Apr 03, 2012, 09:26 AM
United States, NJ, Pompton Lakes
Joined Jan 2011
Originally Posted by ApexAero
A couple things I would suggest is change your connectors to at least 5.5mm on the batt and 4mm on motor. Use heat shrink not electrical tape. Don't plan on accurate readings using 12 gauge on a meter and 10 gauge on everything else. A 2200 40c ain't gonna make it, your over the output at 92amps when your batt is barely good for 88 amps, you'll burn the battery.
wow, I've been thinking about the gauge wires. Do I cut the 4mm males off my ARC motor and then solder 5.5's on ?
ALso please explain the battery situation. how do you know what amps a battery can produce? Do I need a larger capacity pack? I tried running the same test with a larger 3000mah skylipo 6s 40c and got the same results.
Thanks guys!
