Old Apr 01, 2012, 03:12 PM
KiTCyclic is offline
Find More Posts by KiTCyclic
KiTCyclic's Avatar
Joined Jan 2004
Slash 4x4 SVU with VXL-3s
So I got an ultimate and got it out there. On the second battery the ESC started smoking. Traxxas is going to repair it which is good but here is my question. I am new to these trucks and I swear I don't remember the truck not rolling when pushed by hand, but since that smoke incident, I cannot push the truck by hand. It just skids. When I spin the rear wheels, two rear wheels spin and same for front.
Is my motor shot or locked up too? Or is this normal?
Thanks for any advice or help you can offer!
KiTCyclic is offline Find More Posts by KiTCyclic
Old Apr 01, 2012, 04:39 PM
rustlererad3 is offline
Find More Posts by rustlererad3
Outdoor Extremist
rustlererad3's Avatar
Pennsylvania
Joined Jul 2010
I just smoked my esc saturday but I am not sure about this, ponder and research this I will
rustlererad3 is offline Find More Posts by rustlererad3
Old Apr 01, 2012, 06:23 PM
KiTCyclic's Avatar
Joined Jan 2004
after removing the motor I was able to turn it with a pair of pliers. It is slowly loosening back up, what does this indicate?
Old Apr 01, 2012, 09:52 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I would bet that the reason the ESC fried was the motor seizing up, not the other way around.
Did it get wet? I would flush the motor with electrical cleaner and oil the bearings to see if that helps. If it doesn't, its possible that the rotor came apart and is rubbing on the stator. If its the latter, the motor is likely 100% toast.
wparsons is offline Find More Posts by wparsons
Old Apr 02, 2012, 05:03 AM
KiTCyclic's Avatar
Joined Jan 2004
No water, but it was a 3s battery. Only the second run ever though! I will just send the motor back this time instead of tearing it down since it is under warranty. I just wish I would have packaged it with the ESC when I sent it!
I ordered a MMP and Novak 6.5t to replace these two with but I'm guessing 3s is not a good idea for the stock setup?
Thanks for your reply.
Old Apr 02, 2012, 06:52 PM
Outdoor Extremist
Pennsylvania
Joined Jul 2010
as long as you replace your one plastic gear in the trans and convert to robinson racing you should be good for a little while
Old Apr 02, 2012, 07:59 PM
KiTCyclic's Avatar
Joined Jan 2004
The plastic gear has no issues that I can tell nor does it show signs.
Old Apr 03, 2012, 01:40 PM
Outdoor Extremist
Pennsylvania
Joined Jul 2010
it will after some 3s time...plastic gears plus metal gears plus 3s equals smoked plastic
Old Apr 03, 2012, 06:54 PM
KiTCyclic's Avatar
Joined Jan 2004
seriously reconsidering these damn 3s batteries. Anyone wanna help me make the decision to get rid of the 3s. I have ran one cycle on one and the other one has never been ran. And I got a bad motor, bad ESC, people talking of stripped gears, all for a lil adrenaline!
Old Apr 06, 2012, 09:38 PM
Outdoor Extremist
Pennsylvania
Joined Jul 2010
okay theres nothing wrong with 3s just bear in mind stock the truck is built to somewhat handle it because they are not bulletproof for 3s if you want bulletproof 3s capability be prepared to put in a little wrench time and the rewards are tremendous
Sold Slash 4x4 Vxl Novak1/8 RPM harrisjp Cars - Trucks and Parts (FS/W) 8 Mar 28, 2012 12:06 AM
Discussion Emaxx for mini e revo vxl and slash 4x4 vxl . rcfanatic123 Trader Talk 2 Mar 20, 2012 06:16 AM
For Sale Traxxas Slash 4x4, Brushless Velineon VXL 3s + extra nitin1518 Cars - Trucks and Parts (FS/W) 3 Feb 29, 2012 01:36 AM
Found Traxxas Slash 4X4 Waterproof Velineon VXL-3s ESC & 3500 Motor Chunks Cars - Accessories (FS/W) 0 Apr 07, 2011 08:07 AM
Discussion Slash 4x4 vxl 3s power Just Lucky Off-road Cars 1 Dec 30, 2010 04:31 PM
