Old Apr 07, 2012, 04:17 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Well this sucks. I charged up another 4S pack and ran to the park real quick (okay, drove) to try and get a 4S flight data recording. No-go again. I got home, went to download the data recorder and nothing's on it. Jesh. I did a manual clear of it and will try again on another date. I don't do a lot of data recording with it, but it sure is nice to have for motor/prop/battery comparisons. Maybe tomorrow I'll have more luck...if the wifey lets me fly.
Juz,
What kind of flight time are you getting with your HT-FPV setup with that 3000mAh pack? My 4S 2650 is getting about 8 minutes right now with my 920kv motors.
Vantasstic is offline Find More Posts by Vantasstic
Old Apr 07, 2012, 04:51 PM
NutBag is offline
Find More Posts by NutBag
NutBag's Avatar
Australia, QLD, Brisbane
Joined Oct 2005
Originally Posted by juz70 View Post
Best FPV frame I know of = HT-FPV
OpenPilot CopterControl
frankenquad CC protective case
Spektrum AR 7010 rx + sat rx
HT power distribution board
Turnigy Plush 25 amp ESCs
NTM 1200kv motors
NTM 28 series accessory pack
gaui 8 inch props
turnigy ESC programming card
800mW vTx (rated/tested at 600mW at 12V)
480 OSD camera
cloverleaf whip antenna
rmrc camera cable
rmrc large vTx cable
rmrc video jumper to connect camera cable to tx cable
370mah 3s lipo for cam/vtx
GoPro Hero2 for onboard recording
layerlens gopro protection
Maiden FPV flight...
http://www.youtube.com/watch?v=c98uH...1&feature=plcp
That's awesome Juz! My frame is in the post to me now... Excited!
Got a CC and a franky case ready to go... Pretty much the exact same set up!
Switched to cloverleaf/crosshair myself and loving every minute of it :-)
Chris.
NutBag is offline Find More Posts by NutBag
Old Apr 07, 2012, 09:38 PM
The RevKev is offline
Find More Posts by The RevKev
PastorBikerBrewerPilot
The RevKev's Avatar
United States, NE, Central City
Joined Mar 2012
I'm curious, those of you building the HT-FPV frames, do you use the blue loc-tite on your fasteners? I saw it is recommended, but not required. Pros & cons before I start my build?
The RevKev is offline Find More Posts by The RevKev
Old Apr 07, 2012, 10:48 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Some do, some don't. I normally don't, but did on my HT-FPV frame. I loc-tited the arms and screws on the bottom of the frame. I didn't loc-tite the top frame screws so I could disassemble the frame easily, if needed.
Old Apr 07, 2012, 11:44 PM
juz70 is online now
Find More Posts by juz70
Lumenier team pilot
juz70's Avatar
Australia, VIC
Joined Dec 2009
I never loctite anything on my quads. One or two frame screws coming loose ain't going to bring you down. So much easier to re-build/repair/modify the frame without loctite.
Pre-flight, pre-flight, pre-flight.
juz70 is online now Find More Posts by juz70
Old Apr 07, 2012, 11:47 PM
shdwkeeper is offline
Find More Posts by shdwkeeper
United States, CA, Anaheim
Joined Dec 2011
Anyone have Pictures of where they located their Eagle Tree OSD Pro, eLogger and GPS at?
Also what is everyone using to mount their FPV camera on this frame to?
shdwkeeper is offline Find More Posts by shdwkeeper
Old Apr 07, 2012, 11:54 PM
juz70 is online now
Lumenier team pilot
juz70's Avatar
Australia, VIC
Joined Dec 2009
Originally Posted by Vantasstic View Post
Juz,
I have no OSD on this frame (yet) and land after about 5.5 minutes and pump back around 2000 - 2200mah. I am kind of guessing these figures as I am not that obsessed with flight times etc. With an OSD I just fly until my pack has given me 70 -80%. Without OSD, for safety, I fly for 5mins. There is always another lipo!
Old Apr 08, 2012, 01:34 AM
Joined Dec 2011
NTM 1200kv motors
gaui 8 inch props
480 OSD camera
rmrc camera cable
Juz - does your FPV mount get your camera above the GoPro? Or do you have a riser below it, got a Pic of that?
Old Apr 08, 2012, 03:42 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
True that. I thought I'd do this "properly" and put loctite on every screw but the ones for the top plate and protection plate. I think this was a mistake. If I break an arm I have to buy new spacers and screws, it's impossible to get these out now. Crap. Think I'll order a new set of screws right away since I already have a spare set of arms.
WiseDuck is offline Find More Posts by WiseDuck
Old Apr 08, 2012, 05:37 AM
The RevKev's Avatar
Joined Mar 2012
FPV camera is tentatively planned to be mounted alongside my Gopro using the snap case from eyefly.info
http://www.eyefly.info/index.php?rou...tegory&path=63
Duo-snap FPV cam mount: http://www.eyefly.info/index.php?rou...&product_id=63
Old Apr 08, 2012, 07:29 AM
klaudius is offline
Find More Posts by klaudius
klaudius's Avatar
France, IdF, Juvisy-sur-Orge
Joined Nov 2003
My miniquad for FPV.
Frame: Custom - carbon arm 30 cm - Nivea plastic case. First quad good for your skin....
Flight Controller : Crius SE - Multiwii 2.0
Power Distribution: soldering
Batteries: 2S - 3S for FPV
ESC: 4 turny plush 10A
Motors: 1810 hobbyking
Props: 5x3
Rx: 41mhz 6 channel
Lights: none
Camera: Sony Super HAD PAL
Video Tx: Fatshack 2.4Ghz 100mw
OSD: none
klaudius is offline Find More Posts by klaudius
Old Apr 08, 2012, 10:56 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Well, what can I say, the VC-FPV frame sure as **** won't become my main quad anytime soon because of random issues with electronics, motors and everything. I'm using Naze32 on it and I have little to no yaw authority. Sometimes I can barely turn left, and this time I couldn't turn right and the motors (Which are expensive, smooth, quality motors. I.e MT2216) make this horrible noise when I try. What's going on?!
Naze32 with VC-FPV - Something is wrong (0 min 37 sec)
Old Apr 08, 2012, 11:10 AM
klaudius is offline
klaudius's Avatar
Joined Nov 2003
Perhaps a wrong ball bearing on one motor. it happed to me on one motor.
If your propeller are unbalanced, it can break ball bearing.
Old Apr 08, 2012, 11:21 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Could be that, altho they feel fine when I turn them by hand. They don't make any noises, they don't feel gritty... But just to be sure I'll replace all 4 motors with another set I have.
Old Apr 08, 2012, 11:47 AM
klaudius is offline
klaudius's Avatar
Joined Nov 2003
by experience not noticable just turning le motor by hand... apply lateral pressure on axis in many direction, the axis must be rock solid...sommetime it make a clic on outrunner cause magnet stick on stator.
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4493 May 19, 2016 02:53 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
