Old Oct 23, 2003, 08:50 PM
dulcelife is offline
Find More Posts by dulcelife
Non Practicing A&P Tech
dulcelife's Avatar
Tampa, Florida, United States
Joined Aug 2003
Mountain Models Cessna 180 Build Step by Step
This thread is meant as a pictorial step by step building guide for the newbie interested in seeing how to put together the MM Cessna 180. It is my second balsa build after the Dandy but that one doesn't count because of how easy it really is to build. The Dandy really is simple as a jigsaw puzzle only easier!
The 180 is a bit more involved although the beginner should be able to put it together with some help from these threads. Inorder to jump start those beginners just dieing to see pictures, I will post all the images I have thus far in my build and will go in and edit each post just as fast as I can in the coming weekend.
Let's start with what you get in the mail from Doug at Mountain Models:
dulcelife is offline Find More Posts by dulcelife
Old Oct 23, 2003, 08:54 PM
dulcelife's Avatar
Joined Aug 2003
Be very carefull when opening the package as this is laser cut and the pieces fall out very easily. Try to find a surface you will not disturb and lay out the different sheets hopefully with their pieces in place:
Here's what you get:
Old Oct 23, 2003, 08:55 PM
dulcelife's Avatar
Joined Aug 2003
Lay it all out:
Old Oct 23, 2003, 08:57 PM
dulcelife's Avatar
Joined Aug 2003
The first order of business is the tail wheel which following the instructions is quite self-explanatory. I opted for a dubro wheel, but made the stock wheel because I love to follow directions... yeah right...
Old Oct 23, 2003, 08:58 PM
dulcelife's Avatar
Joined Aug 2003
Next we start the fuselage side and this is once again quite simple and well documented in the builders manual.
Old Oct 23, 2003, 08:59 PM
dulcelife's Avatar
Joined Aug 2003
You should wind up with this:
Old Oct 23, 2003, 09:02 PM
dulcelife's Avatar
Joined Aug 2003
Next we join the two sides of the fuselage with bulkheads. I recommend you use the parts outline in the beginning of the manual and match them up on the plan. It is important to use a builders triangle to insure things are square. I use this big one from The Home Depot because It will stand on its own.
dulcelife's Avatar
Joined Aug 2003
Build it up!
Old Oct 23, 2003, 09:06 PM
BrunswickOH is offline
Find More Posts by BrunswickOH
Brunswick, Ohio
BrunswickOH's Avatar
Joined Aug 2003
Put on some SHOES!!!!! and correct that to Mountain Models!!
BrunswickOH is offline Find More Posts by BrunswickOH
Old Oct 23, 2003, 09:22 PM
dulcelife's Avatar
Joined Aug 2003
Here is a view from the front with all of the bulk heads. Heed the warning about making sure F2 and F3 facing the front. It is clearly marked on the pieces.
glenclif is offline
Find More Posts by glenclif
Watch This !!!
glenclif's Avatar
United States, FL, New Smyrna Beach
Joined Jun 2002
I don't remember seeing any toes in any of my MM Kits !!
glenclif is offline Find More Posts by glenclif
Old Oct 23, 2003, 09:23 PM
dulcelife's Avatar
Joined Aug 2003
The view from the rear:
Old Oct 23, 2003, 09:24 PM
dulcelife's Avatar
Joined Aug 2003
You then insert the stringers being careful not to snap them, glue and sand the rear to match the shape of the fueslage.
Old Oct 23, 2003, 09:25 PM
dulcelife's Avatar
Joined Aug 2003
Do the same for the top of the fuselage.
Old Oct 23, 2003, 09:28 PM
dulcelife's Avatar
Joined Aug 2003
The wing mount is a nifty little piece that needs to be aligned nicely before you glue the carbon fiber supports to the inside of the fuselage. In my case it was too loose a fit, so I carefully jury-rigged a method of bringing them closer together without putting too much stress or worst snapping any balsa. The rubber bands are very very loose.
Mountain Models Cessna 180 - construction pics! Martin Hunter Parkflyers 139 Aug 17, 2005 11:46 AM
Another Mountain Models Cessna 180 Basketcase Parkflyers 7 Sep 06, 2002 12:05 AM
Any flight reports for the Mountain Models Cessna 180? Drewmotion Parkflyers 19 Jul 14, 2002 02:54 AM
Question Mountain Models--Cessna 180?? steve f Parkflyers 116 Jun 03, 2002 11:13 AM
Mountain Models Cessna 180?? steve f Parkflyers 11 May 02, 2002 08:41 AM
