Old Apr 02, 2012, 07:56 PM
wheels down is offline
Find More Posts by wheels down
United States, MN, Floodwood
Joined Dec 2008
Need a little help Byron F-16
I restored Byron f-16 put a os 91 in her
had a os 77
made a starter wand with 1/2" socket and slip clutch to turn the engine over
have a double nut on the crank shaft
try to fire it up tonight turn over a few time and the safety nut unscrewed
is this normal to use the nut to turn engine over
am I missing something that would go on the crank or something?
also if any one has any pictures of a starter wand for this jet
and a pic of any thing that is mounted on fan / crank
any help would be great
thanks john
wheels down is offline Find More Posts by wheels down
Old Apr 03, 2012, 09:30 PM
rcshirt is offline
Find More Posts by rcshirt
miniture aircraft pilot
rcshirt's Avatar
United States, FL, Tampa
Joined Oct 2007
yes, that is normal. loctite the nut and let it dry. a lot of times we would have to loosen the glow plug to get it to spin , then retighten the plug. use forceps on your fuel lines or the engine will flood and makes it harder.
on two of my f-16's i actually rotated the motor to the upright position to make the staring procedure easier.
rcshirt is offline Find More Posts by rcshirt
Old Apr 04, 2012, 08:23 AM
Joined Dec 2008
thanks for the advice
john
Discussion A Little Disappointed With My Phase 3 F-16 David McAfee Foamy EDFs 20 Mar 10, 2012 11:01 PM
Discussion Build help Byron Mig 15 & Byron F-16 bruff Arizona Model Aviators 2 Feb 16, 2012 11:41 PM
Discussion Need help wiring up Thrust Vectoring on f-16 Rone3 Foamy EDFs 10 Jan 07, 2012 01:42 PM
Sold Byron F-16 NIB CRCJA Aircraft - Electric - Jets (FS/W) 4 Nov 23, 2011 06:52 PM
Wanted I need a Dynamax starter Probe for the Byron F-16 Jets or alike mechengineer03 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Sep 20, 2010 04:26 PM
