Old Apr 04, 2012, 12:36 AM
StrangerDejaVu is offline
Find More Posts by StrangerDejaVu
United States, MN, St Paul
Joined Jan 2012
I reserve this space! It'll be a couple weeks before I get it all together, but a black HT FPV quad is on it's way
Frame: HT FPV
Flight Controller: OP CC. May also try the new Quadrino.
Power Distribution: Board offered by hoverthings and witespy
Batteries: 2200 and 4000 3S
ESC: Turnigy Plush 18A
Motors: NTM 1050 on the way, may also try a Turnigy SK3 700 or 800kv 4S setup
Props: 8" carbon GemFan
Rx: JR R921 2.4ghz
Lights: maybe!
Camera: RMRC 420 feed, GoPro HD2 video
Video Tx: RMRC 300mw
OSD: None
StrangerDejaVu is offline Find More Posts by StrangerDejaVu
Old Apr 06, 2012, 02:26 PM
The RevKev is offline
Find More Posts by The RevKev
PastorBikerBrewerPilot
The RevKev's Avatar
United States, NE, Central City
Joined Mar 2012
Its here: some changes on the spec for now...
Frame: HT-FPV
Flight Controller: NAZA
Power Distribution: HT
Batteries: 30C 2450mAh Flight, 1100mAh RMRC Vid
ESC: DJI 30A
Motors: DJI 920
Props: DJI 8, maybe 10's, any word on Vid vibe with this?
Rx: Spektrum AR8000 & Sat for now. Waiting on EzUHF Rx
Lights: none
Camera: RMRC 600tvl NTSC
Video Tx: RMRC 5.8 500mHz
OSD: EzOSD
AUW:
Vid Tx: RMRC 600mHz 5.8 w/ blubeam whip
Vid Rx: Fatshark Dominator 5.8 w/ blubeam whip
Tx: Either my Dx6i or Dx8 w/ EzUHF on the way for future expansion
Camera mount: eyefly.info duo-snap 2 camera mounting
Meantime, I'm messing with the VC-450 I got off RCG. Ordered some extra tabbed plates to maybe have some fun with it in the future too.
The RevKev is offline Find More Posts by The RevKev
Old Apr 06, 2012, 04:09 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by The RevKev View Post
Just got word mine is in the mail today. I'm giddy as a schoolgirl!
Frame: HT-FPV Black w/ Red protector plate
Motors: Debating between the DJI 920kv or some NTM 1050kv I have on the way
ESC: Debating between DJI opto 30A or Turnigy 30A plush
Power dist: Hoverthings
Vid TX: RMRC 600mHz 5.8 w/ blubeam whip
Camera: RMRC600tvl NTSC
FBatt: Turnigy 2450mAh 30C
VBatt: ?
OSD: EzOSD
FC: DJI NAZA
Props: 8's (DJI if I use the DJI motors)
Rx: Spektrum AR8000 w/ Sat
My inputs for you...
On 3S the 1050kv with 8" props or the 920kv with 9" or 10" props should be fine. I think 920kv with 8" props on 3S would be rather weak. I'm running the DJI 920s with 8" props on 4S on mine and it does fine. I'm going to compare those motors on 3S with 10" props to see what gives the best performance/flight time. I was hoping to do that today, but to windy. Fingers crossed tomorrow will be better weather. I'll post results as soon as I have it.
If you're using the Naza controller then I'd go with the DJI ESCs. If you use 'other' ESCs then make sure you disable the ESC BECs by removing the red servo wires from the connectors. You don't want to try and have two different power sources fighting each other to feed your system.
Vantasstic is offline Find More Posts by Vantasstic
Old Apr 06, 2012, 06:22 PM
BayAreaCrasher is offline
Find More Posts by BayAreaCrasher
BayAreaCrasher's Avatar
Joined Feb 2011
Just starting to build my HTFPV and noticed a problem. The instructions call for 54 spacers to be used, but the kit only comes with 50. Not a big deal, but I wanted to throw that out there. Did any of the people who've already built it come across that problem?
BayAreaCrasher is offline Find More Posts by BayAreaCrasher
Old Apr 06, 2012, 07:18 PM
daign is offline
Find More Posts by daign
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
About to finish her up... Best Frame in the world.
Fresh with Sk3 motors.
daign is offline Find More Posts by daign
Old Apr 06, 2012, 11:17 PM
The RevKev's Avatar
Joined Mar 2012
Great advice! I'll be anxious to hear your experience and "borrow" from you
Saw that I might have had a line on an OPCC but daign was a Johnny on the spot
On the vc-450 I have already, I notice there is some drift in Atti mode even though I'm in hover indoors. Can you give me some guidance or point me to a place where this has been dealt with in another forum?
I'm lovin reading and learning from you all. Thanks!
Happy Easter!
Old Apr 06, 2012, 11:35 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Happy Easter!
I think you'll pretty much always have some drift unless you've got GPS position hold...even then it'll drift around some.
Old Apr 06, 2012, 11:39 PM
juz70 is offline
Find More Posts by juz70
Lumenier team pilot
juz70's Avatar
Australia, VIC
Joined Dec 2009
I love drift....video later...
juz70 is offline Find More Posts by juz70
Old Apr 07, 2012, 12:03 AM
juz70 is offline
Lumenier team pilot
juz70's Avatar
Australia, VIC
Joined Dec 2009
Best FPV frame I know of = HT-FPV
OpenPilot CopterControl
frankenquad CC protective case
Spektrum AR 7010 rx + sat rx
HT power distribution board
Turnigy Plush 25 amp ESCs
NTM 1200kv motors
NTM 28 series accessory pack
gaui 8 inch props
turnigy ESC programming card
800mW vTx (rated/tested at 600mW at 12V)
480 OSD camera
cloverleaf whip antenna
rmrc camera cable
rmrc large vTx cable
rmrc video jumper to connect camera cable to tx cable
370mah 3s lipo for cam/vtx
GoPro Hero2 for onboard recording
layerlens gopro protection
Maiden FPV flight...
FPV - drift (3 min 55 sec)
Old Apr 07, 2012, 10:44 AM
shdwkeeper is offline
Find More Posts by shdwkeeper
United States, CA, Anaheim
Joined Dec 2011
NTM 1200kv motors
gaui 8 inch props
480 OSD camera
rmrc camera cable
http://www.youtube.com/watch?v=c98uH...1&feature=plcp
That was a great video - Nice Job
shdwkeeper is offline Find More Posts by shdwkeeper
Old Apr 07, 2012, 10:57 AM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
NTM 1200kv motors
gaui 8 inch props
480 OSD camera
rmrc camera cable
Awesome video Justin! Nicely done. Some close calls in there although I half expected you to fly under that tanker while it was drifting
I see you've gone to circularly polarized antennas, how do you like them? At 1.2 they seem kind of big. And fragile.
Paul
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Apr 07, 2012, 12:09 PM
The RevKev's Avatar
Joined Mar 2012
Nice vid. Not sure what's more impressive - the driving or the flying... I used to be a truck driver to pay my may through school and that makes me want to crap myself!
So what you are saying is that this problem I have - spending time on forums and money on quads means I'll eventually end up even poorer than I already am, culminating in my being a "drifter"?
Old Apr 07, 2012, 02:28 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I flew my HT-FPV frame today with the DJI 920kv motors and different size LiPos and Props. For some reason my data recorder only recorded the first flight's data with the 920kv on 3S with 10x4.7 props. I also flew it on 4S 2650 with 8" props...but don't have the data on it. I'll try again later (maybe tomorrow if the wife permits me to fly).
Attached is my motor/prop/battery testing data so far...in order of longest flying time per mAh used. I really need to get a larger battery...my 8-9 minute fly time just seems to short.
Old Apr 07, 2012, 02:32 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
NTM 1200kv motors
gaui 8 inch props
480 OSD camera
rmrc camera cable
Juz, your frame looks great. I see many improvements Tom has added from the prototype frames. I'm considering buying a 'release' version to add to my fleet...in red. I like red to make it easier to find after I crash.
Old Apr 07, 2012, 02:49 PM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Maidened this one today, after a bit of tweaking it flies really well. Tomorrow I'll take it out for a spin, first impressions are really good!
Frame: HT-FPV Camo
Motors: Tiger MT2216-11 900kv
ESC: Hobbyking Blueseries 20A
Vid TX: Hobbyking 5.8ghz 200mw
Vid Rx: 5.8ghz 200mw
Camera: Sony CCD 600tvl for 52 USD, from SecurityCameras
VBatt: 3S 360mah Nanotech
Tx: Turnigy 9X with ER9x and FrSky telemetry module and external LCD
Rx: 6ch FrSky telemetry receiver
FC: Naze32
Props: 9x4.7 CF reinforced Gemfan
WiseDuck is offline Find More Posts by WiseDuck
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4498 Jun 07, 2016 12:20 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
