50 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
That's a bummer. Was the failure from the ESC? I've ready many reports of bad solder joints on the ESC connectors. I have 18A DJI ESCs and haven't suffered that problem (yet). Hope you get it back in the air quickly.
Vantasstic is offline Find More Posts by Vantasstic
Old Sep 23, 2012, 09:55 PM
Cervanchez's Avatar
Joined Dec 2011
no it was the male bullet connector on the DJI motor. That's the second one I've found. First one pulled out when disconnecting a motor from the ESC. I'm kicking myself for not resoldering all of them when I found that first one. I did that now and they all looked horrible.
Old Sep 23, 2012, 10:23 PM
compuatic is offline
Find More Posts by compuatic
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Originally Posted by Titus Gordon View Post
Crius AIO Pro 1.0 flashed with Megapirate NG 2.7 R4
Skywalker Quattro 20Ax4
FrSky D8R-II+
FrSky Telemetry Hub
FrSky FLVS Lipo Voltage Sensor
4x 2212 motors (no idea what brand, they came with the ARF kit I bought)
All motors are spinning the correct direction, and my 3 position switch and my throttle hold switch are programmed for six flight modes (although I have them all set to the default stabilize mode). I just need to balance and install the props, install the GPS module, tidy up some wiring and start test flights!
[/IMG]
Finally someone using the crius aio with this frame. I am in the process of building the same thing. Can you please share your experience so far? Any fpv videos? What settings are you using? Thanks
compuatic is offline Find More Posts by compuatic
Old Sep 23, 2012, 10:26 PM
Titus Gordon is offline
Find More Posts by Titus Gordon
FPV it is!
Canada, SK
Joined Aug 2012
I'm having great success with the Crius AIO with megapirate. This is my first build and my first Quad (the blade mQx doesn't count).
Here's my build so far..
http://www.rcgroups.com/forums/showthread.php?t=1735137
I'm planning on FPV but it's a little ways off, I wan't to make sure every mode is stable.
Hovered successfully for the first time today, I'm currently just trying to get it tuned, it's still a little unstable and twitchy.
Titus Gordon is offline Find More Posts by Titus Gordon
Old Sep 24, 2012, 10:13 PM
RobDawg is offline
Find More Posts by RobDawg
RobDawg's Avatar
United States, ID, Meridian
Joined Sep 2012
Help!!
I need some help with my Quad. Here is a video explaining the problems I am having. I am posting this to see if anyone has any ideas for me. The copter is just flipping over. I am assuming that there is a problem with the FC at this point. I have done the throttle calibration where you put the throttle all the way up, turn the copter on, and then pull the throttle down. Here is my setup:
HT-FPV frame
DJI NAZA Flight Controller
NTM 28-26 1000kv Motors
DJI 30A ESCs
Hoverthings power dist. board
TX/RX Turnigy 9X
Battery: Nano tech 3300 mAh 35-70C
If you have any questions, please let me know. Sorry the audio is not synced up.
http://www.youtube.com/watch?v=AGfU0mHooV8&feature=plcp
RobDawg is offline Find More Posts by RobDawg
Old Sep 24, 2012, 10:31 PM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
HT-FPV frame
DJI 30A ESCs
TX/RX Turnigy 9X
Your Naza is backwards...the motor Ports need to face forward...flip it around
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Old Sep 25, 2012, 08:24 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
No, no, no, no,no. His Naza is installed correctly. It's the frame that's installed 180 out!!!! . FWIW, the Naza also doesn't look very squared on the frame...looks crooked...could just be the camera angle I was seeing though. It sure would help if Naza put a big FRONT/Arrow on the case though...
Doesn't the Naza assistant have something to verify control reaction, i.e. tilt the nose down you see a graphic representation of the nose moving down, etc? Maybe not now that I think of it. Even the free, open source, Multiwii GUI has this feature. Even my, thankful now sold, XAircraft had this feature. Hmmm...seems DJI needs a little catching up on firmware functions...and a Tricopter mix!
Old Sep 25, 2012, 09:10 AM
Joined Apr 2011
Haha...on second look...i think you are right Van....i stand corrected!...but really it does look like the Naza is a little crooked in there....you may want to square it up
A bit and just makes sure the "M" Ports face forward and that you have the motors spinning in tire right direction and you will be good to go
Old Sep 25, 2012, 09:44 AM
glmccready is offline
Find More Posts by glmccready
Gary
glmccready's Avatar
United States, MD, Salisbury
Joined Mar 2011
Rob: 1) Make sure your blades are spinning in the right direction. 2) Make sure your ESC control wires are in the correct slots on the Naza board, ie #1 motor into #1 slot. 3) make sure your aileron and nick wires are not reversed to your Tx. Check rudder wire too. 4) Make sure you are in X mode and not + mode.
Most often get an immediate flip from #2 or 3. Ask how I know....lol
glmccready is offline Find More Posts by glmccready
Old Sep 25, 2012, 09:50 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
I don't believe DJI ESCs can be throttle calibrated so you can probably skip that step.
As others have noted the NAZA looks backwards and crooked.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Sep 25, 2012, 10:24 AM
RobDawg is offline
RobDawg's Avatar
Joined Sep 2012
It works!
Thanks for all the help guys! This Forum is GREAT!!
I did have my NAZA pointing the wrong way, and I noticed that the back left motor was not spinning as fast. I calibrated that ESC, and flipped the NAZA around, and bingo!
Quadcopter works! (0 min 56 sec)
Old Sep 25, 2012, 10:25 AM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Originally Posted by Cervanchez View Post
Hey guys
Frame: HT-FPV
ESC: DJI 30A optos
Motors: DJI 2212
Props: 8-9" various
Rx: Frsky D8RX
Lights: n/a
OSD: Eagle tree
AUW: ~1600g
Are u having any interference with your 1.3ghz VTX and frsky? I could not get over a mile without mine going into fail safe. On 5.8ghz i can get well over 1.5 miles before i get any beeps.
blueprint is offline Find More Posts by blueprint
Old Sep 25, 2012, 10:36 AM
The Recursion is offline
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
You need a low pass filter with 1.3Ghz. I made the same mistake.
The Recursion is offline Find More Posts by The Recursion
Old Sep 25, 2012, 12:58 PM
Joined Apr 2011
http://www.youtube.com/watch?v=J8oMd...ature=youtu.be
hey that's awesome!! See..ask and yee shall receive...honestly its always the simple things that go wrong...small oversights...Mine has always been making sure the motors are spinning the right way and that i have the correct props on the right motors...
but now that it works...have fun!!
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4493 May 19, 2016 02:53 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
