This thread is privately moderated by DPage, who may elect to delete unwanted replies.
Old Apr 02, 2012, 08:43 PM
DPage is offline
Find More Posts by DPage
Trader Rating: 30
Joined Sep 2003
Trader Rating: 30
Sold
NIP Futaba FP-S9402 Dual Ball Bearing High Torque Hi Speed Metal Gear Coreless Servo
NIP Futaba FP-S9402 Dual Ball Bearing High Torque High Speed Metal Gears Coreless Servo
New In Package unused Futaba FP-S9402 Dual Ball Bearing High Torque High Speed Metal Gears Coreless Servo with servo arms, an mounting hardware. This is a high quality coreless high torque water resistant and dustproof servos. $75 shipped and paypalled.
Dan
Futaba S9402 Hi-Speed Coreless Ball Bearing Metal Gears High-Torque Servo.
The FP-S9402 is a high torque servo (111.1 ozs.) with an extremely fast response time (.09 sec) that makes it an excellent choice for rudder, elevator, and aileron applications on the two meter pattern aircraft.
This one is amazing! Just compare the torque and speed to other servos!
Great for 1/10 scale Cars, Boats, Airplanes and Helicopters.
This servo can produce high-current draw from your batteries. If using NiMH or LiPo batteries, make sure they are capable of delivering sufficient amps.
FEATURES: Hi-Torque
Coreless Motor
Two Ball Bearings
Metal Gears (brass and steel)
Dust and Water Resistant
Plated “J” type Connector (Gold colored)
One-Year Warranty
SPECS: Size: 1.6 x 0.8 x 1.5” (1-5/8 x 13/16 x 1-1/2”) (41 x 20 x 38mm) Weight: 1.9oz (1-15/16oz) (55 grams Torque: 89 oz-in @ 4.8V - 111 oz-in @ 6V (6.4 kg-cm @ 4.8V - 8.0 kg-cm @ 6V)
Transit time: .12 sec/60° @ 4.8V - .10 sec/60° @ 6V
Connector: “J” type with about 10” lead
INCLUDES: One S9402 servo
Four Black rubber rectangular grommets Four brass eyelets Four servo mounting self-tapping screws (#4x1/2”) Three black plastic servo horns (arms)
1- circular, 1- “X”, 1- “6-arm”
DPage is offline Find More Posts by DPage
Sold NIP Futaba FP-S9304 Dual Ball Bearing High Torque Coreless Servo DPage Aircraft - General - Radio Equipment (FS/W) 0 Apr 01, 2012 01:47 PM
Sold 2 New Unused Futaba Coreless Dual Ball Bearing S9202 Servos DPage Aircraft - General - Radio Equipment (FS/W) 0 Mar 18, 2012 08:46 PM
Sold 2 New unused Futaba Coreless Dual Ball Bearing S9301 Servos w 3 Servo Arms, Grommets DPage Aircraft - General - Radio Equipment (FS/W) 0 Mar 18, 2012 08:47 AM
Sold 2 New Unused Futaba Coreless Dual Ball Bearing S9202 Servos DPage Aircraft - General - Radio Equipment (FS/W) 0 Mar 04, 2012 10:55 AM
Sold 2 New unused Futaba Coreless Dual Ball Bearing S9301 Servos w 3 Servo Arms, Grommets DPage Aircraft - General - Radio Equipment (FS/W) 0 Mar 03, 2012 06:21 PM
