United States, PA, Bethlehem
Joined May 2012
http://hotwirefoamfactory.com/-K03P-...Table-Kit.html I have that particular model but there are dozens of plans out there that you can get that will essentially give you the same thing. The wire is more like a guitar string rather than a hangar. Thin and it will slice through the foam like a hot knife through butter! I'll go take a look for that extra wire (in my basement somewhere!). I'll PM you when I find it - might not be until tomorrow night
Passaic, New Jersey
Joined Mar 2010
starting to build my ht-fpv, i will be using the electronics off my f450 (dji 30amp esc, 920kv motors, naza, and gps), what would be the better combo 4s with 8'' prop or 3s with 10'' prop, im gonna have to buy new batteries so just want to know which way would be better to go with for longer flight times, also for those that have used this same setup how are you connecting the esc to motor because when i mount the distribution plate in the middle my motors and esc dont reach each other, thanks
Joined May 2012
Right where I thought I put it (for once!)PM me where you'd like me to send it and I'll drop it in the mail tomorrow. - Rob Edit: Here's a pelican case I did a few years back and the foam is still holding strong! Yes, I'm legal so no need to ask! The "scroll saw" method is really the best way to go when cutting foam for your cases. It gives you a nice platform to work on and you can get some really intricate cuts. In it's simplest form it's just a hunk of wood with a hole in it, an arm, and a wire hooked up with a spring for tension - easy as pie to make and since you have a transformer already you are 95% of the way there.
Joined May 2012
My "solution" was to make little pigtails that I soldered a female deans connector to. I soldered these to the power distribution board. Then I soldered the male deans to the ESC. Sort of a modular system now.... The goal was to make it more portable and if I decide to get a case for it the arms can be separated from the body with ease. Otherwise they're at the mercy of the length of whatever wire length you go with. Not sure if this is the best method or if it will cause issues (doubt it) but I'll know next week when she's finally airborne. Otherwise - I'd say get some wire and extend the ESC leads. |
What gun is that? Looks a lot like my paintball gun.
Joined May 2012
![]() Another one of my expensive hobbies. I played paintball for many years when I was still able to run without falling over!
I built my own power distribution hub and used 2mm bullet connectors to attach the ESCs to the distro board. When I travel I only need to remove the arms, disconnect the bullet connectors and done...no soldering, no messing, just plug and unplug. It worked so well I did the same thing with my DJI 550 frame. |
Latest blog entry: Transplanting a Spektrum Dx4E Rf Deck...
Expensive is an understatement when you get into class 3 stuff, although I have seen some SMGs as low as 3K-4K.
Joined May 2012
I get some great footage from the quad at the range though although it can be a little dicey at times That's one of the reasons I purchased the camo version!Anyway - back to Hoverthings! Sorry for the temporary derailment everyone! |
Australia, VIC, Mordialloc
Joined Aug 2009
http://www.rcgroups.com/forums/showp...&postcount=515 |
| Thread Tools | |
| Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) | JettPilot | Video Piloting (FPV/RPV) | 3078 | Today 09:24 AM |
| Discussion Show us your FPV Multicopter | Derek_S | Video Piloting (FPV/RPV) | 194 | Feb 08, 2013 12:07 PM |
| Discussion FPV Successful? Show us setup and parts list | Royalson | Video Piloting (FPV/RPV) | 0 | Mar 10, 2012 08:25 AM |
| Discussion Show us your FPV / RVP ground Base set up in action | Trackercal | Video Piloting (FPV/RPV) | 94 | Nov 05, 2010 10:21 AM |
| Discussion Show Us Your FPV Helo Set Up | Trackercal | Video Piloting (FPV/RPV) | 2 | May 11, 2009 11:05 PM |
