(7/31/2012 update: the latest file version is now attached to the first post. and will be updated there whenever needed)
Okay, spent a lot of time completely rewriting the Hot Wire Calculator, and I think it's looking good. Checked all of the earlier user data against it and the answers all worked. I also added preliminary data for wire types other than stainless steel -- thanks gmwahl. There's a new variable for this called "resistivity. Just plug 700 in there for most stainless steel. The spreadsheet should be self explanatory in this area. Regular steel wire looks like about 250. I'll post it here now, but have more to say about it a little later tonight, plus will work out examples tried before. |
I would definitely put a 5 amp fuse in line with the bow, and maybe also an ammeter to check and make sure you're under the rated PSU output. I'd also probably make the bow 50" but add a coiled air resistor of about 20" using the same wire. That would make the total electrical length 70" which would drop the amperage (and heat) a bit. Then with a lead and alligator clip gradually clip onto the coil closer in until I got the cutting temp I wanted (preferably), or my meter was getting close to the PSU limit, and go no further without using a higher rated power supply. EDIT: maybe that fuse should be a Slo-Blo type. When the wire is cool it might draw more than 5 amps momentarily and blow a fast blow fuse. Or maybe use a 6 amp fuse. But then you're not really protecting the PSU very well. The PSU might also shut down if the initial momentary draw is over its limit. |
The far end will reduce the current (and heat) the most.
Seems like I'm getting into wire cutter design and advice, and I hadn't meant to do that in this forum thread, just ask for some data input to work up an experimental, and hopefully helpful wire size calculator for others to use work out their cutter designs. Personally, I think a fixed regulated power supply is not the best or easiest choice for wire cutters, and isn't what I use myself even though I have several of them lying around here. By using an air resistor, we're trying to make a regulated supply somewhat variable. A wire cutter should be variable for lots of reasons -- initial testing at lower than maximum power, cutting different sizes or types of foam at different heats, etc. Wire air resistors have several drawbacks like limited adjustment range, and the fact that they get hot themselves, etc. Everything is probably do-able, with a fixed regulated computer supply but as with all homemade bow setups, it takes some electrical understanding and design foresight not to produce something that cuts poorly or is even potentially dangerous. Maybe it would be best to open a new thread for this particular fixed supply design. I'm happy to answer questions here about the wire calculator, and certainly also grateful for user data to improve or correct it. You might also look for threads including air resistors and PSUs. I remember seeing someone else's setup like this which included photos, here on the RCGroups forums. I'll try to work out an example calculation with the spreadsheet for your smaller bow today, too. |
United States, OR, Portland
Joined Jan 2012
Sorry about the side track clutter. Maybe have this exchange removed from here & off to the nw thread? I know this isn't the easiest path, but I think it could be useful for those who don't have readily available access to a true variable setup. I am grateful for the assist.
~psguardian |
led dimmer
Put an LED dimmer on the output from the PSU. You can then vary the power from 0-8amps
![]() http://www.ebay.co.uk/itm/1x-DC-12V-...item2a1dc13e58 |
In the USA: http://www.ebay.com/itm/1x-DC-12V-24...item231f17c5a0 Joe |
| Thread Tools | |
| Question Drivers and Steppers for CNC Hot wire foam cutter | sscherin | CAD/CAM | 1 | Feb 27, 2012 03:08 PM |
| Wanted CNC Hot Wire Foam Cutter (4 axis) | -Snowfly- | Aircraft - General - Miscellaneous (FS/W) | 0 | Dec 07, 2011 04:13 PM |
| Discussion Need plans for hot wire foam cutter | chuckinnc | Foamies (Scratchbuilt) | 2 | May 17, 2009 12:04 PM |
| Discussion Need advise making hot wire foam cutter | Fuelman | DIY Electronics | 7 | Nov 22, 2008 12:04 PM |
| HELP: Need info on building hot wire foam cutter | Chic | The Builders Workshop | 4 | Jan 11, 2003 11:13 AM |
