1. DX7s yes if you can afford it
2. ar8000- works fine with any esc - but won't bind with out sat hooked up I believe. orange rx should be fine for park flyers. 3. Charger ac is fine but most you see are dc. which one now thats a tough one to explain, you need to look at the output of the charger or you will take forever charging your batts. 50 watts seem like a lot but not really---amps x volts = watts so when you get bigger batteries the amps you can put in are going down and charge time goes up. 5. ESC Battery Don't think you need one for the pnp, it will list what you need thats not included. 6. My plane -all work in this plane stock? here is 188 pages of info on the pz stinson http://www.rcgroups.com/forums/showt...arkzon+stinson |
Taiwan, 北市
Joined Dec 2010
This thread might be very helpful for you. http://www.rcgroups.com/forums/showthread.php?t=1586139
And I personally applied Turnigy 3S 2200 Lipo and iMax B6 charger for a long time, they all worked great for me. But Turnigy lipo comes with the yellow XT-60 connector, while B6 does not include such connector, you'd need an adapter between XT-60 and Dean connectors. Be reminded that B6 came with an adapter for AC use at home, and a lead/plug for charging with 12V car battery as well. And DX6i is more than enough for flying R/C planes, DX7 is way better but might be expensive if you are budget minded. They all work for flying FPV. There have been tons of trainer available on markets, better to find a high wing and slow one as your real trainer, Champ is not good enoguh for flying real R/C. Chen |
Here is a good site that goes over power in general - LiPo batteries, connectors, chargers, etc.
http://sites.google.com/site/tjinguy...arging-how-tos You need to pick a connector for your batteries and ESCs to standardize on. Or only buy one brand where they are the same, like E-Flite. But that can be expensive. For the most part, many like Deans. I decided to use Anderson Powerpoles because I can use some of the same equipment (like a watt meter) in my HAM radio gear (where APPs are the standard). |
Rochester, NY
Joined Sep 2009
1) The main things that will likely help you with flying your next plane are adjustable d/r and expo which both the DX6i and DX7s have. Which one is best for you depends on what sort of planes you hope to get into in the future. You might want to spend some time looking around at more advanced planes that interest you and see what sort of requirements they have in terms of channels, controls and programming. DX7s is probably the safer way to go as you'll have more options available to you then you would with a DX6i.
2) The AR8000 comes with a satellite. As far as parkflyer foam planes are concerned, a full range receiver without a satellite like an AR600 should be just fine in most cases; thus why parkzone uses it in pretty much all their non-micro BNF stuff. 3) You may want to spend some time looking through the battery & chargers section on this forum. There is a lot of useful information to be had if you're willing to do a little reading. As already stated B6 and Accucell chargers are fine if you're just starting out but as your battery collection grows you may find that 50W of charging power takes too long to get your batterys up and ready. You need a power supply to run the DC chargers, any one will do so long as they meet the voltage and current input requirements for the particular charger you're looking at. You may want to consider getting something with a little more power like a Junsi or Powerlabs charger (check out epbuddy.com or progressiverc.com for nice deals on them). They cost a bit more but pay off in the long run if you're sticking with the hobby (plus they work nicely on a couple of car batteries). 4) Non-micro Parkzone planes all use EC3 connectors. You'll need to buy an adapter for whatever lead batteries you choose, replace the connectors on the batteries and/or esc, or buy only parkzone/e-flite batteries (which I recommend against as they're overpriced and not of very good quality). Batteries can be charged either by the main leads or from the balance connector alone (up to about a 2A rate). Batteries have different types of balance connectors as well so keep that in mind when buying batteries and your charger. 5) As already explained, in the case of the stinson (and many other electric planes) the battery for plane connects to the ESC directly. A component in the ESC known as a BEC (battery elimination circuit) converts the voltage to ~5-6V which is used to power the receiver which in turn relays power to the servos. It works with pretty much any receiver you're looking to put in there. 6) I don't own a stinson but from what I've heard of it, it doesn't seem like a very good aileron trainer. You say you can do ridiculous stunts with ease on the champ but is that at constant WOT and max throws (linkage on the inner-most hole of the control horn)? Coming from a slower flying champ, it may be a bit of a jump in speed alone, moving up to a bigger plane. Also the plane doesn't sound very durable which is something really nice to have if you're starting to learn ailerons. If I were you I'd reconsider and perhaps check out an e-flite apprentice pnp or a parkzone ultra micro t-28. But to answer your question, yes that should work fine together provided the zippy battery has a decent c-rating (bare minimum 15C for a 2200mAh battery, I would recommend 25C or better). Hobbyking is dirt cheap but they have a checkered past when it comes to customer service, also some of the stuff they sell isn't of the best quality. Also pay attention to where you're ordering from, the global warehouse takes a while to ship here. As far as good deals go it really depends on what you're looking to buy. |
Hobby King has a USA warehouse http://www.hobbyking.com/hobbyking/s...obby_Warehouse in Tacoma , WA. Other good USA places to get things are : http://www.hobbypartz.com/ http://www.nitroplanes.com/ http://www.lazertoyz.com/shop/ Lazetoyz has an AC charger for $10 ( go to battery page and scroll down to bottom left of that page . http://www.bphobbies.com/view.asp?id=V819427
One of the best flying planes EVER is this one http://www.hobby-lobby.com/telemasters_216_ctg.htm comes in different sizes from 35 " wingspan to 12 FOOT wingspan ( the bigger they are , the better they fly - and they're easier to see from a distance ) . But I would recommend learning ailerons on something inexpensive ( possible crashes while learning ) like this one http://www.fancyfoam.com/index.php?m...g3sd5qve829ds5 funny looking but TOUGH and able to fly slowly - good for learning . But whatever you get , have someone who knows how help you set it up - correct CG , trim , dual rates , expo etc. |
Rochester, NY
Joined Sep 2009
Most ESC's that I know of aside from E-flite ones are sold without any battery connectors. I saw a couple Hobbyking brand ESC's with XT60 connectors on them but I'm not sure if I'd trust them. If you want a good ESC with an XT60 connector on it you'll have to solder it on. |
| Thread Tools | |
| Help! MultiWii Initial Setup Problems...PLEASE HELP! | superjon | Multirotor Talk | 0 | Mar 24, 2012 06:52 PM |
| Help! Buying FPV gear.. need advice on initial setup | neo__04 | Video Piloting (FPV/RPV) | 22 | Mar 08, 2012 10:25 PM |
| Discussion My final setup | Luisfc1972 | Beginner Training Area (Aircraft-Electric) | 8 | Feb 22, 2006 01:56 PM |
| T-REX SETUP My final conclusions for the H18L with 4 Tanic1050mah combo. | wildstallion | Mini Helis | 5 | Feb 24, 2005 05:48 PM |
| Final Setup on My Sirius | jayman | Electric Sailplanes | 2 | Jun 06, 2001 04:17 PM |
