Old Aug 05, 2012, 08:24 AM
trinco is offline
Find More Posts by trinco
☢ ɴᴏᴏʙ ☢
trinco's Avatar
Malaysia
Joined Mar 2012
custom made HT-FPV frame using 1.5mm 3k carbon fiber sheets
trinco is offline Find More Posts by trinco
Old Aug 05, 2012, 08:53 AM
The Recursion is online now
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
Isn't Carbon fibre more breakable and G10, and an electric conductor?
The Recursion is online now Find More Posts by The Recursion
Old Aug 05, 2012, 10:43 AM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I do believe CF is more rigid. Which can mean more breakable....the willow bends in the wind while the mighty oak breaks. As for conductivity...probably not very much so...if at all. It does look cool and lots of frames use CF...and cost more.
Vantasstic is offline Find More Posts by Vantasstic
Old Aug 05, 2012, 12:01 PM
robstach is offline
Find More Posts by robstach
United States, PA, Bethlehem
Joined May 2012
Originally Posted by Vantasstic View Post
Bean field. We don't need to stink'n bean field. Can you help me find my HT-FPV frame? I know I set it down somewhere...but now I've LOST it!!!!!
Nope, I found it...right under the pile of junk. Hey...aren't you supposed to be on vacation??????
This IS vacation. I'm snuggle up with a vodka tonic while the wife and kid are at the beach. It's 1pm. I dont do well in the sun so I'm back at the beach house wishing the freakin' wind would die down.
Maybe it is nap time!
robstach is offline Find More Posts by robstach
Old Aug 05, 2012, 12:03 PM
robstach is offline
Joined May 2012
Hey EF, did that foam cutting wire ever make it to you? How's that project coming along?
Old Aug 05, 2012, 12:09 PM
Joined May 2012
Not yet, but I did receive the case. Unfortunetly it's pluckable foam unlike the 'foam insert' advertised on the sale. I'll probably look at buying an insertable foam insert for it shortly as I much prefer the regular foam to pluckable foam. I may use the pluck to help lay everything out first though.
Old Aug 05, 2012, 12:28 PM
robstach is offline
Joined May 2012
Jeez! I sent that out like a century ago. I did wonder if some eyebrows would raise if they saw a wire in an envelope ...
Hope but gets there soon.
Yeah. The pluck able foam will work but it's not quite as custom or as tight of a fit.
Best bet when you do get non-pluck is to trace your pieces with chalk and cut inside the lines. It will be super snug!
Old Aug 05, 2012, 01:53 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I did some reconfiguring on my HT-FPV frame the other day. I installed 750kv NTM motors and a set of Simonk flashed ESCs. On 4S with 9" props it just didn't feel it had the power....plus I started getting some bad vibs in one motor at higher throttle (probably a prop needing better balance). I just stuck my DJI 930kv motors back in and flew it today with 9x5x3 props (vs the 8" 2-blade ones). I'll have to look at my data recorder to see what they were doing in flight. They didn't feel to bad, but needed a little over 1/2 throttle to hover. Looks like it's time for more motor/prop experimentation. I wonder how the 750s would be with 10" 3-blades...
Old Aug 05, 2012, 08:28 PM
imagebuff is offline
Find More Posts by imagebuff
imagebuff's Avatar
United States, TX, Tomball
Joined Jan 2011
I've got my HT-FPV maidened today.. and WOW! What an absolute thrill when my HT-FPV / NAZA combo leapt into the air with perfect stability the very first time! Truly fantastic and a leap ahead of my old multiwii tricopter. The DT-750's are running great on 4S fully loaded with gopro.
The ONLY problem I have is that two of the arms are still uneven / won't lay flat on a table. I've tried the recommendations here regarding tightening of screws at different points etc but I get the exact same results no matter how I tighten the screws. Unfortunately it appears to be causing the two motors on those arms to get quite a bit hotter than the other two.
Any ideas?
Chris
imagebuff is offline Find More Posts by imagebuff
Old Aug 05, 2012, 09:22 PM
jpsabo is offline
Find More Posts by jpsabo
jpsabo's Avatar
Joined Feb 2011
I 've had really good luck with the GemFan carbon-filled 11x4.7's with 4S and Avroto motors. 3S just didn't do it, and I even tried 900 Kv RCTiger motors as well. Maybe try the 750's again but with 10 and 11 inch props?
http://www.rcgroups.com/forums/showp...&postcount=570
-John-
jpsabo is offline Find More Posts by jpsabo
Old Aug 05, 2012, 09:42 PM
Joined May 2012
My 1000mw video TX just arrived, and it's HUGE. It doesn't fit in the tail, and weighs about 130gs. I've removed the case, and it fits now (and is 60g less weight), but how important is the case for heat dissipation since it's obviously acting as a heat sink? The bottom of the board has a metal heatsink attached to it. I was thinking of flipping it upside down, and if required, adding a small computer heat sink directly on that spot since that was the only part even touching the case.
Thoughts?
Old Aug 05, 2012, 09:59 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
-John-
Thanks. I think I got some 10" carbon filled Gemfans...I think. I might give them a try on the 750s. I do have 10" 3-bladers so I can try something in the 10" size with it.
I pulled down my in-flight data tonight. I'm averaging ~15A-18A (total) on the DJI 930kv motors with 9x5x3 props...so about <4.5A per motor. I added an LED driver to the frame. Now I need to add some LEDs so I can have blinking lights!!!!
Old Aug 05, 2012, 10:00 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Thoughts?
You'd be best to have it mounted so it gets plenty of air to dissipate the heat. I use a 300mW VTx on my frame mounted up front, just behind the GoPro. You really don't need that much power for a quad...they can't fly that far before they run out of battery.
Muddie is offline
Find More Posts by Muddie
A Snickering Hound
Muddie's Avatar
United States, SC, Myrtle Beach
Joined Jan 2012
Any ideas?
Chris
Similar issue here too. No matter what I've tried I get that same "seesaw" effect which, in my experimentation, causes the motors on the affected arms to run hotter.
I'm just not totally comfortable flying this frame until I can get this figured out.
Muddie is offline Find More Posts by Muddie
Old Aug 05, 2012, 10:55 PM
robstach is offline
Joined May 2012
I'm stil not sure how I did it but here's when my see saw went away:
I had 3 arms tightened and had left the left rear arm loose but rotated on its side within the frame. I then twisted it into place with the deck screws fairly tight. Once it snapped into place my seesaw was gone. It was strange.
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4499 Yesterday 08:54 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
