Old Apr 24, 2012, 06:17 PM
PROACE is offline
Find More Posts by PROACE
Rocky Mountain High and Higher
PROACE's Avatar
Joined Jan 2002
May 2012 Model Aviation, page 123 J-3 Cub, plans $19 and info on how to order.
I think I will order a set of plans for myself. Don't know when I would build but when I am ready there they are
PROACE is offline Find More Posts by PROACE
Old Apr 25, 2012, 06:29 AM
SBS_Pilot is online now
Find More Posts by SBS_Pilot
Sweden, Stockholm County, Sollentuna
Joined Aug 2010
If you like deltas, you can get some inspiration in this thread: http://www.rcgroups.com/forums/showthread.php?t=1383759
SBS_Pilot is online now Find More Posts by SBS_Pilot
Old Apr 25, 2012, 08:37 AM
aspeed is online now
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
The Sig Wonder is ok if built very light, maybe punch a few holes. I have a .10 on a Misflit which was a magazine plan from the 1980's. It works ok but would be better with the lighter servos that are more available now. Also any 2 meter glider would work as a conversion. I had one that was my favourite plane until the wing folded up. It was my best lawn dart - slow wing flutter down crash so far. Probably took close to a minute for the whole crash to be over. A SPAD .15 size plane may work good. Then there is a glut of control line airplanes. An F2D combat kit is about $50 and will go fine with a .10.
aspeed is online now Find More Posts by aspeed
Old May 16, 2012, 01:03 PM
ozmo01 is online now
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
R Randolph "Three Quarters"
ozmo01 is online now Find More Posts by ozmo01
Old Aug 18, 2012, 07:08 PM
MrBreeze is offline
Find More Posts by MrBreeze
Prop buster extrordinaire
MrBreeze's Avatar
United States, KY, Louisville
Joined Apr 2011
Sorry guys, been away for a bit. I have an HOB Decathelon framed up but it
looks like I may have to put it on a diet. I have the plans for the Chips, but I
was thinking Norvel .15 for that one. Also have the Wonder kit with plans to
use a Norvel .15.
MrBreeze is offline Find More Posts by MrBreeze
Old Aug 20, 2012, 11:57 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Another classic in any size:
http://www.rcgroups.com/forums/showp...8&postcount=14
coriolan is online now Find More Posts by coriolan
Old Aug 21, 2012, 12:00 PM
Moeregaard is offline
Find More Posts by Moeregaard
United States, CA, Thousand Oaks
Joined Sep 2010
The "Small Wonder," RCM Plan #673, from the January, 1977, issue of RCM. It's a nice-looking parasol-wing model, 46" span/320"^2, for .09--.15 glow and three channels. I built one years ago and it was a nice flyer at 32 oz. with my OS .10 FSR.
Moeregaard is offline Find More Posts by Moeregaard
Old Aug 23, 2012, 06:33 PM
OkiThumper is offline
Find More Posts by OkiThumper
Closed Account
Joined Feb 2006
I've got an unbuilt HOB 2x2, 2 meter glider. It would be very easy to mount an OS .10 R/C or Enya .09 R/C on it, by simply removing the balsa block nose cone and mount engine to the ply behind it. Did you use any downthrust and possibly also right thrust so it would track okay?
OkiThumper is offline Find More Posts by OkiThumper
Old Aug 23, 2012, 07:04 PM
Canada, ON, Cottam
Joined Jan 2012
Oddly enough I was just thinking about putting a .10 on my 2x2 when a guy in the club volunteered to tow up some gliders. I had to add a lot of weight to the nose and thought a .10 would be nice, and do some good. The .049's barely worked on the 2 meter planes, and we need mufflers which suck the power from the .049's. I didn't build the one that the wing sheared on and it is long gone, so couldn't say about the thrust. I still have the motor and some gliders. I would put in a couple of degrees down and right thrust though. It sort of needs a throttle servo too. Electric gives a second option for landing. I saw a guy stunting profusely with a Gentle Lady at a fun fly with a .10. His didn't break the wing.
Old Aug 24, 2012, 10:18 AM
GeorgeG97322 is online now
Find More Posts by GeorgeG97322
Power Upward
GeorgeG97322's Avatar
United States, OR, Albany
Joined Jun 2007
There was a plane called the Gnat which was a full sized plan inside an issue of Model Airplane News about 20 years ago. It was designed around the OS max .10 from that era. More of a pattern plane than sport type but it did fly quite well and was easy to build. If your interested, PM me, I should still have the plans around my shop somewhere.
George
GeorgeG97322 is online now Find More Posts by GeorgeG97322
Old Aug 24, 2012, 01:57 PM
Closed Account
Joined Feb 2006
Thanks for the offer George, but I am more of a sport flyer than pattern flyer. I have a couple other unbuilts in the queue, which are .10 power. The 2x2 appeals to me, because it would be a relaxed form of flying, without the hassle of an upstart launcher.
Old Aug 24, 2012, 08:54 PM
Toysareforkids is offline
Find More Posts by Toysareforkids
Tn
Joined Jan 2011
The Gnat was a biplane, for a .010 not a .10, and was any thing but pattern.
Unless there is two Gnats, it is possible.
Pat
Toysareforkids is offline Find More Posts by Toysareforkids
Old Aug 24, 2012, 10:23 PM
Power Upward
Joined Jun 2007
The Gnat as stated...
Old Aug 25, 2012, 09:51 AM
Canada, ON, Cottam
Joined Jan 2012
Then there is the SPAD Gnat. Made of coroplast. More for a .15, but a bit of trimming with tinsnips could work on a .10. Who has the patent on the name?
Old Aug 26, 2012, 10:37 AM
Closed Account
Joined Feb 2006
Oh, I suppose if it were iGnat, Apple would have have it patented.
George, although I am not a pattern flyer, that plane does seem a simple build and would not take long for one to get it flying.
Sold NIB O.S. .10 LA motor garrettt04s Aircraft - Fuel - Engines and Accessories (FS/W) 2 May 03, 2012 05:14 PM
Discussion In the market for another plane, not sure which direction to go bdshort Electric Plane Talk 15 Apr 03, 2012 05:59 PM
Discussion Which plane for a beginner? giantsfan Beginner Training Area (Aircraft-Electric) 57 Mar 14, 2012 02:20 PM
Alert LA no fly zone for 10/22/10 Doc Holiday48 Multi Task F3X 31 Oct 27, 2010 05:05 PM
Discussion Any demand for LA .10 size bi-plane racer? Ken Park 1/2A Planes 18 Sep 10, 2008 08:02 AM
