Old Jul 26, 2012, 10:11 PM
robstach is offline
Find More Posts by robstach
United States, PA, Bethlehem
Joined May 2012
Originally Posted by yoadrian View Post
Looks like a stick of C4
Maybe it will be if that thing ever decodes to puff up? Looks cool though.
Hmmm... Wonder if I need camo tape now!
robstach is offline Find More Posts by robstach
Old Jul 27, 2012, 01:08 AM
Casey_S is offline
Find More Posts by Casey_S
Casey_S's Avatar
Joined Mar 2011
The power distribution board on my HTFPV just shorted
I plugged my battery in for the first time and I see a spark fly out from the frame and I smell something burning. Freaked, quickly unplugged the battery, and took the frame apart to expose the power distro board and it looks like it shorted in the connection between the positive battery wire and the board. The board seems to be visibly singed there. What're the odds that the rest of the components are toast?
Casey_S is offline Find More Posts by Casey_S
Old Jul 27, 2012, 08:06 AM
tamron is offline
Find More Posts by tamron
Canada, ON, Barrie
Joined Jan 2009
oops..wrong thread, sorry
tamron is offline Find More Posts by tamron
Old Jul 27, 2012, 08:31 AM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Electricty follows the least path of resistance. The majority of your juice was flowing through the short, not the peripheral electronics. Shorts are hard on batteries...even if for just a split second. Everything else that isn't directly between the battery and power distribution board should be fine.
Vantasstic is offline Find More Posts by Vantasstic
Old Jul 27, 2012, 10:17 AM
Quadrinus is offline
Find More Posts by Quadrinus
Joined Jul 2012
i have this frame and it is flying flawlessly because of the 2 alu bars that i had tie wrapped to the frame.
if i remove this 2 alu bars, the quad is yawing randomly to the right or to the left and the whole frame is vibrating.
i don't know if i did something wrong...
what do you think?
Quadrinus is offline Find More Posts by Quadrinus
Old Jul 27, 2012, 10:41 AM
cquian is online now
Find More Posts by cquian
USA, TX, The Colony
Joined Dec 2005
The HT FPV frame is not what you have pictured. Yours looks like the VC-450 frame. On my VC-450, I have never had a vibration issue or any other odd flying characteristic. The VC-450 is like one of the best, most stable frames out there.
Make sure all your bolts are tight and that you don't have any hairline cracks somewhere.
cquian is online now Find More Posts by cquian
Old Jul 27, 2012, 01:14 PM
SDSURFnGLIDE is online now
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
just purchased my FPV gear this morning...will post pics of ht-fpv when all is set up...
SDSURFnGLIDE is online now Find More Posts by SDSURFnGLIDE
Old Jul 27, 2012, 01:19 PM
Casey_S is offline
Casey_S's Avatar
Joined Mar 2011
Good to know. Battery's fine, tested it. Knowing how volatile lipos are though I was afraid I'd have an explosive situation on my hands.
Took another look at the board in the daylight. It looks like the copper connection to the positive battery wire and the rest of the board "popped". Is this something that I can fix with a bit of solder?
Old Jul 27, 2012, 02:37 PM
Keddy is offline
Find More Posts by Keddy
Canada, ON, St. Catharines
Joined Jul 2012
I would figure out why it happened in the first place. It would take a lot of current to do this. Something shorted and the copper acted like a fuse.
Keddy is offline Find More Posts by Keddy
Old Jul 27, 2012, 02:38 PM
Keddy is offline
Joined Jul 2012
Also, those battery lead solders look poor, as well as the one at the bottom right.
Old Jul 27, 2012, 02:52 PM
Casey_S is offline
Casey_S's Avatar
Joined Mar 2011
My guess would be a poor solder between the XT60 plug and positive wire. I'm going to open the patient up for exploratory surgery, but before I scrub in, is that an issue I can fix by soldering the popped connection back together or would it require a replacement distro board?
Old Jul 27, 2012, 03:12 PM
Keddy is offline
Joined Jul 2012
I wouldn't risk it. It's such a cheap part to replace..
Old Jul 27, 2012, 03:13 PM
Casey_S is offline
Casey_S's Avatar
Joined Mar 2011
Oh I ordered a replacement last night. I was just curious.
Old Jul 27, 2012, 03:14 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
My guess would be you had a solder blob that shorted the positive and negative wire pads. As for repairs, unsolder the positive lead from the current pad and solder it to one of the empty + pads on the inner part of the board. If the original copper pad has lifted from the board I'd cut it out and remove it so it doesn't run the possibility of shorting against another negative pad. So is it fixable, yes, by relocating the wire to a different + pad.
Old Jul 27, 2012, 03:19 PM
Keddy is offline
Joined Jul 2012
Also, something does quite look right here. Looks like solder went under the paint and got really close, this may have arced.
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4498 Jun 07, 2016 12:20 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
