Old Apr 01, 2012, 07:50 PM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
Question
HET 700-68-1500 KV motor shaft moved forwards.
1st run up with HET motor in fan ran for about 1 minute, then motor locked up.I pulled motor back out of fan, windings look fine and all but even with pliers I could not turn motor shaft.I ended up pushing shaft rearwards and it popped back, and then I was able to turn motor over but its still pretty tight.Is this common with the larger HET motors, and is there any way to stop this from happening?I know this motor is ruined but if I bought another one,I feel the same thing is going to happen and I rather not take a chance hurting the fan or jet next time it happens...
fh64_lucky is offline Find More Posts by fh64_lucky
Old Apr 03, 2012, 04:30 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I don't know about this motor. But the shaft might need a collar. Some motors only have e-clips.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Apr 03, 2012, 05:35 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
HET is an inrunner. No clips or collars. The bearing load is born by the motor's end caps.
Only way for the shaft to have moved forward would be for the front bearing to have failed.
Lucky, if you can get either of the end caps off the motor, you should be able to replace the front bearing with a higher quality one from Boca, etc, and, if the rotor's bearing surface is not damaged, run the motor again.
I've gotten pretty good at knocking inrunners apart if you want a hand with it. Rear cap with the wires usually comes apart the easiest with a little heat and some tapping on the motor shaft. Then you replace both bearings, as the tapping likely damaged the rear bearing.
murdnunoc is offline Find More Posts by murdnunoc
For Sale HET typhoon 700-68-1400kv w/ 90mm EDF HET 9305 EDF c2nv Aircraft - Electric - Jets (FS/W) 2 Apr 06, 2012 05:38 AM
For Sale HET typhoon 700-68-1400kv w/ 90mm EDF HET 9305 EDF c2nv Aircraft - Electric - Power Systems (FS/W) 1 Mar 31, 2012 07:28 PM
Sold Turnigy T600 and HET 700-68 motors oscarel Aircraft - Electric - Helis (FS/W) 0 Feb 15, 2012 03:44 AM
For Sale Turnigy T600 and HET 700-68 motors oscarel Boats (FS/W) 0 Feb 11, 2012 11:49 AM
Sold EDF motor inrunner HET TYPHOON 700-68 / 1680 kv pajlotmato Aircraft - Electric - Jets (FS/W) 0 May 08, 2011 11:21 AM
