Old Jul 31, 2012, 10:18 PM
Banana Furikake is offline
Find More Posts by Banana Furikake
United States, OR, Keizer
Joined Jul 2012
Originally Posted by Banana Furikake View Post
I'll play with some low level flight to see if it may be a motor issue. Thanks!
Flew it for 10 minutes straight with no issues. Left it in GPS mode and let it hover in pretty strong winds.
Oh well. Thanks for all the suggestions. I'll keep working through it and see if it crops up again.
Banana Furikake is offline Find More Posts by Banana Furikake
Old Jul 31, 2012, 11:11 PM
KC10Chief is offline
Find More Posts by KC10Chief
United States, OK, Oklahoma City
Joined Dec 2002
Pull up on the motors and make sure that the little C-clip is on the bottom. My first guess would be a motor problem. I think Tom has it right. One motor isn't able to spin any faster for some reason and the other three are holding their RPM to compensate. I'm going to guess that it's your front, left motor. I suppose it could be an ESC issue of some sort but I'm guessing it's your motor.
KC10Chief is offline Find More Posts by KC10Chief
Old Jul 31, 2012, 11:23 PM
Joined Jul 2012
got it. will try tonight. thank you!
Old Aug 01, 2012, 09:29 AM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Good point. Also make sure there IS some play in the motor bell. It should pull up a little. If it's to tight it will bind as things heat up and expand.
Vantasstic is offline Find More Posts by Vantasstic
Old Aug 01, 2012, 09:58 AM
vic20owner is online now
Find More Posts by vic20owner
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
Hey guys- need some help. I took my HT-FPV out today and the thing cratered. I had transferred everything from my Witespy and put it in the HT-FPV. Unit had 980kv motors and upgraded ESC's- running 9x4.7s. (Also has the DJI Naza with GPS). The only thing I changed was to change to a 5000mah 3S battery (from 2200 3S). The battery is connected by a bullet connector to a XT-60 via an adapter. COG was in the right place, all props balanced, GPS calibrated and flashing green. I had the unit in ATTI mode and was pretty high (I had done some lower level testing and it was running aok). I reached a certain altitude and it wouldn't go any higher- I then maxed the stick- and it sat and wouldn't climb. Suddenly the quad lurched to the side and went down. I was hoping someone might be able to tell what's up by the engine noise on the video.
I also checked the battery when I got home and it had plenty of power.
http://vimeo.com/46718006
Thanks in advance!
Ok I have another question: Which receiver are you using, and does it have a satellite? What are the failsafe stick positions programmed to?
vic20owner is online now Find More Posts by vic20owner
Old Aug 01, 2012, 12:11 PM
Estuardon is offline
Find More Posts by Estuardon
United States, FL, Miami-Dade
Joined Jan 2010
Originally Posted by huskerfreak View Post
I have a few questions...
I just received my FPV air frame and I plan on using my electronics out my Whitespy 450. Am I going to be under powered? I plan on just using my goprpo for right now. I am waiting on the update on the fpv back pack to stream live.
Another question is why is everyone using both a gopro as well as a separate fpv cam? Does the gopro not record when using the video out on it? I suppose I could look into it myself as I have one. I was just looking for a quick answer.
Finally I am using the quadrino board does anyone have a good pic of it mounted on this air frame. I went through quite a few pages and did not see one.
Jamee
In my opinion you won't be underpowered but your flight time will be less, regarding update of Gopro wifi bacpac, I have been waiting for the release and just gave up, they promised things that are not true, and you will not be fpving through a wifi stream as they led us to believe, the remote will work, the wifi streaming is only for transfering video while you have wifi but not live stream, it is way to fat and heavy for fpv(wifi bacpac) invest in a transmitter..regarding, I use it for fpv but you must remember to charge it, the camera use the power from you batteries so you don't have to worry about, did I charge my camera? Regarding quadrino, I would say get a franken quad case for it if quadrino works for you to protect it and mount it easier, but I would go with the naza controller especially if your goal is fpv
Estuardon is offline Find More Posts by Estuardon
Old Aug 01, 2012, 12:27 PM
Joined Jan 2010
Thanks in advance!
Definitely not the battery! As you can hear the motors still going while your banking left during the descent, i am assuming that it has to do with the transmitter/receiver, which one are you using? It appeared that your receiver was accepting commands and then it stopped receiving command until you were llike 20 ft above ground when it received your transmitter input command and pulled right. My best guess is that your transmitter/receive jumped, glitched, maybe due how hot it was,or some kind of interferrence, looks like a hot day. Chalk it up as undetermined pending further incidence..lol if it happens again the you should invest In a data logger. Personally I'm starting to think of having my wife film my quad as I fly to get a different point of view, since sooner or later a crash will happen. You never know maybe a bird dinged it
Old Aug 01, 2012, 12:42 PM
robstach is offline
Find More Posts by robstach
United States, PA, Bethlehem
Joined May 2012
Not to mention - the best I've seen from a wifi backpack is .2 miles (1k feet or so). Not sure if that's what you're looking to fly but it's rather close in terms of range.
robstach is offline Find More Posts by robstach
Old Aug 01, 2012, 03:01 PM
arctyler is online now
Find More Posts by arctyler
Joined Jul 2012
if anyone is selling their ht-fpv pm me! looking to get one
arctyler is online now Find More Posts by arctyler
Old Aug 01, 2012, 04:19 PM
robstach is offline
Joined May 2012
It's Alive!
Well, I received my new motors and props today. Just in time for my weekend exodus for vacation!
Installed T-Motor MT2208-18 11Kv motors and Gemfan 10" props. What a difference!!!!
My HT-FPV wants to fly now! It's no "rocket" on the verticals but it lifts off at the right level of power, holds wicked steady with the Naza, and was a true joy to see flying the way it was meant to be.
Props still need to be balanced but I couldn't resist running a pack through it just to see how she would perform. Life is good and vacation will be even better now that my FPV rig is up and running!
I need to play with gains a bit as a quick yaw will induce some wobble but it's not a concern.
Anyway - if you're thinking about the t-motors I say go for it, they're really nice. I'm not sure I was in love with the Graup E-Props but they sit on my F450 now and I do seem to get longer flight times... I think I'm sticking with Gemfan.
Anyway - that's my update. Finally where I wanted it!
Old Aug 01, 2012, 05:24 PM
robstach is offline
Joined May 2012
Update
Got another pack in .. motors were pretty hot after landing. Need to look into this. ESCs are cool to the touch , so that's good at least. Maybe I need 8 or 9 inch props? Thoughts?
Also - not sure if anything has changed since the seesaw fix with the frame or I haven't balanced the props well enough but I get some pretty annoying vibe via the gopro.
Back to tweaking but that's part of the hobby ......
Old Aug 01, 2012, 05:45 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
I'd go with the 8" or 9" props on those motors, they are fairly small and higher kv for 10"
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Aug 01, 2012, 06:31 PM
robstach is offline
Joined May 2012
Yep - kind of what I was expecting. Needed someone to kick me in the right direction ... thanks! Appreciate your input!
Old Aug 01, 2012, 06:35 PM
robstach is offline
Joined May 2012
Vibration Update
Switched back to the E-Props and all (and I mean all) vibration is gone.
I balanced the Gems pretty well but I'm not confident in their prop adapter. I'm thinking that it's not exactly doing the job. The props needed quite a bit of help to get into balance.
Video to follow once I get this pack charged
Old Aug 01, 2012, 07:23 PM
sbmon is offline
Find More Posts by sbmon
Joined Aug 2004
Thanks in advance!
Judging from the audible increase in rpm followed by what looked to be the right front motor power dropping out could it possibly be?
1. The prop adapter came loose (if it's a the collet style).
2. Motor shaft may have come loose inside the endbell housing.
Let us know what you find.
shawn
sbmon is offline Find More Posts by sbmon
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4485 Apr 22, 2016 08:34 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
