Old Nov 24, 2012, 06:48 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by scrape View Post
I think I pushed the battery to far. Think I'll keep it closer to the ground @ the end of the pack.
It's official...you broke it!!!
Vantasstic is offline Find More Posts by Vantasstic
Old Nov 24, 2012, 07:09 PM
glmccready is offline
Find More Posts by glmccready
Gary
glmccready's Avatar
United States, MD, Salisbury
Joined Mar 2011
scrape: bummer. I never let my lipos get to low. Good thing you had those led light strips to hold it all together!
glmccready is offline Find More Posts by glmccready
Old Nov 24, 2012, 07:13 PM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
http://www.youtube.com/watch?v=2vi__gd84XI
Is That a sc2000 cam you are using if so how did you hook it up to the EZosd
Sorry about the crash
tech69x is offline Find More Posts by tech69x
Old Nov 24, 2012, 08:07 PM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
No, it a RMRC-600 they have a cable for plug & play hook-up. Thanks
scrape is offline Find More Posts by scrape
Old Nov 26, 2012, 12:36 AM
shdwkeeper is offline
Find More Posts by shdwkeeper
United States, CA, Anaheim
Joined Dec 2011
OK, I am going to move my Naza to this HT-FPV frame, have been using a CopterControl board. Question:
I'm using Turnigy Plush 30A esc, and currently I have only the signal wire (white) connected on 3 of 4 ports on the FC. All 3 wires (red, black and white) are connected on 1st port. Using the Naza FC do I need to reconnect all these wires again or does it matter, if all 3 wires are intact coming from the esc is that ok as well?
Just curious.
shdwkeeper is offline Find More Posts by shdwkeeper
Old Nov 26, 2012, 12:39 AM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
I'm using Turnigy Plush 30A esc, and currently I have only the signal wire (white) connected on 3 of 4 ports on the FC. All 3 wires (red, black and white) are connected on 1st port. Using the Naza FC do I need to reconnect all these wires again or does it matter, if they are all 3 wires are intact coming from the esc is that ok as well?
Just curious.
Just one like the cc3d
Old Nov 26, 2012, 12:43 AM
Joined Dec 2011
If I have 4 brand new Turnigy 30a ESCs do I still need to remove the wires from them or can I leave them intact? I know with the DJI esc/motors you don't touch anything.
Old Nov 26, 2012, 12:51 AM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
My bad you have to take all of the power wires off
Old Nov 26, 2012, 12:52 AM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
I just looked at mine to be sure
Old Nov 26, 2012, 01:04 AM
Joined Dec 2011
you have a picture? So I only want the white wire connected on all the Plush 30A esc's to the naza then correct?
Old Nov 26, 2012, 01:05 AM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
No the white and black
Old Nov 26, 2012, 01:07 AM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
I use a Naza on mine and you only need to run the white signal wire...
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Old Nov 26, 2012, 01:18 AM
Joined Dec 2011
Ok, I will remove all wires except the white one. You also have the Plush 30a esc as well right? I'm reading that some folks are having problems with this esc and they had to re-flash the firmware, hopefully i won't have to do that.
Old Nov 26, 2012, 01:23 AM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
I have been using flashed esc's with no problem
Old Nov 26, 2012, 01:25 AM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
You need to go here and ask
http://www.rcgroups.com/forums/showt...0#post23363800
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4498 Jun 07, 2016 12:20 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
