Old Nov 19, 2012, 05:53 PM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
Originally Posted by flohio117 View Post
I love 4s also my tris fly on 4s and there awesome. The reason I'm sticking to 3s on my HT frame is because my gaui 960kv motors have a 3mm prop adapter and can't use graupners props so I'm stuck with apc and gaui props. And I don't want to run apc or gaui 8inch props on 4s bc the lift won't really be any better. Also I'm need to use the 3 batteries on something lol but my new iconic x quad is using 850 kv motors and ill be running that on 4s w/ graupner 9 or 10 inch props. It should be one mean flyer
Nice...i just ordered some suppo 2814 1k kv and 30amp simonk esc's to put on the quad...can't wait to see it go on 4s! Currently running 2212 850 kv and 4s
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Old Nov 19, 2012, 05:59 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Are your 2212s the Ipower motors? I have ipower 850 kv I think there 2212s
flohio117 is offline Find More Posts by flohio117
Old Nov 19, 2012, 06:59 PM
Joined Apr 2011
No...rctimer...I've had them since i started flying multi rotors...they have served me well too...just time for a change....
Although i have some ipower 2814's 750 kv and they rock too...they are currently on my Y6...but I'm breaking that down and making a Tcopter....should be pretty cool when its done...
Old Nov 19, 2012, 07:01 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
what fc are you using on your y6 i just built one with a naza and i need to tune it.
Old Nov 19, 2012, 09:54 PM
Kosmos is offline
Find More Posts by Kosmos
Just Starting..
Joined Oct 2012
Got some bugs to work out... (OSD GPS not getting a fix)
(long 8min boring backyard, I know but I am still excited I got it going!)
Believe it or not there were some stiff breezes blowing between those buildings - but I
may have some other calibrations to fix...
First FPV Backyard Flight (8 min 6 sec)
Kosmos is offline Find More Posts by Kosmos
Old Nov 19, 2012, 10:02 PM
The Recursion is offline
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
Kosmos are you using 1.2Ghz vTX?
The Recursion is offline Find More Posts by The Recursion
Old Nov 20, 2012, 12:33 AM
unfaix is offline
Find More Posts by unfaix
I'm New
unfaix's Avatar
United States, TX, Arlington
Joined Mar 2012
It doesnt seem like it since it's cutting in and out pretty badly.
I could be stupidly wrong though.
unfaix is offline Find More Posts by unfaix
Old Nov 20, 2012, 01:03 AM
Joined May 2012
Looks like multipathing to me.
Old Nov 20, 2012, 01:40 AM
Joined Apr 2011
I was flying the Naza...but i sold it....what are your current gains at?...pm if you have any questions...that way we dont clog this thread
Old Nov 20, 2012, 07:39 AM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Hi guys,
I found a new flying site and had a blast over the weekend FPVing. Here's some of the highlights. About a third of the footage was on my HT-FPV frame, the rest was a HT-450.
New Park Adventures (3 min 30 sec)
Cervanchez is offline Find More Posts by Cervanchez
Old Nov 21, 2012, 03:51 PM
MayMayDay is offline
Find More Posts by MayMayDay
ParagonUAV
MayMayDay's Avatar
Canada, BC, Vancouver
Joined Mar 2012
This is quite the robust frame. Had a random failsafe, fell from about 3 stories. No major damage. Just need to replace a prop and re-epoxy an arm plate and I'm good to go. Thanks again for an awesome frame!
HT-FPV Failsafe and Crash (1 min 17 sec)
MayMayDay is offline Find More Posts by MayMayDay
Old Nov 21, 2012, 03:59 PM
Quadrophil is offline
Find More Posts by Quadrophil
Joined Nov 2012
Can anyone with a CC3D flight controller post his successfull settings?
Right now I'm back to (pretty badly working) default settings, but I've tried a lot in the past. And it's neither hovering in one spot, nor very stable at all. Unfortunately not! That's why I'm starting to become a bit depressed with that frame. Spent sooo many hours trying to tune it right.
I'm running 3300mah to 3600mah 4s batteries with NTM 1200kv 28-26 motors and 8inch Graupner E-Props.
Any help would be highly appreciated!!
Quadrophil is offline Find More Posts by Quadrophil
Old Nov 21, 2012, 06:44 PM
vic20owner is offline
Find More Posts by vic20owner
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
Make sure your CG is correct, even back a bit further... and that your arms are straight (no twist in the arm). Any flight controller will work fine with this frame if the frame is balanced correctly.
read this thread for settings:
http://www.rcgroups.com/forums/showthread.php?t=1633231
vic20owner is offline Find More Posts by vic20owner
Old Nov 21, 2012, 09:02 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
Hey man where is the cg on this frame? Can you post a pic with an x on the cg?
Old Nov 22, 2012, 01:08 AM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Just run a string across the motors and where they cross is the c/g...which I think came out around 1" or so forward of the foremost end of the rear arms.
Vantasstic is online now Find More Posts by Vantasstic
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4545 Today 06:50 AM
Discussion Show us your FPV Multicopter Derek_S FPV Talk 194 Feb 08, 2013 12:07 PM
Discussion FPV Successful? Show us setup and parts list Royalson FPV Talk 0 Mar 10, 2012 08:25 AM
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
