Old Nov 22, 2012, 01:34 AM
shdwkeeper is offline
Find More Posts by shdwkeeper
United States, CA, Anaheim
Joined Dec 2011
Originally Posted by flohio117 View Post
Hey man where is the cg on this frame? Can you post a pic with an x on the cg?
The instructions that came with frame show you, the CG is the two back standoffs that hold up the top plate
shdwkeeper is offline Find More Posts by shdwkeeper
Old Nov 22, 2012, 10:40 AM
Quadrophil is offline
Find More Posts by Quadrophil
Joined Nov 2012
Originally Posted by vic20owner View Post
Make sure your CG is correct, even back a bit further... and that your arms are straight (no twist in the arm). Any flight controller will work fine with this frame if the frame is balanced correctly.
read this thread for settings:
http://www.rcgroups.com/forums/showthread.php?t=1633231
CG is correct in my eyes, please see the picture attached to check it.
Arms are straight without any twist.
Thanks for the link with the CC settings. Hopefully they'll work for the new CC3D too, I'll try them out tomorrow.
At the moment, there are two main problems I have with the HT-FPV plus CC3D: Quad is heavily drifting to the right (started to mess around with AccelBias with limited success) and the commonly known "tail wag" of the quad.
Quadrophil is offline Find More Posts by Quadrophil
Old Nov 22, 2012, 12:09 PM
robstach is offline
Find More Posts by robstach
United States, PA, Bethlehem
Joined May 2012
Howdy all - been a while....
Beautiful day for some quick flights before heading out so I decided to get the goggles on and do it!
Coming in for a battery swap and didn't notice the nice little tree that decided to jump in front of me. Bam! No major damage - just missing a prop nut , prop, and washer...
Thought I'd share for a quick laugh! Enjoy!
More importantly - Happy Thanksgiving to all of my fellow HT-FPV pilots and their families!
Thanksgiving Day Ooops......... HT-FPV (0 min 35 sec)
robstach is offline Find More Posts by robstach
Old Nov 22, 2012, 02:02 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Try increasing your roll and pitch rate I gains to the same level as P. Or better yet use txpid and assign it to a knob or slider and adjust in flight until it levels I had the same problem with both cc and cc3d, with the new fw. This is also a common prob.
good luck
Cervanchez is offline Find More Posts by Cervanchez
Old Nov 22, 2012, 02:27 PM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
I have fixed that problem it is all in the Accel Bias settings
tech69x is offline Find More Posts by tech69x
Old Nov 22, 2012, 03:22 PM
Joined Nov 2012
good luck
I'll give your suggestion a try tomorrow, thanks for the info! Besides, you don't have working settings to share for the CC3D, do you?
So the quad drifting to the right is a common problem of the CC3D in general or just in combination with the HT-FPV?
Old Nov 22, 2012, 04:34 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
I bought my frame from someone else. So no instructions lol.
Thanks for the pic
flohio117 is offline Find More Posts by flohio117
Old Nov 22, 2012, 06:13 PM
Cervanchez's Avatar
Joined Dec 2011
in general. I've read others on the op forums that had the same issue. I'm not using my cc3d on the htfpv, I have it on a ht450 (got my naza on the htfpv), so not sure if my settings wil help u. I do remember that there is a dedicated
thread over there for the htfpv tuning. mostly because of the "tail wag" lots of people are getting.
I dont have a link but check it out or ask on the cc3d tuning thread
Old Nov 22, 2012, 11:26 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
Does anyone know if black stuf on NTM prop drive 35-30 motors is normal on the windings?
I have some what looks like melted black stuff in between the windings on my motors. When I poke it its solid and the motors are always cool and I don't feel any problems with the motors. Any clue what it is?
Old Nov 23, 2012, 10:24 AM
simplyfly is offline
Find More Posts by simplyfly
go ahead and try
Canada, ON, Maynooth
Joined Nov 2011
expecting to receive my HT FPV on Tuesday next...
Wondering which of these motors to use...
http://www.hobbyking.com/hobbyking/s...00KV_315W.html
http://www.hobbyking.com/hobbyking/s...00kv_250w.html
http://www.hobbyking.com/hobbyking/s...dproduct=25556
The 1000Kv NTM seems to be the lightest, most powerful motor. I know many of you have chosen the 1200... which is almost 20g heavier, with less output?
Wouldn't the lower Kv motor have longer run time??? and if so, then perhaps the last motor "specially designed for quads" would be a better choice??? although, it is the heaviest motor in the group.
Until this is decided I plan on trying the motors I have...
http://www.readymaderc.com/store/ind...roducts_id=795
These motors are running in the feiyu x4, on 10/4.7. The little quad has oodles of power, even when using 3300mAh 3s. The problem is I have no way of knowing what they are, in terms of Kv and overall output... If they work to satisfaction, then I will likely not make any changes, however i would love to know the specs on this motor, if anyone happens to know off hand.
I have three sets of ESC to choose from...
Turnigy AE-20
http://www.hobbyking.com/hobbyking/s...hless_ESC.html
Tower Pro W30
http://www.hobbyking.com/hobbyking/s...ontroller.html
and then the original Hobbywing ESC's that came with the feiyu x4...
Any suggestions / comments? I plan on using this for FPV, and will not be using Gopro, as popular as they are I will be using this cam...
http://www.rctimer.com/index.php?gOo...0&productname=
Look at the weight... rctimer listed it as 1Kg Ha!!! i hope not... I expect to have to add some weight to balance the quad without the gp... if any thin, I would like to keep the weight at an absolute minimum (within reason / budget)
Thanks!
simplyfly is offline Find More Posts by simplyfly
Old Nov 23, 2012, 11:10 AM
Buzz_Man is offline
Find More Posts by Buzz_Man
Fly safe, fly often!
Buzz_Man's Avatar
United States, GA, Powder Springs
Joined Dec 1999
Originally Posted by simplyfly View Post
Any suggestions / comments? I plan on using this for FPV, and will not be using Gopro, as popular as they are I will be using this cam...!
I'm using four of these with awesome success --> LINK
Buzz_Man is offline Find More Posts by Buzz_Man
Old Nov 23, 2012, 05:52 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
@simplify I'd recommend a 4s setup way more power I tried some NTM 35-30 1100kv motors on 4s with10 inch graupner props and wow talk about power. It's on my Y6 so I think I'm going to get 4 more for my ht frame.
Old Nov 23, 2012, 11:27 PM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
Originally Posted by MayMayDay View Post
This is quite the robust frame. Had a random failsafe, fell from about 3 stories. No major damage. Just need to replace a prop and re-epoxy an arm plate and I'm good to go. Thanks again for an awesome frame!
http://www.youtube.com/watch?v=lEXa6...ature=youtu.be
https://vimeo.com/54100567
Wish I was as lucky. I'm going to need some new arms and motor mounts, which isn't to bad considering it landed on a concrete parking block.
HT Crash (0 min 49 sec)
I'll post the crash damage in the morning.
scrape is offline Find More Posts by scrape
Old Nov 23, 2012, 11:34 PM
MayMayDay is offline
Find More Posts by MayMayDay
ParagonUAV
MayMayDay's Avatar
Canada, BC, Vancouver
Joined Mar 2012
OUCH
Know the cause? Are the electronics intact?
MayMayDay is offline Find More Posts by MayMayDay
Old Nov 24, 2012, 12:53 PM
scrape is offline
Joined Mar 2006
http://www.youtube.com/watch?v=G9w8W...&feature=g-upl
I think I pushed the battery to far. Think I'll keep it closer to the ground @ the end of the pack.
Willie Nelson Angel Flying to Close to the Ground (4 min 26 sec)
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4543 Yesterday 03:18 PM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
