Old Apr 03, 2012, 06:34 AM
new2flight is offline
Find More Posts by new2flight
Ocala, fl
Joined Aug 2002
Help!
want to learn how to make glass fuse.. ..
Hi I would like to learn hour to make fiberglass fuses
I need class101 for dummies. .Step by step inst on how to
do this art of anyone had a site, info comments I'd appreciate
The help ...look at profile jasonetgriff to see my work..
Kindly Jason
new2flight is offline Find More Posts by new2flight
Old Apr 03, 2012, 09:19 AM
G_T is online now
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
There is a lot of info in this forum. Do a search, perhaps using Google. Read for a while, then come back with questions.
0.02c
Gerald
G_T is online now Find More Posts by G_T
Old Apr 04, 2012, 08:59 AM
heliwill10 is offline
Find More Posts by heliwill10
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Here is a link to the best start to finish mold making I've found:
http://www.rcgroups.com/forums/showt...ke+long+skinni
Here is what's on my blog:
http://www.rcgroups.com/forums/showthread.php?t=1568475
heliwill10 is offline Find More Posts by heliwill10
Old Apr 16, 2012, 03:04 AM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
0.02c
Gerald
Absolutely!
In fact, I would say read lots and keep reading. Meanwhile, ask questions as they come up as Gerald says.
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Apr 16, 2012, 12:31 PM
yyz is offline
yyz
Find More Posts by yyz
yyz
yyz's Avatar
USA, CA, Paso Robles
Joined Dec 2004
Jason,
There are some good tutorials here:
http://www.cstsales.com/tutorials.html
And the West Systems products are easy to use, readily available and forgiving for a first-timer.
The only thing I would change is using Frekote mold release instead of what they recommend.
Keep reading and asking and best of luck,
yyz is offline Find More Posts by yyz
Old Apr 16, 2012, 05:28 PM
Joined Aug 2008
More than one correct way.
Jason,
One important point about composites: You will find that there is more than one way to perform a particular task, often many ways. Some of course are inefficient or plain wrong! However, the job can be done well several ways in many cases.
I would advise to avoid taking short cuts with inferior products like resin and wax etc. Many of us learned this the hard way and what turns out to be the expensive way. Good resin costs, but is cheap in the long run and a dream to use. Beginners (and experienced) need no unecessary handicaps like trying to wet out cloth with high viscosity/short pot life inferior resin. (This is just one example).
Jim.
Last edited by Jim.Thompson; Apr 16, 2012 at 05:29 PM. Reason: spelling correction.
Question Want to learn how to buil balsa planes NicholasIrwin Beginner Training Area (Aircraft-Electric) 16 Mar 24, 2012 12:55 AM
Discussion I want to learn to make carbon fiber parts gotthepassion1 Vendor Talk 1 Apr 14, 2010 04:39 PM
Discussion I want to learn to make carbon fiber parts eflightray Beginner Training Area (Aircraft-Electric) 2 Apr 14, 2010 03:56 PM
Discussion I want to learn to make carbon fiber parts eflightray Electric Plane Talk 0 Apr 14, 2010 01:20 PM
Discussion make a fuse out of honeycomb & glass, how? dalbert02 Composites Fabrication 2 Mar 06, 2008 06:59 AM
