Old Apr 03, 2012, 04:30 AM
ehirobo is offline
Find More Posts by ehirobo
Hong Kong
Joined Nov 2008
New Product
Walkera MINI super FP 4ch helicopter
Walkera new FP 4ch helicopter. A 4ch version of the Genius/ mini cp. Compare to it's 6ch brothers, the mini super FP seems to be a bit more stable. And a little longer flight time.
ehirobo is offline Find More Posts by ehirobo
Old Apr 03, 2012, 08:35 AM
mescalinedream is offline
Find More Posts by mescalinedream
Joined Jul 2008
The main motor they are using is the same as the mini. Flight times are going to be about 3min if your lucky. The board/frame layout looks just like the mini cp. I also see they changed the location of the coil that breaks off on the mini. This will probably be better than the msr, we will see. Ehirobo are saying 87.99$ Arf, 109.99 rtf with the new 2401d devo radio. I do see they say the servo is wk-02-5, the minicp uses wk-02-4 I don't know if that is a typo or not. Walkera had said they improved the mini/genius servo by making the cord longer and adding silicone grease to the internal electricals. They also said that the gears are stronger. Maybe the new improved servos are labeled wk-02-05. Anyone know? I think it's a typo cause if you look close on the pic above the servo says 4 or maybe it saays 5?
WALKERA Mini Super FP Flybarless 4CH Helicopter RTF - 2.4GHz
Features:
The flybarless design characterizes low power loss and great improvements in efficiency
Sophisticated 3-Axis gyro flybarless stabilization system automatically adjusts the controls for stable flight
Highly developed low voltage drive system provides a green, environmentally friendly and safe power solution
Mini size helicopter for indoors, providing 5-6 minutes of flight time after a full charge
Specification:
Overall length: 220mm
Main rotor dia.: 241mm
Tail rotor dia.: 42mm
Gyro: Three-axis
Main brush motor: 1220FC
Tail brush motor: 0615R
Servo: wk-02-5
Battery: 3.7V 240mAh Li-Po
Dimension: 220*40*77mm
Package Included:
Mini Super FP Flybarless helicopter
WK-2402D transmitter
Li-Po Battery Charger
3.7V 240mAh Li-Po Battery
Spare main blade X 1 pair
Spare tail blade
Instruction manual
All helicopter were setup and tested by skilled technican before delivery
As 2.4Ghz technology do not require any frequency contorl. Makes this mode a lot safer to operate and don't have to worry about bringing the wrong crystal to the flying field
Design for EXPERT pilot
mescalinedream is offline Find More Posts by mescalinedream
Old Apr 03, 2012, 01:49 PM
Picofly is offline
Find More Posts by Picofly
Blade 180 FPV & Mini-Protos
Picofly's Avatar
Helsinki, Finland
Looks like an ideal sub-micro FPV project!
Lighter and more efficent than Mini CP. My Mini CP weighs 49 g with a C05 motor 240mAh Hyperion, video camera and A/V transmitter. I guess Super FP would weigh around 45 g with the same setup and fly 2-3 minutes longer.
Picofly is offline Find More Posts by Picofly
Old Apr 03, 2012, 04:44 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Also FP can have higher lift profile blades with lower airspeed than it's CP "cousin", so some flight time might be won back there as well.
SoloProFan is online now Find More Posts by SoloProFan
Old Apr 04, 2012, 01:49 PM
FDR_ is offline
Find More Posts by FDR_
Joined May 2011
Servos are different for sure: it seems they have no controller within, just the pot... Look at the plugs! There is an empty plug for a third servo: ie for a CP version. It also uses CP blades too...
FDR_ is offline Find More Posts by FDR_
Old Apr 04, 2012, 02:05 PM
afloyd82 is offline
Find More Posts by afloyd82
ladybird, miniCP, msrx, 4F180
Joined Jan 2012
Dang, I want one. I like all of walkera's new product. I wonder if the Devo 7 will work with this since its all devo, just wont use all 7 channels on the TX.
afloyd82 is offline Find More Posts by afloyd82
Old Apr 04, 2012, 09:44 PM
StCalvin is offline
Find More Posts by StCalvin
ooops
StCalvin's Avatar
Dekalb,Illinois
Joined Oct 2003
I believe XHeli and Nitroplanes have had videos up for a while?
StCalvin is offline Find More Posts by StCalvin
Old Apr 04, 2012, 11:04 PM
afloyd82 is offline
Joined Jan 2012
I like the look of the head design. Looks like a mostly CP head with CP looking blades but at a positive pitch. I bet its gonna fly really well. I like my msrx a lot, this looks neater than that.
Old Apr 05, 2012, 01:51 AM
scub is offline
Find More Posts by scub
United States, MA, Springfield
Joined Dec 2010
..and how much is it, $169?
needs to be priced under $90
scub is offline Find More Posts by scub
Old Apr 05, 2012, 02:06 AM
FDR_ is offline
Joined May 2011
BNF $88:
http://www.ehirobo.com/shop/product_...ducts_id=11717
Old Apr 05, 2012, 04:21 AM
flyerinside is offline
Find More Posts by flyerinside
Spain, CL, Valladolid
Joined Oct 2011
And 109,99 $ for RTF.
It seems that Walkera has recovered common sense with their prices.
flyerinside is offline Find More Posts by flyerinside
Old Apr 05, 2012, 05:25 AM
ehirobo is offline
Hong Kong
Joined Nov 2008
The servo's look identical fromt he outside. But the mini use -4 and the super use -5. Not sure what is the different........
Old Apr 05, 2012, 05:57 AM
cgpirre is offline
Find More Posts by cgpirre
cgpirre's Avatar
Belgium
Joined Dec 2011
So this is a flybarless, fixed pitch, non-3d helicopter?
Does this mean it can handle wind lot better than the v911 for instance, or is this a privelege of cp helicopters?
cgpirre is offline Find More Posts by cgpirre
Old Apr 05, 2012, 07:08 AM
Xrayted is offline
Find More Posts by Xrayted
Closed Account
Joined Dec 2007
Originally Posted by FDR_ View Post
With shipping from $25-$45 to the U.S.
The one thing I hate about Ehirobo despite them having stock on many Walkera helis and parts.
Xrayted is offline Find More Posts by Xrayted
Old Apr 05, 2012, 07:52 AM
Travis MCH is offline
Find More Posts by Travis MCH
Travis MCH's Avatar
United States, TX, New Braunfels
Joined May 2011
I sent Wow Hobbies an E-mail about a week ago asking when this helis would be in stock. They quickly replied that they " WILL NOT be stocking or selling this heli as it's redundant to the Genius CP that is just as stable"
Go figure, they sell ever other Walkera, why not this one?
Travis MCH is offline Find More Posts by Travis MCH
Discussion My First FP Helicopter Walkera CB180D Crashing badly N8LBV Beginner Training Area (Heli-Electric) 160 Mar 06, 2015 11:30 AM
Sold Walkera V200DQ01 Helicopter 24GHz 4CH RTF HeliPro5 Aircraft - Electric - Helis (FS/W) 2 Dec 21, 2011 09:23 PM
Sold Walkera Helicopter 24GHz 4CH RTF HeliPro5 Aircraft - Electric - Helis (FS/W) 3 Nov 20, 2011 01:05 PM
Sold Walkera Helicopter 24GHz 4CH RTF HeliPro5 Aircraft - Electric - Helis (FS/W) 2 Oct 19, 2011 09:22 PM
New Product New Walkera 200SD3 Airwolf 4ch RC Helicopter Product Tour RaidenTech Mini Helis 2 Oct 07, 2011 12:16 PM
