Old Nov 26, 2012, 01:25 AM
shdwkeeper is offline
Find More Posts by shdwkeeper
United States, CA, Anaheim
Joined Dec 2011
ok, will the Turnigy Stock Plush 30a esc work with the Naza with just the WHITE wire connected? WIll it work with ALL THREE wires connected? Do I have to reflash the esc. Just trying to get an answer here.
shdwkeeper is offline Find More Posts by shdwkeeper
Old Nov 26, 2012, 01:34 AM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
I never used turnigy esc's so i can't speak to that...was using 30a rctimers stock...and those worked just fine...i actually just rebuilt mine with some Simon k 30a ipeaka esc's...they run up pretty well...i haven't removed the red wire yet...gonna do that tomorrow...
But on the turnigys...you should be fine...
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Old Nov 26, 2012, 01:40 AM
Joined Dec 2011
OK, so the NAZA only requires the white wire than from the esc? On the CopterControl board I had to leave the red wire on one of the escs
Old Nov 26, 2012, 08:18 AM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
You might need ground as well, but just leave the red wire disconnected. You don't want the ESC's BECs fighting against the Naza VU (BEC)
Cervanchez is offline Find More Posts by Cervanchez
Old Nov 26, 2012, 08:43 AM
Joined Apr 2011
I'm sure having the ground is a good idea...but i didn't have mine plugged in and never had any issues
Old Nov 26, 2012, 08:53 AM
Cervanchez's Avatar
Joined Dec 2011
If it works without the ground I'd leave that disconnected as well then. That way no risk of ground loops.
Old Nov 26, 2012, 10:13 AM
Joined Apr 2011
Yep
Old Nov 26, 2012, 11:33 AM
Joined Dec 2011
Yep
thanks you guys. I will remove the RED and BLACK and leave the White Signal wire and give it a shot.
Old Nov 26, 2012, 12:21 PM
Joined Apr 2011
Also if you want just take the plastic off completely and put some shrink wrap around the end of the signal wire...works real nice...then tape back the other two
Old Nov 27, 2012, 10:03 AM
Joined Dec 2011
I just remove the pins out of the plastic using a small screwdriver leave the white pin in there.
Old Nov 27, 2012, 10:40 AM
Joined Apr 2011
Yep that works too...
Old Nov 28, 2012, 07:33 PM
Kosmos is offline
Find More Posts by Kosmos
Just Starting..
Joined Oct 2012
No it is all 5.8 - and I am in a very populated area so there may be a lot
of interference. Was gone over the holiday break - but I have managed
to get a GoPro mounted - attached is more boring backyard video but
l have to say I am happy with the results of the GoPro and some moongel
Now if I could just figure this
EagleTree stuff out and get the GPS lock that would be cool!!!
(any pointers on how to make the sticks a little less sensitive would be
welcome - still very new to it all)
Also thinking about moving the vTX system to its own battery... but that will
add more weight and lower my flight time..... I do have it filtered on a 3s
battery pack...
Here is the HD vid:
First HD FPV backyard flight (5 min 20 sec)
Originally Posted by Exploding Fist View Post
Kosmos are you using 1.2Ghz vTX?
Kosmos is offline Find More Posts by Kosmos
Old Nov 28, 2012, 07:39 PM
Kosmos is offline
Just Starting..
Joined Oct 2012
Cool site!! Jealous - I need to get out of the backyard.....
(heavy sigh... perhaps this weekend...)
Hi guys,
I found a new flying site and had a blast over the weekend FPVing. Here's some of the highlights. About a third of the footage was on my HT-FPV frame, the rest was a HT-450.
[snip] video url [/snip]
Old Nov 28, 2012, 10:06 PM
Mochaboy is offline
Find More Posts by Mochaboy
Radd Graduate '06
Mochaboy's Avatar
United States, MA
Joined Aug 2006
Add exponential to your roll channel on your transmitter in 5% increments starting at 5%.
As for the GPS - are you talking about the GPS expander hooked up to a v4 logger?
Mochaboy is offline Find More Posts by Mochaboy
Old Nov 28, 2012, 11:31 PM
Cervanchez's Avatar
Joined Dec 2011
Looks like your ready to rip. Here's part 2 on a foggy day. Fog shots were on my HT-FPV, the rest was on my HT-450. Thanks Tom for making awesome frames.
In the Fog (3 min 40 sec)
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4517 Jul 12, 2016 01:32 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
