Old Jul 25, 2012, 03:34 PM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
Originally Posted by Helidaho View Post
I like them but they don't work well with 4s batteries. I was having timing misses with the escs causing a squeeling crash. Going back to 3s no problems at all!
Hmm...I mean what would be the advantage of 4s over 3s in this case? I know that the 4s give you a little more oomph right?
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Old Jul 25, 2012, 04:57 PM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
4S is more effecient than 3S...less amps required for the same power output. The high cell count also, usually, means need of lower kv motors and/or props.
Vantasstic is online now Find More Posts by Vantasstic
Old Jul 25, 2012, 05:09 PM
Joined Apr 2011
Thanks!! Yeah my current motors work just fine...but the front right motor keeps throwing the prop with the collet off...i cannot get it to stay and i figure this is a good excuse to try some new motors!!
Old Jul 25, 2012, 05:17 PM
Estuardon is offline
Find More Posts by Estuardon
United States, FL, Miami-Dade
Joined Jan 2010
Originally Posted by Keddy View Post
I'm very new to multi rotors, so I don't know the do's and don'ts.
How does my wiring look?
I would suggest a power distribution board for a clean look
The naza controller is in the right location but I would put it on the second floor, I would leave the 1st floor for wiring and the second for electronics, the naza is so stable that you won't crash unless you have some sort of failure.
Estuardo
Estuardon is offline Find More Posts by Estuardon
Old Jul 25, 2012, 05:21 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
i find disto boards to look more messy and just 1 more place where a solder joint can fail.
agreed
Or if you actually fly it hard.... naza will hover well and perhaps you wont crash, but if you fly FPV long distances and low alt you will crash.
good news is. the HT-FPV is very durable
Adidas4275 is offline Find More Posts by Adidas4275
Nick_P is offline
Find More Posts by Nick_P
United States, MO, De Soto
Joined May 2003
Question about motors for this frame...so the motors i have right now are ok...but ive been eyeballing those NTM 1200 kv motors....
What are peoples take on these for this frame?
NTM 1200kv are not playing nice with SimonK flashed F-20 or F-30 esc for me. On 3s I have severe timing issues. When Yawing I get 1 or more motors stalling and unless i am a bit up its difficult to recover. Switching to wii esc fixes the timing issue, but it just doesn't perform well enough for me to use the wii esc and NTM combo.
From reading, it seems like a hit or miss type issue. Some people run them without issue on flashed escs and others like me are having timing issues.
Nick_P is offline Find More Posts by Nick_P
Old Jul 25, 2012, 05:40 PM
Joined Apr 2011
Thanks for that...I will probably eventually move to some flashed esc's...but for now the ones i have work just fine...But it looks like i will need to do some research on what other motors are out there.
Old Jul 25, 2012, 06:01 PM
Nick_P is offline
Joined May 2003
I have used Suppo 2212-11 1200kvs with SimonK firmware escs with success. They are a peppy little motor that has power comparable to NTM 1200KVs.
http://www.blueskyrc.com/index.php?m...products_id=38
Old Jul 26, 2012, 02:27 PM
yoadrian is offline
Find More Posts by yoadrian
32 ft/sec^2 sucks
yoadrian's Avatar
United States, GA, Jasper
Joined Nov 2006
Here's my HT-FPV frame after replacing the dead HFPro flight controller from my disastrous sunset flight
Thanks to Adidas, he got an old HFPro board for cheap with a non working OSD. Which is fine with me as long as it flies! I love how smooth they fly. But since the green boards are a different layout from my black board I could no longer use that big red protective case. So I used the OEM protective cover that came with the HT FPV kit. There weren't any holes where I wanted the board so I used the cover and dropped the board from that
NTM 1200Kv Motors
9x4.7 APC Props
Turnigy Plush 25amp ESCs
Hoverfly Pro v1 Green board with non-functional OSD
EzUHF Rx with Sander style antennas
EzOSD with GPS, RSSI
3000Mah Turnigy 3s nano Flight Battery
370Mah Turnigy 3s nano VTX battery
300Mw 1280MHz VTx
RMRC 600XV CCD FPV Camera
Frankenquad Landing gear (awesome)
HT-FPV frame, found a crack in the go pro plate but still seems sturdy enough. Not bad for a 200ft + free fall! Same APC props too!
1505g AUW - WOOHOO... that's about as light as I've ever had in an FPV quad since my Gaui 330x days!
Hey Heli, did you ever figure out why your osd stopped sending distance and then alt?
yoadrian is offline Find More Posts by yoadrian
Old Jul 26, 2012, 04:04 PM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
Yeah, turns out it was an incompatibility with the camera and the blinking text. I hadn't changed the default alarms so when the text started blinking I guess that isn't compatible with the 600tvl cameras and it disappears! So if I want to keep using the camera I just need to set the OSD limits to something I would never even come close too. Or get another camera! hehe... Pixim cameras were recommended to me by the EZOSD guys.
Paul
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Jul 26, 2012, 06:02 PM
Bhuwan is offline
Find More Posts by Bhuwan
United States, MA, Boston
Joined May 2012
Originally Posted by slidins15 View Post
i was bored and analysing the video again to see what went wrong
i noticed that as the quad crashed upside down into the cow crap, the propellers were still spinning. Milliseconds before impact, the props have hit the crap and sprayed it up in the air. Now we all know what it looks like when the "shite hit's the fan" :d
lol
Bhuwan is offline Find More Posts by Bhuwan
Old Jul 26, 2012, 08:36 PM
Keddy is offline
Find More Posts by Keddy
Canada, ON, St. Catharines
Joined Jul 2012
Oh no, where did my battery go?
Keddy is offline Find More Posts by Keddy
Old Jul 26, 2012, 09:45 PM
yoadrian is offline
32 ft/sec^2 sucks
yoadrian's Avatar
Joined Nov 2006
Looks like a stick of C4
Old Jul 26, 2012, 09:49 PM
yoadrian is offline
32 ft/sec^2 sucks
yoadrian's Avatar
Joined Nov 2006
Has anyone had to flash their naza esc's? Mine start out a little jerky and I have to egg them on a little to get everything to spin up right. One time one motor was going backwards a little, so I disconnected everything and reconnected the battery. I used the naza esc's so that it would all be compatible with the naza controller and wouldn't have any turnigy issues.
Old Jul 26, 2012, 10:08 PM
robstach is offline
Find More Posts by robstach
United States, PA, Bethlehem
Joined May 2012
That sounds like a very odd problem. Never had any issues like that with either of mine. I'd slap it back on to the assistant software and calibrate.
Latest firmware I assume.
robstach is offline Find More Posts by robstach
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4562 Today 09:20 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
