Old Jul 23, 2012, 05:59 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Originally Posted by Keddy View Post
No no, the lipo was just there to hold the wires out of the way. The leads are going to run up a hole in the frame to the next level with a plug.
Ah ok
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jul 23, 2012, 06:00 PM
Keddy is offline
Find More Posts by Keddy
Canada, ON, St. Catharines
Joined Jul 2012
The naza is close, but it's not touching.
And I was planning to run the video TX out in the tail.
Also, the VU? LED is actually protruding out of a hole in the chassis. So it is visable.
Keddy is offline Find More Posts by Keddy
Old Jul 23, 2012, 07:54 PM
sbmon is offline
Find More Posts by sbmon
Joined Aug 2004
keddy
Build looks pretty good.
One thing I would be careful about.
If you plan on actually flying with the park flyer rx I would at a minimum get it into a better more central location on the quad. Also be aware afaik that specific rx does not support the correct failsafe mode required to failsafe the naza fc if there is a loss of radio signal. While that rx does have a failsafe mode it is not what spektrum calls preset failsafe which is what you want for the naza fc.
shawn
sbmon is offline Find More Posts by sbmon
Old Jul 23, 2012, 08:00 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I'm very new to multi rotors, so I don't know the do's and don'ts.
How does my wiring look?
Keep in mind that I need to mount the RX still, and shrink wrap those solders.
That's where I put my Naza controller...works fine. I'd recommend putting the VU in a better spot to see the LED. You'll want to see the LED status during initialization and while flying. With it pointed straight down you'll loose that visibility. I mounted mine up on the front arm. Even on a back arm is better than you're current location.
Vantasstic is offline Find More Posts by Vantasstic
Old Jul 23, 2012, 09:39 PM
Keddy is offline
Joined Jul 2012
Yes I'm aware that the RX doesn't have a fail safe compatible with the naza.
Could anyone piont me to a budget RX that will get the job done right?
From what I read, they start at the 7xxx series.
Also, I've now mounted the RX on the back arm.
I'm going to leave the VU where it is for now. I can see the LED just fine through the large opening on the bottom of the chassis. I'm just going to do a few test flights and find a safe time limit and always time my flights.
Here is a close up of the VU from the bottom. I think I'll be ok.
Old Jul 24, 2012, 12:25 AM
Urbanerosion is offline
Find More Posts by Urbanerosion
Joined Feb 2012
Here's my HT-FPV
Having a great time with this new hobby. I've only had the HT-FPV out a few times but she flies pretty well.
Video from first day fpv-ing
HT-FPV Frame
HT-FPV Power Distribution Board
NTM Prop Drive Series 28-26A 1200kv / 250w
DJI ESC-30A OPTO Brushless Speed Controller
DJI NAZA Multi-Rotor Stabilization Controller with GPS Add-on
GAUI 210801 8-inch Prop Set (8A and 8B)
Turnigy nano-tech 3300mah 3S 45~90C Lipo
Futaba T8FG Super 14ch Transmitter w/R6208SB 2.4GHz Receiver
1.2Ghz Low Pass Filter
1.3Ghz Tuned to 1280Mhz 14dBi Panel Antenna
1.3 GHz Bluebeam Whip Antenna Set
SMA Right Angle Adapter
Fat Shark Dominator Modular Design 640x480 FPV Video Glasses
Racewood 1.3GHz 500mW Wireless AV Transmitter Blue Label
Racewood 1.3GHz Wireless AV Receiver VRx Blue Label
FPV Camera - 600TVL SONY SUPER HAD CCD D-WDR Color Board Camera DNR
Camera - GoPro Hero2
Urbanerosion is offline Find More Posts by Urbanerosion
Old Jul 24, 2012, 02:18 AM
Boris B is online now
Find More Posts by Boris B
Boris B's Avatar
The Netherlands
Joined May 2012
Doesn't look bad that video! Are you flying without OSD?
Boris B is online now Find More Posts by Boris B
Old Jul 24, 2012, 03:52 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
The Hobbyking orange 7 & 9 channel Rx are suppose to have failsafe on all channels, although I have not tested it yet personally.
Site Sponsor
Old Jul 24, 2012, 07:13 AM
sbmon is offline
Joined Aug 2004
I have one in them mail. I will report back
fwiw horizon is wrong about the AR8000 rx it does support both types of failsafes even though the manual states it differently.
shawn
Old Jul 24, 2012, 08:21 AM
bpd964 is offline
Find More Posts by bpd964
Change is good...
Connecticut
Joined Mar 2008
Frame: Hoverthings FPV
Flight Controller: Naza / Naza GPS
Power Distribution: Self wired spider
Batteries: 4s 3300 nanotech
ESC: DJI 30a
Motors: DJI 920 kv
Props: Gemfan 9 x 4.7
Rx: Hitec optima 9
Lights: n/a
Camera: GoPro2 / RMRC 700tvl (recently upgraded)
Video Tx: ImmersionRC 600mw / Fatshark Domonator CL ant.
OSD: Eagletree OSD pro, with Gps
AUW: ?
All Up Weight (Gross)
bpd964 is offline Find More Posts by bpd964
Old Jul 24, 2012, 09:20 AM
The Recursion is offline
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
< Oops replied to wrong thread >
The Recursion is offline Find More Posts by The Recursion
Old Jul 24, 2012, 01:25 PM
Joined Feb 2012
Thanks.. I'm currently looking into osd but haven't taken the plunge yet.
Old Jul 24, 2012, 11:17 PM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
Here's my HT-FPV frame after replacing the dead HFPro flight controller from my disastrous sunset flight
Thanks to Adidas, he got an old HFPro board for cheap with a non working OSD. Which is fine with me as long as it flies! I love how smooth they fly. But since the green boards are a different layout from my black board I could no longer use that big red protective case. So I used the OEM protective cover that came with the HT FPV kit. There weren't any holes where I wanted the board so I used the cover and dropped the board from that
NTM 1200Kv Motors
9x4.7 APC Props
Turnigy Plush 25amp ESCs
Hoverfly Pro v1 Green board with non-functional OSD
EzUHF Rx with Sander style antennas
EzOSD with GPS, RSSI
3000Mah Turnigy 3s nano Flight Battery
370Mah Turnigy 3s nano VTX battery
300Mw 1280MHz VTx
RMRC 600XV CCD FPV Camera
Frankenquad Landing gear (awesome)
HT-FPV frame, found a crack in the go pro plate but still seems sturdy enough. Not bad for a 200ft + free fall! Same APC props too!
1505g AUW - WOOHOO... that's about as light as I've ever had in an FPV quad since my Gaui 330x days!
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Jul 25, 2012, 09:40 AM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
Question about motors for this frame...so the motors i have right now are ok...but ive been eyeballing those NTM 1200 kv motors....
What are peoples take on these for this frame?
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Old Jul 25, 2012, 03:18 PM
aka Helidaho
Joined Jun 2010
I like them but they don't work well with 4s batteries. I was having timing misses with the escs causing a squeeling crash. Going back to 3s no problems at all!
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4545 Today 06:50 AM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
