Old Apr 01, 2012, 09:31 AM
N2RYD is offline
Find More Posts by N2RYD
Joined Mar 2005
Will lipo go bad on first charge
I am a new bee with electric power. I won a Park zone SR-10 BNF. I went out and purchased a Cellpro power lab 6 and acc.
I read here on RCG about Gens ace lipo and purchased 2 2500mAh 3s1p 25c and changed the supplied charge connecter over to an ultra deans.
I just when and tried it 1st charge and the Cellpro displayed that I had a bad cell.
1) Did I do something wrong?
2) Dose this occure some time?
3) Is there ant way to restore the pack back to life?
Bob
N2RYD is offline Find More Posts by N2RYD
Old Apr 01, 2012, 10:08 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
What are the individual cell voltages as measured through the balance tap?
Info on overdischarged lipoly restoration here: http://www.rcgroups.com/forums/showthread.php?t=1074181 Level of success is a mixed bag.
You need to assess whether you have a bum tap connection first before attempting any restoration procedure.
If you do determine that you received a bad pack, my recommendation would be to seek warranty replacement.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Apr 01, 2012, 10:33 AM
N2RYD is offline
Joined Mar 2005
Thanks Mark. Like I said I new at this.
Bob
Old Apr 01, 2012, 02:05 PM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Minor correction the FMA CellPros are 4S charger <Edit > there is a CellPro 10 and 10XP.
The 6 and 8S ar Powerlabs.
GensAce use JST-XH connectors and Powerlab 6 (in your case) needs to be set to JSt-XH) balance node not FMA node mode. You Also need to use JST=XH balancing adapter . Al this is unless you have a FMA node to JST-XH node adapter board in which case you would leave PL6 in the FMA balancing node.
Yes this is all a lot to grasp and sort out. There are no standards for balancing leads configurations or connectors.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Discussion Charging my first lipo battery with my new charger insutama Batteries and Chargers 7 Oct 16, 2013 08:24 PM
Help! First charge of Lipo after it's been sitting for a while BillzillaAus Batteries and Chargers 10 Mar 27, 2012 07:57 PM
Discussion New LiPo First Time Charge? tonyd075 Batteries and Chargers 4 Feb 29, 2012 06:16 PM
Discussion Charging a Lipo for first time photopilot Batteries and Chargers 15 Jan 25, 2012 02:43 PM
Discussion bad to leave lipo's charged joohn Batteries and Chargers 8 Sep 19, 2011 04:40 AM
