Old Jul 27, 2012, 03:28 PM
Casey_S is offline
Find More Posts by Casey_S
Casey_S's Avatar
Joined Mar 2011
Originally Posted by Vantasstic View Post
My guess would be you had a solder blob that shorted the positive and negative wire pads. As for repairs, unsolder the positive lead from the current pad and solder it to one of the empty + pads on the inner part of the board. If the original copper pad has lifted from the board I'd cut it out and remove it so it doesn't run the possibility of shorting against another negative pad. So is it fixable, yes, by relocating the wire to a different + pad.
Easy enough, thanks. Just to be sure, so I don't **** anything up more than it is, the - wire can stay where it is?
Originally Posted by Keddy View Post
Also, something does quite look right here. Looks like solder went under the paint and got really close, this may have arced.
-picture-
That's not solder, that's just light reflecting off the paint.
Casey_S is offline Find More Posts by Casey_S
Old Jul 27, 2012, 03:40 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
That's hard to answer by looking at your picture. If your battery pad is firmly attached to the board still then it might be fine to leave where is. If it's even a little loose/lifted then I'd relocate the wire to another + pad.
Do you have an ohm meter? If so, touch the leads between any two + and - pads. If you have ~0 ohms then you have a direct short somewhere in the board. If you are reading in the Mohm range then you should be good.
Last thing...I don't like exposed pads like this. If anything conductive gets on them you're looking for a serious short to happen. I put hot glue over my pads (used or unused) to insulate them. The hot glue will peel up pretty easy if you need to resolder/add a wire.
Vantasstic is offline Find More Posts by Vantasstic
Old Jul 27, 2012, 03:49 PM
Casey_S is offline
Casey_S's Avatar
Joined Mar 2011
I meant the negative wire. The positive sure can't stay where it is.
Nope, no ohm meter.
I don't have any hot glue at the moment but electrical tape should do the job too I imagine?
Old Jul 27, 2012, 06:43 PM
robstach is offline
Find More Posts by robstach
United States, PA, Bethlehem
Joined May 2012
Hey guys - just got my HT-FPV off the ground (kinda) for the first time. Is yours LOUD as all hell?
I have graup e-props on mine along with some T-Motor 2216 900kvs. Haven't tried swapping out the props yet but this thing sounds like a chainsaw. It's almost intimidating!
Noticed that the rear arms are kind of flexy too - front seems better. Anybody else?
robstach is offline Find More Posts by robstach
Old Jul 27, 2012, 09:09 PM
AlanFlorida is offline
Find More Posts by AlanFlorida
AlanFlorida's Avatar
USA, FL, Palm Harbor
Joined Jul 2004
Very strange...I am not sure what would cause it to be loud. I have had mine flying for quite some time and love it.
I am sure you will track down the gremlin. Best of luck!
AlanFlorida is offline Find More Posts by AlanFlorida
Old Jul 27, 2012, 09:22 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Oh, okay. That makes sense then. Sure it can stay in place if the pad is in good shape.
Nope, no ohm meter.
Then go get one. A cheap $10 one is better than nothing. A simple mutli-meter with Volts, Ohms, and Continuity (with tone) is all you need. I got a nice big one from Harbor Freight...if you have them in your location. http://www.harborfreight.com/ac-dc-d...ter-37772.html . You don't have to have one with the audible continuity...but it makes it easier when testing wires and such as you can listen for continuity vs having to look a the meter display.
Electrical tape will work in a pinch. It will leave tape residue over time which would just turn into a mess to clean up.
Old Jul 28, 2012, 10:16 AM
Joined Jul 2004
I still do not have an OSD on my HT-FPV, just camera, ReplayXD camera, Video TX, etc..
Do most of you HT-FPV friends run an OSD?
Thank you,
Alan
Old Jul 28, 2012, 11:11 AM
Estuardon is offline
Find More Posts by Estuardon
United States, FL, Miami-Dade
Joined Jan 2010
When I first started I had put my props incorrectly and it sounded 3 times louder as the trust was pushing upwards on two motors, so I was giving it more throttle to take off, it took off at 80% but it sounded just like a chainsaw.. Recheck your props, their rotation and look for bends, tears or small cracks..
Estuardon is offline Find More Posts by Estuardon
Old Jul 28, 2012, 11:18 AM
Joined Jan 2010
Thank you,
Alan
I don't use an osd yet because of budget restrains (wife ) but i would say that it depends on the type of flying that you plan on doing.. If you fly your quad less than 200 ft and you stay with good visual range then I would tell you that it is not necessary. But if you fly in places whee you can get disoriented like a desert or a big grassy place where there are no good landmarks, the return to home feature is priceless.. Also depends on your goggles, I would say the fat shark dominators are great for seeing the osd outputs but if you have the base googles it may cut off or not look as good, I'm saving for the eagle tree package @ hobbyking.
Old Jul 28, 2012, 11:48 AM
robstach is offline
Joined May 2012
You are correct.. I initially had one motor spinning the wrong way. Fixed that and she's quiet until take off. I think the "buzz" is vibration.
Balanced the blades today - one was WAY out of balance. So.. hoping that will help.
Side note: completely jacked up my gopro lens trying to get a motor off. I wasn't thinking and placed the frame nose down on my bench completely forgetting that a) I had my gopro attached and b) I didn't have a lens protector on.
So annoyed with myself. So - looks like I'll be ordering a replacement lens tonight. Grr......
Old Jul 28, 2012, 01:01 PM
yoadrian is offline
Find More Posts by yoadrian
32 ft/sec^2 sucks
yoadrian's Avatar
United States, GA, Jasper
Joined Nov 2006
[QUOTE=robstach;22289265]You are correct.. I initially had one motor spinning the wrong way. Fixed that and she's quiet until take off. I think the "buzz" is vibration.
Something else that will help with vibrations and a tighter mounting solution for your motors.
yoadrian is offline Find More Posts by yoadrian
Old Jul 28, 2012, 02:58 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Thank you,
Alan
Yep. You can get a very basic OSD (voltage x2, and time) from the HK Simple OSD. Just tap it into one or two of your batteries, connect it's vid out anywhere to your vid line (between camera out and VTx in). Calibrate the voltages, set up the display locations you prefer. Done. It isn't fancy, but will monitor your battery voltage. Sample video of mine here:
Untitled (0 min 39 sec)
. Cost around $15 or so.
For real OSD I use Dragon OSD. It provide a lot more information, direction home, etc.
Old Jul 28, 2012, 03:56 PM
robstach is offline
Joined May 2012
Got her airborne but I definitely need to switch to 4s if I keep these t-motor 900kv .... wayyy underpowered on 3s.
Still need to dial in the Naza but that won't happen until I get everything else sorted.
Liking the frame but wish the arms weren't as flexy. Also noticed that one of my legs doesn't sit as flat as the other 3. Rebuilt it twice and it didn't help. Not cool...
Anyway - most of my vibe issues are sorted. My video is pretty darn stable. No complaints there.
Looking forward to tweaking it and getting things straightened out!
Old Jul 28, 2012, 04:50 PM
Joined Jul 2004
Sounds like you are making great progress!! Can you post a few pictures of your machine?
Best,
alan
Old Jul 28, 2012, 05:33 PM
robstach is offline
Joined May 2012
Best,
alan
Progress is slow but that's by my own hand. I rushed through some things and didn't do my homework .... BUT, there's an end in sight! Been meaning to post pictures .. here they are. Still needs some tidying up but it's getting there.
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4517 Jul 12, 2016 01:32 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
