Espritmodel.com Heli Air
Old Apr 02, 2012, 01:42 AM
Rhondas's Avatar
usa
Joined Dec 2004
charger that came with the Radio TO CHARGE the new NIMH BATTERY PACK ?
I have an older T6xa Futaba radio that came with a SMALL wall charger , the original battery was a NICAD 8 cell 600 mah AA pack, so I bought a NIMH 900 mah battery pack,
can I still use my wall charger that came with the Radio TO CHARGE the new NIMH BATTERY PACK ?
Rhondas is offline Find More Posts by Rhondas
Old Apr 02, 2012, 02:36 AM
Joined Aug 2002
Originally Posted by Rhondas View Post
I have an older T6xa Futaba radio that came with a SMALL wall charger , the original battery was a NICAD 8 cell 600 mah AA pack, so I bought a NIMH 900 mah battery pack, can I still use my wall charger that came with the Radio TO CHARGE the new NIMH BATTERY PACK ?
Yes, but 900 mAh does take 50% longer of the time taken to charge your 600mAh pack.
1. As supplied, the battery has a "chemical" charge only.
If the battery were to be charged before despatch ex factory, it would be flat before it hit the retailer's shelf.
2. NiMH do not reach full capacity until after at least the third use (charge).
3. NiCD were reasonably forgiving in the event of overcharge / overdischarge / hard knocks but NiMH are not. Majority of NiMH cells have a shorter life span than we used to expect of NiCads, best never to exceed 1c or one hour charge rate.
4. Black wire corrosion is just as much if not more evident in NiMH than was experienced with NiCad.
When Nickel-Metal Hydride (NiMH) was introduced in the early 1990s, much was made of its memory-free status. NiMH do suffer from crystal build up also known as "memory" but to a lesser extent than NiCd. No proven research is known that specifies best maintenance except all concur that repeated cycling of NiMH is not recommended because of the shorter service life.
NiMH were introduced solely to satisfy the EU "Greenies" as under the changed CE regulations, it was to become to expensive to continue with the supply and then subsequent return to and disposal by the supplier of the poisonous NiCD cells. NiCad are still allowed for use by emergency & medical services in lieu of NiMH.
101 re Charging RC Batteries - Titan Energy
Battery University
R/C Battery Clinic - Archived Articles Listing.
More information available under "Battery Care, Performance & DIY Battery Packs." at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
A.T. is offline Find More Posts by A.T.
Old Apr 02, 2012, 09:02 AM
58 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Absolutely. Just increase the charge time proportionately. A full charge from very low will need about 24 hours. But most of the time you won't be using anywhere near full capacity, so an overnight charge will suffice.
Daedalus66 is offline Find More Posts by Daedalus66
Latest blog entry: Polaris Aileron Pushrods
Old Apr 21, 2012, 10:33 PM
Rhondas's Avatar
usa
Joined Dec 2004
thanks for your answer
Help! Need Help Charging NiMH batteries with B6AC Charger bobepine Batteries and Chargers 8 Jun 16, 2012 04:19 AM
Discussion Charging NimH AAs with Ni CAD wall charger? Rob_P Batteries and Chargers 7 Apr 01, 2012 06:05 PM
Discussion charging new nimh battery scub Batteries and Chargers 3 Mar 31, 2012 08:04 PM
Discussion Charging my first lipo battery with my new charger insutama Batteries and Chargers 4 Mar 03, 2012 04:03 PM
Discussion Help with charging NiMH with NiCd charger Riodiler1 Batteries and Chargers 5 Nov 05, 2011 05:19 PM
