Old Sep 11, 2012, 04:18 PM
MrBen. is offline
Find More Posts by MrBen.
Great Britain
MrBen.'s Avatar
Joined Dec 2008
Im getting 9 mins easily with a 3s 3300mah and sunnysky 980kv motors I have about 30% left in lipos when I land
MrBen. is offline Find More Posts by MrBen.
Old Sep 11, 2012, 04:22 PM
The Recursion is offline
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
Wow. How much do you weigh without batteries (and with)? What size props?
The Recursion is offline Find More Posts by The Recursion
Old Sep 11, 2012, 06:41 PM
vic20owner is offline
Find More Posts by vic20owner
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
Originally Posted by Tron78 View Post
here is short vid of me discovering the joy of DJI stock motors with eprops on 4s! I really like this frame... it didn't work for me on 3s.. annoying yaw in wind and ff flight.
http://www.youtube.com/watch?v=POxJ8mEqhwA
cheers,
Tron
Nice work! Mind if I link to your video on the hoverthings site? Which flight controller are you flying there? The flips scream CC, but desc says Naza! Very nice!
vic20owner is offline Find More Posts by vic20owner
Old Sep 11, 2012, 07:11 PM
Judar is offline
Find More Posts by Judar
Judar's Avatar
Australia, VIC
Joined Sep 2011
So i have been trying out a multiiwii FC on the HT-FPV frame.
Using simonk flashed esc, 1000kv ntms and 10" props
I have got it flying pretty good, but im strange getting wobbles from time to time.
Im not 100% happy with getting the PIDs dialed in.
Being an A-symmetrical fame does anyone have any advise on tuning the PIDs for roll/pitch so that i get it locked in?
Judar is offline Find More Posts by Judar
Old Sep 11, 2012, 08:11 PM
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
Which brand of multiwii? Some of the cheap china versions need a lot of filtering to work correctly... if it is a quadrino, make sure it is the latest.. the one before was recalled and had the wobble you describe. Also which firmware are you running? The latest?
The multiwii can be tough to tune at times.
Old Sep 11, 2012, 08:22 PM
Judar is offline
Judar's Avatar
Australia, VIC
Joined Sep 2011
its a Crius MultiWii Standard Edition Flight Controller V1.0 SE
I have updated it from 2.0 to 2.1 through arduino
and the only things i have changed in the sketch are...
#define QUADX
#define MINTHROTTLE 1064 // special ESC (simonk)
and
#define CRIUS_SE // Crius MultiWii SE
Old Sep 11, 2012, 08:24 PM
Judar is offline
Judar's Avatar
Australia, VIC
Joined Sep 2011
this afternoon ill see if i can record some flight so i can show you what its doing.
Old Sep 12, 2012, 12:34 AM
EarthOrbiter is offline
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
Hoverthings beggining build
Got the frame in today. The setup as shown without the powertrain has a perfect CG. The video battery will be smaller and a camera added. So far so good. The Gens ace is a 60 to 120 c 3s battery I drain it down to 10 volts with no puffing. Don't try that with a lower c battery. I feel deep emotions, sad, and happy tearing apart the gear from my old experimental frame.
PS; The last frame weigh up was 1641 g with gopro.
Total flight time max was 12 min before the Naza would drop it at second level.
Right now it weighs 1140g I think the flight time will be similar.
EarthOrbiter is offline Find More Posts by EarthOrbiter
Old Sep 12, 2012, 04:15 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
For those in Canada we have more HT-FPV in stock as of yesterday (thanks Tom).
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Sep 12, 2012, 12:11 PM
tamron is offline
Find More Posts by tamron
Canada, ON, Barrie
Joined Jan 2009
Go Pro only?
Hi guys
Just wondering if anyone has mounted a different camera on this frame. It looks like the Go Pro is the holy grail here, but I was curious if anyone had tried and how it's worked out for them.
JJ
tamron is offline Find More Posts by tamron
Old Sep 12, 2012, 12:31 PM
Joined May 2012
I wouldn't call the GoPro a holy grail, but more of the default. If the GoPro didn't poop EM interference everywhere AND worked well in lower light, I'd consider that title.
Old Sep 12, 2012, 01:45 PM
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
Hmmm I haven't had any problems with EM with my gopro... but low light yes. But the new gopro resolves that problem.
Maybe the noise problem is from powering the go pro from the flight battery... and it's actually line noise? I use the the gopro internal battery and a separate battery for video tx. Have had no problems at all.
Old Sep 12, 2012, 01:48 PM
nike25 is offline
Find More Posts by nike25
United States, IN, Schererville
Joined Jan 2004
The interference issue seems to be with the Naza GPS. Haven`t heard of it interfering with other FC`s
nike25 is offline Find More Posts by nike25
Old Sep 12, 2012, 03:24 PM
Joined May 2012
Correct, the Naza GPS near the GoPro (Hero 2) causes signal degradation. To be fair, other components do this as well, as the Naza GPS appears to be extremely sensitive to EM interference. Someone posted a youtube video with the same problem happening with it powered with the GoPro internal battery and no video out connections, otherwise that'd be my guess to Vic.
Moving the GPS to an arm and putting 3 (yes 3) ferrite rings on the wire seems to have resolved the issue. Before I had it right behind/above the GoPro, which is where the interference is the highest (someone with a spectrometer measured it).
Old Sep 12, 2012, 04:46 PM
compuatic is online now
Find More Posts by compuatic
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Guys i need some help.
I'm about ready to buy all the components to build a HT-FPV. This will be a traditional FPV setup with a gopro and fpv camera in the front. No aerobatics or sport flying. 5.8ghz video gear. I would like some advise on the motor / battery / prop setup.
Currently planning on buying the Sunny Sky 2212 980kv motors since they seem to be a popular quality motor. Please suggest a battery(how many S and what size) and props. Should i go with the 20A ESC or 30A version of SimonK flashed from rctimer? Thanks for the help
compuatic is online now Find More Posts by compuatic
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4498 Jun 07, 2016 12:20 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
